We get an error code - 10.10.01 on our HP 4600 Color printer. What does this mean?
SOURCE: HP Photosmart all in one C3180
My suggestion: Don't buy HP. I have the same region coding problem. All I want to do is buy HP ink, put it in my HP printer and print stuff. Too hard. I've wasted 30 pounds on ink and another 30 pounds on "support" phone calls to HP. Hopeless. I will never buy HP again. Waste of time and money.
Posted on Nov 19, 2007
leroyal
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
KingDWS
  • 1606 Answers
SOURCE: ''HP Laserjet 4600, Error code 81 0180 E10 1 Error''
That indicates that the printer has a network card problem. You can try rebooting/resetting which can clear it but usually means a trip to the hp repair shop.
Posted on Jul 09, 2009
  • 19 Answers
SOURCE: HP 4600 Color Printer stays in "Initialize" Mode
If you are using a jetdirect network card it could be the cause of your problem. Pull the network card and restart the machine. Seen it a couple of times
Posted on Jul 28, 2009
  • 39 Answers
SOURCE: HP color laserjet 4600 dn printer How do I set
From the control panel of the printer, do the following:
1. arrow down once to highlight the 2nd item: "paper handling".
2. press the check button (turquoise color) to select this option.
3. arrow down 2x's until you highlight the "tray 2 size".
4. hit the check button to select this item.
5. You should see a size that is "letter" and there should be a ' * ' asterisk which means that is the default setting. If you see other paper sizes as well, then arrow up or arrow down to highlight the preferred size, and then press the check button to insert the asterisk ' * ' which will set that as the default.
6. you change the paper type as well as paper size for the other trays in the same fashion. Most HP printers will select paper according to the SIZE as well as the TYPE. The printer can "sense" the paper size in the paper cassette tray by the stops that hold the paper. Therefore the printer will choose that paper based upon the SIZE and what you define as its type.
Posted on Feb 19, 2010
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
Hp color laser jet 4600 57.40 error
57 indicates a printer fan error has occurred
the .4 points to the formatter fan (F1) is bad.
Connector J1004. Voltage should be 24 VDC between pins 1 & 3.
If it is, then replace the fan, if it isn't, replace the DC Controller PCB.
May 01, 2014 | HP LaserJet 4600 Printer
Regularly getting error code 50.9 on a HP color laserjet 3550 printer
Hey Joe,
This is what the HP Website has to say about it:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
BUT! you can try performing a cold reset, and maybe this would help:
500, 3550, 3700, 4600, 4650, 5500, 5550, 8500, 8550, 9500) use the instructions below. 1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
Feb 07, 2011 | HP Color LaserJet 3500 Printer
Need to have 4600 laser printer in just black ,because of broken
Sorry, my friend, there is no way to force it go B/W and override the error message.
Sep 09, 2009 | HP LaserJet 4600dn Color Printer
Hp 4600 error message 51.2c The message appears as soon as i insert the cyan cartridge. It was working properly but after printing 2000 pages (mostly blue color) there was noise and after that the message...
errors in the 51 range are laser scanner errors, it's saying either the laser is out or the scanner motor is not turning, or not turning fast enough. A good shop repair.
Aug 12, 2009 | HP LaserJet 4600 Printer
''HP Laserjet 4600, Error code 81 0180 E10 1 Error'' the printer does not work. please help !
Jul 09, 2009 | HP LaserJet 4600dn Color Printer
Error Code 51.2 C on an HP 4600
A 51.2 error message means that there is an error 51(Printer Error).2 (Laser Error) C (Cyan). This basically means that there is something wrong with the laser and the cyan color laser.
Reference via HP Website, Click Here
To Fix the problem:
  1. Press the green c00224695.jpg (Select) button to continue.
  2. Turn the printer off, and turn it on again.
  3. Perform a cold reset.
    1. Turn on the printer.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the c00224695.jpg (Select) button.
    4. Continue holding the c00224695.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the c00224695.jpg (Select) button when the Ready, Data, and Attention light are on steady.
    6. The control panel will display SELECT LANGUAGE .
    7. Press c00224697.jpg (Down Arrow) button once. The control panel will display COLD RESET .
    8. Press c00224695.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
  4. If this message persists, contact an HP-authorized service or support provider.
Mar 21, 2009 | HP LaserJet 4600 Printer
HP color laserjet 4600 dtn
It sounds like to me you purchased a bad fuser. Is the fuser brand new or a refurb? If so either way you will have to replace it with a working fuser . Good Luck!!
Nov 29, 2007 | HP LaserJet 4600dn Color Printer
239 people viewed this question
k24674
jasbo
jasbo
