Question about Grundig S350 AM/FM/SW Radio
S350 won't stop scanning on AM/MW mode. Tech support said reset with paper clip but that won't stop it either. Any thoughts? John G. Warren john.g.warren@jci.com
  • Grundig Master
  • 8,016 Answers
Strange. How can it, since that Radio does not have an Automatic Tuning System. To tune in to any frequency you have to turn one of two knobs. Are you sure about the Model Number?
Posted on Aug 19, 2011
I have a 2007 Pontiac G6 Gt convertible automatic with manual option. Engine is a 3.9 liter V6... last night no problem at all with the transmission, while driving to work the next day in drive, as usual,...
Hi Warren, Best advice I can give you is to take the vehicle and have a diagnostic scan carried out. Sounds to me as if the transmission has gone into limp mode. The problem could simply be a defective speed sensor on one of the wheels, or more complicated and inside the box. Once you have the fault codes let us know what they are and we can maybe give an idea of the work required. Regards John
Sep 07, 2014 | Cars & Trucks
Ink cassete is jammed
Hp 5280 is just a pile of garbage. Make loud gear stripping
noise and won\'t load paper. Tryed all the fixes. I think all
these cheap printers/scanners are programmed to stop
working a certain time so they can sell you more JUNK !!!!
MW
Aug 07, 2013 | HP Photosmart C5280 Printer
My Grundig S350 won't turn on. I have replaced the batteries and hit the reset button and still nothing. Please help.
Its Deluxe Version the S350 DL can use two types of batteries: D-size or AA. Inside the battery compartment there is a switch to select the size in use. If you use the AA sie batteries, they will not hold in their locations unless you lower a flap and secure them.
Have you tried to power the radio with the adaptor?
Aug 27, 2011 | Grundig S350 AM/FM/SW Radio
I have used my Grundig S350 radio almost daily, for the past 6-7 years. I went on vacation for 10 days. When I returned home, I turned on the power, lights light up, etc., but no sound...no matter how...
Hi
Its microcomputer chip may have hanged. Just make a reset ans see whether it helps you. It must help you, i"m sure. To reset it;
S350 incorporates with micro computer chip (the component that
controls how the radio operates). If the radio has been subjected to
abnormal environmental conditions, the micro computer chip may
hang up and the following symptoms may appear
The display shows nothing and the radio cannot be turned on by
pressing POWER & SLEEP button.
The display shows random characters or does not work properly
although the radio can receive stations normally.
In these cases, you might need to reset the radio. To reset the
S350, unplug the external adaptor (if one is being used) and
remove the batteries from the battery compartment. Insert a
pointed object, such as straightened paper clip, into the RESET hole
on the right, front side of the radio and gently press and release the
button inside the hole. Then plug in the AC adaptor or reinstall the
batteries
OK.
Jul 13, 2011 | Grundig S350 AM/FM/SW Radio
Grundig r2001 radio error 3 cant sort it after flat batt
The picture shows an S350 -- if your model looks like that but with a different designation this fix may still work:
Look above the gain knob (bottom right) and then above the Tuning fast -- slow lettering. You should see a reset hole. Use a paper clip to reset the radio.
Ringbearers
Apr 04, 2011 | Grundig S350 AM/FM/SW Radio
How do I resest my GPX MW-3847?
there is a buton in the back use a unfolded paper clip to pushit
Jun 15, 2009 | GPX MW-3847 MP3 Player
Canon Pixma 210 series has an error code 6000, won't print or scan
Hope this helps
With thanks to a canon tech
Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
May 22, 2009 | Canon PIXMA MP150 All-In-One InkJet...
AM radio tuner set as MW tuner. How to switch to U.S.A. AM mode?
AM is just another name for MW. The Radio should tune to a strong signal regardless of the frequency the radio is set to. It should also sweep the entire frequency looking for stations. I'm assuming it has a channel scan setting, plus options to set a number for the station. AM/MW are very much dependent on the position of the either internal or external Ariel. If you have the radio in the wrong position or you have some electrical equipment nearby it could block the signal for the station you want, but not affect the others. Which might explain why it can't find the station you want.
May 05, 2017 | Philips DCM230/37 iPod Docking Executive...
Gpx 2 gb mp3 problem
There is a reset button on the back of the MP3 player. Use a paper clip and reset the player. It will keep everything and should "wake it up". Try plugging it back into the computer now.
Hope this helps!
Jan 02, 2009 | GPX MW-3847 MP3 Player
Grundig S350 digital display
The radio is analog with a digital display. Mine displays off all the time, you can try turning the other switches on it just slightly. Just move them a tiny amount. This seems to correct my problems. Heat is also another factor with these things, they drift all over the place.
Dec 09, 2006 | Grundig S350 AM/FM/SW Radio
Grundig S350 AM/FM/SW Radio Logo
Top Grundig Audio Players & Recorders Experts
k24674
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
