Question about Trekstor Computers & Internet
Unfortunately I dropped my Trekstor 500GB hard drive on the floor and now it registers as a removable disk with message "please insert disk into removable disk". My computer is a Windows vista. Can the Trekstor be repaired (assuming its a hardware problem with the Trekstor) and can I retrieve my data. Until now it worked perfectly. Thank you Paul Anderson
    Master:
  • 388 Answers
Yes you can retrive the information using a data recovery program you may get it working again bye re-formating the har drive this will loose all the info use the data recovery to get it back.
Posted on Oct 06, 2010
    Brigadier General:
  • 10,406 Answers
An external unit has two main parts:
* the disk-drive
* the USB-to-disk-drive adapter
In your case, the adapter seems to be working OK.
But, when Windows tries to read the 'table-of-contents' from the disk-drive, it cannot,
and so you get the 'please insert' message.
You might want to disassemble the unit, and remove the disk-drive,
and connect it as a 'slave' disk-drive in a desktop computer,
just to bypass the adapter, to see if the disk itself can be read.
So, about 0.1% of the blocks on the disk-drive are 'unreadable'.
This means that the other 99.9% of the disk-drive _could_ be readable,
namely all your files.
Search online for 'DATA RECOVERY' software -- it reads through the blocks on the disk-drive,
block-by-block, trying to 'stitch' blocks back together (like assembling a jigsaw puzzle) to
reconstruct the (unreadable) table-of-contents, and thus make it possible to copy the files
from that drive onto the 'C:' drive of the desktop computer.
    Guru:
  • 1,481 Answers
Gone...throw it away...the disks inside are corrupt now it cant be used...
I dropped my TrekStor DataStation maxi g.u - 3.5"
Hello
You need to understand that a hard drive is very similar to glass, if you drop it, its done for, and it breaks.
contact a data recovery service if you had something of importance in the drive, you will not be able to recover anything out from it yourself if you really dropped it.
they break, they can break even if the case falls over on it self on the table.
let me know if you have any other questions.
Thanks.
Ekse
Feb 04, 2011 | Trekstor DataStation maxi m.u SATA 3.5"...
I dropped my TrekStor DataStation maxi g.u - 3.5" External Hard Drive 1TB & USB 2.0 on the floor. When I turn it on the light illuminates however when I plug it into my computer it doesn't even...
Mechanical damage. Last possibility to retrieve the data on it: open the case, extract the hard disk, put it in a desktop and try to access it in there. If even this fails then it's dead, junk it.
Feb 04, 2011 | Trekstor 88470 DataStation duo w.u 1TB...
When I click on my icon(which has a ? mark on the side) this message comes up. The drive or network that the shortcut TREKSTOR (E).Ink refers to is unavailable make sure the disk is properly installed or...
If you don't have the Trekstor, then just delete that ICON (the one that causes the problem when you click on it).
Or, find the Trekstor, and connect it to your computer, and click the ICON.
Dec 31, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
Just need to ask, trekstor external HD light is
Hi, unfortunately your are probably right. You can buy a new hard drive and install your self as the cheepest option?
Jul 10, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
Constant blue flashing light,computer will not detect
I dropped my Trekstor 500GB hard drive and now it registers as a removable disk with message "please insert disk into removable disk". My computer is a Windows vista. Can the Trekstor be repaired and can I retrieve my data. Until now it worked perfectly. Paul
Feb 12, 2010 | Computers & Internet
Drive Being Recognized as Removable Disk
Use EASEUS Data Recovery Wizard to recover the data. You can find the program on the internet..
To format afterwards click Start, click Run and type compmgmt.msc.. In there format your drive..
Mar 10, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Help!Help with external hard drive?
Your disk drive is a delicate instrument, it will react negatively if dropped on the floor.
However what you might try all be it rather radical in this age of micro fine technology is. take a deep breath and sit down. Take the disk drive in your left hand with the edge of the drive that struck the floor facing away, make a fist with your right hand and strike the opposite edge with with almost equal force.
The reason behind this is simply that when you dropped your drive on the floor the heads got jammed either into the disk spool or out side of it,
If you have to pay $300 for disk recovery you cannot be doing much worse than trying this before you have to.
Oct 20, 2008 | Maxtor OneTouch II external hard drive...
Trekstor DataStation maxi m.u 500GB stopped working :'(
This is probably a bad sector on your hard disk. Connect it up and try this:
1. Start > Run > type in cmd then click OK to get a command prompt.
2. Type in chkdsk e: /r (replace e: with the drive letter of your external hard drive).
Jul 29, 2008 | Trekstor Computers & Internet
Trekstor Storage device
I have an answer on how to fix the Trekstor Datastation "Removable Disk" problem.
I also own a Trekstor Datastation 500GB and had the same problem even though it worked for several months then all of a sudden when I tried to hook it up to another computer, it stopped working. It would recognize the USB connection but you could not read the drive as it would say "Removable Disk".
In "Device Manager" it recognizes the drive as Sundata USB2SATA. But what it really should be is "WDC WD50 00AAVS-32ZTB0 USB Device" or something similar to that. For those that are wondering, yes, the hard drive is a Western Digital Hard Drive. Western Digital Caviar to be exact.
Solution: You need to open the cover to the hard drive and reconnect the hard drive to the connector on the board. It's that simple!
It is very loose and this model is not well designed so it can easily come off if you accidentally knock over your hard drive or move it to another location. The hard drive is held in place by screws on a holder where there is room for the screws to slide if the screws are not tight enough.
You'll need a T10 screwdriver bit to remove the cover and a Phillips screwdriver to adjust the hard drive.
NOTE: Doing this will probably voids your warranty but trust me, it works and it's really easy and quick to do. Took me 15 minutes.
May 03, 2008 | Trekstor Datastation maxi t.u SATA 500 GB...
Computer does not recognise Hard Drive
Hey guys. I have an answer on how to fix the Trekstor Datastation "Removable Disk" problem.
Feb 11, 2008 | Trekstor Datastation maxi t.u SATA 500 GB...
Computers & Internet Logo
579 people viewed this question
Top Trekstor Computers & Internet Experts
Marcin
vojvodabudva
ray gallant
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
