Question about Saeco Classico Espresso Machine
Prime it I just cleaned and descaled my Classico and I can't find the instructions on how to prime it.
    Sergeant:
  • Saeco Expert
  • 223 Answers
1. Open the steam knob all the way.
2. Turn on the pump (coffee Button)
3. Turn on the power to the machine.
The machine will start to pump hot water out from the steam wand. When you get a steady flow, your machine has been primed.
For Descaler, Cleaners and Parts for your saeco machine visit
www.CeriniCoffee.com
Posted on May 29, 2008
My machine reads "prime water system
The reply cannot be helpful if any explanation is offered without knowing the category, make and model of the coffee maker.
Basically the water flow in the system is slowed. The machine may need descaling.
If the pump is louder than normal, it is air locked and will need manual priming to let it pump normal.
The manual priming is to inject a few drop of water into the pump (just like a speaker needs a sip of water to continue his speech).
To manually prime the pump you can use a syringe, a Turkey bastor (if you are in USA) or use a hand pump made available with some makes (included as accessory with Saeco, Gaggia espresso machines).
For descaling you may use the link to order a reliable descaler:
http://www.shop.partsguru.com/DSC-6x2-Gurus-Choice-Best-Descaler-Economy-pack-DSC-6x2.htm
Mar 03, 2015 | Coffee Makers & Espresso Machines
Coffee maker will not prime.
E05 means "Water circuit blocked. No water in flow meter or flow meter not turning (jammed)".
Since I got it when I had not descaled for a month, I poured in tripple strength descale in the water container, and restarted the machine 3 times. Noticed that it took in a small gulp of the descale. Waited hours. Restarted 3 times again. Waited... and after about 20 restarts over 2 days. When I almost had given up it primed and was able to do a normal descaling.
I forgot to weigh how many grams of descaled it took in after each restart. That would have been nice for troubleshooting.
Apr 06, 2014 | Saeco Exprelia Automatic Espresso Machine...
My keurig b60 says prime
This can go out by draw out some hot water. However if this happens very often then you need to perform a descale.The brewer should be descaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. Descaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend descaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The descaling process involves using 48 ounces of undiluted white vinegar. Learn how to descale your brewer.
Feb 24, 2012 | Keurig B60 Coffee Maker
It says descale but I don't know how. It won't let any vinegar or water go through.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 08, 2011 | Keurig Platinum B70 Coffee Maker
Machine stoppped working
Try this remove the brew unit and clean the screen on the unit, then insert unit, and open steam/hot water valve to prime. If that does not work then there might be a malfunction with the pump, I am assuming that the machine is only 2 weeks old?
Jun 25, 2009 | Saeco Odea Giro Plus Coffee Maker
No water output even after manual prime
Water line is clogged you will have to open machine and find where the line is clogged.
Mar 23, 2009 | Saeco Vienna SuperAutomatica Coffee...
CANNOT PRIME PUMP AFTER DESCALING - therefore CANNOT MAKE COFFEE
first vinegar is not strong enought proper descaler for expresso machine and in our water container the hole in the bottom put water in the tank with a hoseor turkey juicer our anything you got push water in hole you need to pressurize to forse the pummp to trim itself hope it help fixya pierre
Jul 24, 2008 | Keurig Elite B40 Coffee Maker
"NEED TO PRIME" alert is on. Have run a couple of tanks of water through the wand making hot water, but still says NEED TO PRIME. The pressure on the water seems a little lower than normal. Tried to...
That message indicates that water lines may be dirty. How long ago or how often had you descales your machine? If you have not routinely descaled then the water lines have to be cleaned ( by opening the machine) manually and/or replaced. Another possibility if you have been descaling it regularly, is that a water line may have small crack. And yet another possibility is that the pump may be going bad and/or the flow meter is clogged ( needs cleaning and/.or replacement). Best suggestion at this time is to have an Authorized SAECO Service Center check your machine. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Jun 11, 2008 | Starbucks Saeco Italia Digital Barista...
Steam jet in Saeco Classico
Try Descaling your machine. A lot of times calcium will form on the inside of the boilers and on the heating elements in espresso machines causing heat transfer issue and clogged lines.
If the heating element cannot transfer enough heat fast enough then your steam will run out.
If you need a good descaler or descaling instruction visit www.CeriniCoffee.com
Dec 22, 2007 | Saeco Classico Espresso Machine
Saeco Classico Espresso Machine Logo
491 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
