Question about Pioneer Televison & Video
Have just purchased DVR-LX60D. Owning a DVD-696, am familiar with the setup of activating the HDMI output and the front panel of the DVR is showing that HDMI output is active. Fine so far. However, there is no HDMI output feeding through to my Pioneer plasma. Have used different HDMI cables, which both work fine with the DVD-696. Am I missing something here or is the HDMI output on the DVR just bust.
    Genius:
  • 1,224 Answers
Sometimes with certain sets you have too on remote use the input for video 1 video 2 video 3
with hdmi certain tvs require one of the videos to be on to watch in high quality
Posted on May 28, 2008
I have an Element EDHFT12 hdmi player and can not get it to play in hdmi. It shows no signal in hdmi
Make sure the audio output in your system setup, is set to HDMI output. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 28, 2013 | Element Skateboards Element EDHFT12 DVD...
How do I get my dvr-lx60d to play all regions ?
You don't list the manufacturer so try this link. Put in your manufacturer and model number. You never know there may be a fix somewhere.
Hope this helps.
http://www.videohelp.com/dvd
Jan 20, 2011 | Televison & Video
Yamaha rx-365 reciever not showing all speakers
I,m not familiar with the Yamaha but most receivers are set up the same way. In your setup menu are the speakers marked on in the display?. Your DVR needs to be transmitting in 5.1 to start with. If this is the case then make sure you select the correct audio function on the receiver.
Mar 04, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
Apr 05, 2009 | Sharp Televison & Video
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to reset the default value for the toshiba sd 6100 dvd player
If you want HDMI 'Auto' mode (the factory default), you need a combination of selecting the proper output mode (use the remote's 'Progressive' button to toggle between the four output modes: HDMI, RCA VGA, component video out and s-video. Once you're in HDMI mode (the led's on the front of the box are a dead give-away!), then you can press the front panel 'HDMI Select' button to move through the five available HDMI settings: 480P, 720P, 1080i, 1080P and 'Auto'. You're in 'Auto' mode when all four led's are lit.
Jan 25, 2009 | Toshiba SD6100 DVD Player
No dish network sound through denon 1609 receiver
check the setting for the HDMI connection at the Denon you may have to assign the HDMI audio setting also on the front of the Denon while in the DVR mode press the input mode button on the front of the Denon to select auto and if that doesn;t give you sound you will have to connect a cable from the DVR optical.coaxial or analog audio output to the Denon and setup for that type of audio connection
Jan 19, 2009 | Denon AVR588 Receiver
I have just purchased a pioneer dvr-lx60d dvd recorder with a 250 gig hard drive built in . i would like to know how to back up my dvd collection on to the hard drive .?? can you help. the player wont let...
i have played a dvd movie in my laptop computer(Toshiba dvd player) it has played
but when i try to ply it in my desktop computer(LG dvd player) the disk is not opening do you have a soft ware or suggestion to solve this problem
Jul 13, 2008 | Pioneer Televison & Video
Re; my Vizio P42HDTV... when I hook up my DVD player to the set via HDMI cable and then set the input mode on the set to HDMI, all I have is a black screen? My DVD player lights up showing a good...
First, try another set of connections, S-Video or Component to make sure you have signal. That narrows your problem range just to the HDMI links,
Next, check for an ouput setup on the DVD to make sure you are feeding the HDMI output.
Then, Check the TV setup to make sure the input is turned on, Sometimes you have to make an input or output active before you can use it. This is a power, circuitry and noise related design issue.
Finally, try another HDMI cable.
Feb 15, 2008 | Televison & Video
Pioneer 5070HD, Onkyo TX-SR605S receiver and Cyberhome DVR 1500 connection
you may have fixed your dvr1500 by now but i just came across your signal problem today,so if it is still not working try putting a cable from the yellow video out of your 1500 to tv video in ,switch to this input on your tv and you should get a picture.after this is done set output on 1500 to composite and put into cbl/sat on amp,put hdmi cable from tv into hd out on amp, go to setup input assignment ,click on this to get monitor out,click again you get hdmi mntr flick right to switch on,put your tv to hdmi and you should have a picture.
hope this helped.
cable guy.
Sep 17, 2007 | Cyberhome CH-DVR1500 DVD Recorder
Televison & Video Logo
130 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
