Question about Samsung (SP0822N) 80 GB Hard Drive
I formatted my hd making it slave in other system: now i m placing it back on my system then it is saying Primary IDE masterNONE; Primary IDE Slave SP0822N Then comes NTLDR MISSING
    Brigadier General:
  • 10,406 Answers
> formatted my HD
This deleted 99% of the files on the disk-drive.
> Primary IDE Master: NONE
> Primary IDE Slave: SP0822N
Good. Your motherboard has detected ONE disk-drive.
Do you have just one connected disk-drive on your PRIMARY channel, or do you have two connected disk-drives (via the 2 connectors on the one ribbon-cable on the PRIMARY channel) ?
If you have two drives connected via one ribbon-cable, you MUST set the 'master/slave/cable-select' jumpers on BOTH disk-drives, to identify which of the two will be the 'master' and which will be the 'slave'.
Also, check that the 'second' disk-drive is getting electrical power.
> NTLDR MISSING
Like I said, you deleted 99% of the files, including the 'NTLDR' file.
Your computer is trying to "boot" from the 1% of the files that still exist on the disk-drive, but cannot find the now-deleted file.
Perfectly normal, given that you have formatted the disk.
Posted on Oct 06, 2010
Today I installed SATA HDD at red SATA port 1 . But in BIOS, it shows Primary IDE master not detected....Primary IDE slave not detected....Third IDE master detected..I wanna know why my HDD is not detected...
there is no diffrence between primary & third ide hdd ,if you install nay booteble hdd in master so system try to from that frist . boot sequence of motherboard is try to boot from primary master first then Primary slave then secondary master and then master secondary ..................,
Jun 12, 2011 | ASUS P5GC-MX/1333 Motherboard
Trying to install Windows XP SP1 onto HD with this Motherboard. System will not boot from HD to start install.
Make sure your IDE hard disk drive is connected to IDE1 port and that the data cable is fully connected. Also check the jumper on the IDE drive. If you are using only one IDE hard disk drive set the jumper on the drive as a Master without a slave. If you are running two IDE hard disk drives set the primary drive's jumper as a Master with a slave. Set your second IDE disk drive's jumper as a slave. The master drive should be connected at the end of the data cable and the slave drive should be connected to the next data connector. Than check your bios settings. Power on the system and press the Delete key every 2 seconds until the bios menu loads. See page 3-1 in your manual. If you need the manual for the NF8-V MB click on the link provided below and download it;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF8-V&fMTYPE=Socket+754
You'll also need the program Adobe reader to view the manual. Adobe reader is a free download; http://www.adobe.com/products/reader/
Once you’re in the bios go to page 3-4, Standard CMOS Features.
Follow the instruction listed for IDE HDD Auto-Detection. Your HDD should be listed here. Than see page 3-7 in the manual. Open Advanced BIOS Features. A normal boot menu for the Abit would read;
First boot device Floppy disk drive (If one is connected). 2nd boot device should be (CD-ROM/DVD-ROM). Third boot device should list your primary hard disk drive's (Model number). Load your windows CD into your CD-ROM drive.
Once the settings above are set, press the F10 key to save your changes and exit the bios. Your system will auto restart. Windows should begin to load.
Cheers!
Mike
Nov 18, 2009 | Abit NF8-V Motherboard
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
How do I add a second HD
Turn the machine off
Open the case
Look to see if there are IDE connector (Wide Flat cable with a connector usually grey)
If this is not present look for a SATA connector usually a small red or blue wire similar to a cat5e network cable
Scew your HDD in place in the rack connect the cable either IDE or SATA
If you have an IDE drive look for a 4 pin female connector from the power supply
If you have a SATA drive look for the connector from the power supply
Once all is connected then reboot you computer typically your bios should auto detect it.
Let me know what happens from here
Sep 19, 2009 | Dell Precision T3400 375W 32bit Computer...
HOW DO YOU INSTALL A SECOND OS ON A SLAVE DRIVE. I AM RUNNING WINDOWS XP HOME EDITION. I WANT TO INSTALL WINDOWS 98 SECOND EDITION ON A SLAVE DRIVE DISC. SOME PROGRAMS I HAVE WILL NOT WORK ON XP.
You cannot install 98 directly on your system slave drive, but there is a way to install it.
1) disconnect your primary drive
2) make your slave drive as primary.
3) install 98
4) Connect your actual primary drive again and start your system
XP records your mac id of your motherboard and 98 does not records, the other way is, you can install both the OPS on your one primary drive by creating different partitions, you will need to full format your drive first.
1) Full format your primary drive.
2) Create partitions.
3) Install 98.
4) Install XP in different drive of your same hard disk
You will be able to see both your OPS when you start your system.
Sep 18, 2009 | Computers & Internet
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Feb 26, 2009 | Computers & Internet
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Slave drive
if you do know how to install hardrives to your computer, this will be fairly simple.
check the back of your hard drive and look for the pins. there will be a connector there that will indicate if the hard drive is a master or slave. put the jumper into slave.
after doing that. connect your hard drive to the ide cable. since it is a slave hard drive, put it in the 2ndary ide slot on that cable. you can either do this on the primary ide cable or the 2ndary ide cable.
restart your computer.
done
Mar 22, 2008 | Maxtor Hard Drive
Hard drive not detected
Rickyrudy, I suspect one of the following may work: -The problem drive is set as the slave on the secondary IDE channel. If it?s the only drive change it to the master. -Try checking the drive setup setting in the BIOS, make sure both drives are set to auto detect in the BIOS. If this works don?t forget to try setting the unused drive setting to none to speed up the boot process. -If you are using jumpers to define the master and slave double check the settings against the chart on the drive in question. -If you?re using cable select to define master/slave drives try using the jumpers instead. Let us know if this works and please don?t forget to rate this posting.
Feb 25, 2007 | Tekram P6 B40-A4X Motherboard
Would a SCSI disk and a IDE disk work together?
This solution works on WIN98 and I don?t see a reason why it wont work on you If there is something that you were missing you might want to check with anther expert. This solution is a little complex so I hope ill be able to explain it well enough: 1. Make a boot disk so u can format and install windows. 2. Define the new HD as MASTER and hook it up to "primary IDE" 3. Disconnect the SCSI and pull the board out. 4. Reset the comp from the boot disk u made (HD is connected) 5. Get in "bios settings" and make sure that the new HD is defined as "primary drive" In the 1st IDE 6. Now, perform a FDisk on the new HD, define partitions, do a reset and format the HD Install the operating system you wish to have, make sure it works well. 7. install the SCSI board and its HD make anther reset. 8. now the comp is supposed to make boot and recognize the SCSI, it is possible that you will need to define your system configurations but for that, regretfully, I cannot guide you Although this is not necessarily have to happen. Good luck
Feb 23, 2006 | Cybertron Intel Pentium 4 2.66GHz Serial...
Samsung (SP0822N) 80 GB Hard Drive Logo
133 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
