Question about KitchenAid Microwave Ovens
The "auto Sensor" on my kitchenaid KCMS185JSS microwave does not work, but everything else does.
  • KitchenAid Master
  • 9,086 Answers
That's probably a failed humidity sensor, and repairing that is a pretty easy do it yourself job.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 30, 2008
I have a KitchenAid microwave model # KCMS185JSS. Everything works except it stopped heating up anything. Is there a separate fuse for the microwave heating? Where is it? can I fix this myself?
Sounds like the microwave's magnet tron (join two words together this page will not allow the correct word) the has gone down. They only last a short time depending on use. Not a great job to do on your own (if you do not know what you are doing) the part cost about 35pounds so most cheap microwaves are not worth repairing, if it is an expensive one it may be worth paying for the repair.
May 26, 2014 | KitchenAid KCMS185J Microwave Oven
Microwave popcorn
Could be your KitchenAid microwave only works with bagged popcorn.
Jan 22, 2014 | KitchenAid Microwave Ovens
Kitchenaid KCMS185JSS
The problem is one of the door switches has failed, usually caused by food partical buildup, switch must be replaced for normal operation.
Mar 12, 2012 | KitchenAid Microwave Ovens
My KitchenAid microwave oven's model number is KCMS185JSS-4. Manufacture date is July 2005. It's been working fine until today, with an occasional glitch in the digital readout... sometimes the letters...
Either your high voltage rectifier or magnetron (or both) has failed.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
Sep 30, 2010 | KitchenAid Microwave Ovens
Kitchenaid KCMS185JSS-3 microwave - no power
Well your gonna have to take it down a take apart the microwave more than likely. Probably have a shorted HV diode,magnetron, shorted winding in HV transformer.burnt or frayed HV wire insulation
Sep 03, 2009 | KitchenAid KCMS185J Microwave Oven
My KCMS185JSS-5 microwave has no heat. It seems to be running, the light and turn table all work, but it won't heat water.
hi..Your micro hood is "shot".so it is not working properly.
The food may not be heating,but the electrical and the walls
of the unit might heat.This may cause sparking and melting
of the interior of the unit.
check it out..
thank u..
kindly rate my response..
Jun 15, 2009 | KitchenAid Microwave Ovens
Microwave partially heats
its time repair will cost more than a new one
Dec 01, 2008 | KitchenAid KCMS145J Microwave Oven
KitchenAid KCMS185JSS1 Door Removal
On most new MW ovens, the door will lift off the hinges once the top grille is removed. There are two screws on the top that hold the grille in place.
Mar 12, 2008 | KitchenAid KCMS145J Microwave Oven
I've replaced the computer on my kitchenaid kems378gss3 oven/microwave combo. I need the "codes" to key in on the keypad - to make the microwave actually "cook: things. Everything else works...
If you don't have the owner's manual you can download it here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%204452300.pdf
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20(Micro)%20-%204452614.pdf
Some units will not allow time programming if the door is open - or if the microwave thinks it is due to a bad door switch or door switch mount, etc.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Mar 07, 2008 | Microwave Ovens
Microwave Ovens Logo
99 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
