Question about Delta & Single Handle Shower Faucet
Wateris not hot enough, need to know how to adjust scauldgard on faucetto getmore hot water, and less cold.
    Problem Solver:
  • 11 Answers
Assuming that you have sufficient hot water, you need to adjust the Scald-Guard valve. It's usually quite easy to do. The intent is to limit the amount of hot water that can be fed to to shower head or tub spout. On the 1300/1400 series faucents there is a disk behind the faucet knob/lever called the rotational limit stop. Remove the knob/lever, either by popping the cover off the knob and removing the screw with a Philips head screw driver, or removing the handle with an allen wrench. Next adjust the rotational limit stop disk clockwise to increase the limit on hot water flow. Delta claims each tooth you click past clockwise will increase the maximum water temperature by 6 degrees F.
Delta has a great FAQ on their web site. As of Jan 30, 2011, this link is valid:
http://www.deltafaucet.com/customersupport/faq/Water+Temperature/
If the rotational limit stop disk is already turned to the maximum point (clockwise), then you may have a hot water flow problem (either with the cartridge or to or in the manifold). The cartridges require a little more know-how to replace. You'll need to shut off the main water valve prior to removing the old cartridge. There are a couple of places that detail how to replace and/or service the cartridges, including a short video on youtube. I can post more details on this if you find you need to replace the cartridge.
Posted on Jan 30, 2011
    Sergeant:
  • 268 Answers
First check at sink that you even have hot water. (I had to show friend that 1 of his 2 heat elements in water heater had gone bad. After replacing it then mega hot water).
I am not sure which delta model you have but some of them have a little lever behind plate that u can adjust for hotter water.
If you are not mechanically inclined then don't. Ive seen some cause more problems trying to do-it-urself.
Posted on Oct 06, 2010
What does "EFO" stand for? It keeps blinking on my washer
EF0
displays due to washer over-sudsing or due to washer not filling with
Hot
water.
Causes for washer over-sudsing
Not using High Efficiency (HE) detergent.
Too much detergent was added.
Using too much 2X or 3X HE detergent
Solutions for over-sudsing
Always use HE detergent in an HE washer. It is formulated to be a low-sudsing detergent and made especially for HE washers.
Be sure to use the correct amount of detergent. HE washers require only a small amount of detergent.
Note
: This amount may need to be adjusted for water hardness, load size, and soil level.
If using a 2X or 3X concentrated HE detergent, much less detergent is needed. If suds are seen, reduce the amount used.
If using a water softener, less detergent.
Solutions for Hot water not entering the machine are
Make sure both Hot to Cold water hoses are connected properly at the faucets and at the washer.
Fill hoses are usually color coded, blue for cold and red for hot.
Verify that the hot water inlet hose is connected to the hot water faucet.
Verify that the cold water inlet hose is connected to the cold water faucet.
Verify that the hot water inlet hose is connected to the back of the washer into the hot water inlet port.
The inlet port is usually labeled with (H) or (HOT).
Verify that the cold water inlet hose is connected to the back of the washer into the cold water inlet port. This inlet port is usually labeled with (C) or(COLD).
hope this was some help,all the best.
Dec 16, 2016 | Washing Machines
Unit stiebel Tempra 24Hot water is running through house but cold water pipe is getting hot. Hot water pipe is not getting hot. When cold water connection is removed and water is turned on hot water is...
follow this steps and fix it. God bless you
If there is no hot water, first push the reset button on the high-temperature cutoff; test the thermostat and replace if faulty (see below). Test the heating elements and replace if faulty (see below).
If there is not enough hot water, adjust the thermostat settings. As needed, reset, test and replace thermostats and heating elements if faulty.
If the water is too hot, adjust the thermostat settings and reset. Test and replace the thermostat or high-limit cutoff (see below).
An electric water heater is a 240-volt appliance that can deliver a fatal shock. Always turn off power to the heater at the electrical panel 585dc480-4881-44a8-afda-7267c0f3de26.jpgbefore beginning work, and verify that power has been shut off. Make sure others in the house know not to restore electricity prematurely. If you have any doubt as to whether electricity has been turned off, seek professional assistance.
Oct 02, 2013 | Stiebel Eltron TEMPRA 24 Tankless Water...
No hot water
need to adjust anti-scold when unit shipped is set for cold if u have install paperwork that has info on how to adjust if not remove handle and on valve stem will see blue and red plastic clips slid them forward and adjust till hot water is adjusted to liking
Jul 25, 2010 | Moen & One Handle Tub & Shower Faucet
The washer is set on cold/cold. The hot water faucet is turned off. The washer should not be asking for hot water because it is set to cold/cold. It asks for and received cold water. At some point...
Newer machines know the water temperature. It will mix hot water even on a cold setting if the incoming water is too cold. Detergents need a temperature of at least 60 to activate.This will only happen in the winter usually.
Feb 24, 2010 | Washing Machines
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
I cannot get the water hot enough and maitain the water pressure. The groved thing in center (after removing all hardware and sace plate) is missing the red/blue clips. I am a complete novice and don't...
pegasus is a home depot product u need to adjust ur anti scald setting the valve is shipped in cold position it should have a red and blue plastic clips that go over the grooved thing call pegasus customer service at 1888 328-2383 they should be able to assist u with ur problem if u need parts or how to adjust the anti scald system
Jan 03, 2010 | Union Pegasus F1228100PBV Series 5000...
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
TB3 Brewer is brewing weak tea - how do I adjust?
Hello. Yes, however, you would need to adjust the brewing cycle time to make up for the lost bypass water in order to get the same container level. In other words, the cold water part of the brew cycle is separate from the hot water part of the cycle, if you put in less cold water, and want to keep you container filling to its current level, you would need to increase the hot part of the brew cycle to make up for it, other wise it will brew less into your normal container. If you go to:
http://www.bunnomatic.com/
find your unit by model/type, you should be able to get a owners/installation manual, this will tell how to do it, or call the manufacture.
Hope that helps, and thank you.
Dec 22, 2008 | Bunn TB3Q, 29" Trunk, 3 Gallon Tea Brewer
Leak in washing machine
can you tell where the water is hitting the belt from is it in the middle of the wash tub or from the outside of the wash tub please let me know if its from the middle of the tub its probably the seal that keeps the agitator from leaking, and if its from the side the in lines from the water spicket or the valve that controls hot and cold in the machine could be leaking, please look closely and try to see where the wateris dripping down from. thank you, then let me know
Dec 21, 2007 | Washing Machines
Delta & Single Handle Shower Faucet  Logo
1,681 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
