Question about Magic Chef Ovens
I have a Magic Chef Gas Range Model 37311. The oven door will not open. The latch for the oven that locks the door for the cleaning cycle is in the open position. What can I do to get the oven door to open
  • rick_nosek Oct 06, 2010
    The oven has cooled down and the oven door latch has not released. The door will open approx. 2 inches. For some reason the latch has not fully retracted.
First thing to do is shut off the circuit breaker for 15 minutes. This should reset the oven and allow you to open it up again. If it still won't open after shutting off the circuit breakers for 15 minutes then run the self cleaning function again and see if it opens after it completes the cycle. If it still don't open then the main relay board is not sending power to the lock. You can jump 120vac to the main wire and you'll be able to see if the motor turns. If so, the problem is in the relay board. If not, the problem is in the door latch.
Posted on Oct 06, 2010
  • 503 Answers
Self cleaning ovens on many brands lock the oven door when the self cleaning cycle has started. This is because the oven heats up to a very high temp to burn off the residue on the bottom of the oven and the locking of the oven is a safety device. Once the oven has completed the cycle and the oven has cooled down some the lock will release.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
I was baking dinner and the kids walked by and looked oven door. Now i can't get it to open. Its a magic chef/ self cleaning oven
Need to know the exact model to be sure, but usually there is a button that says "lock" or has a padlock icon that you press and hold for a minute or so to lock and unlock.
Also, if they started a cleaning cycle, that will lock the door, too.
Apr 21, 2011 | Ovens
Hello, I have an older model magic chef gas stove/oven. It has a self cleaning oven option that I tried using. It didn't work, but now the lock light on the stove is still lit up as if it's still in...
most likely your latch assembly on unit has failed.... try resetting breaker to unit and make sure latch is not half opened or half closed while breaker is off... after checking reset breaker and see if this helps if not then probley going to need a new latch assembly and or possibly the control on unit... self clean on all ranges and ovens are trouble in my opinion they get entirely to hot and usually are ran to long... i know you said yours didn't work leads me to believe there may have already been damage to one of the pcb relays on the control but try the above first and you may luck out.... good luck to you
Jan 13, 2011 | Magic Chef Ovens
Magic Chef Range - oven door won't open Gas Oven with stove top 1980's Model 64DY-3CKXW all dials/no electronic displays There are two dials for the oven One that controls the temperature and another that...
If a selfclean oven door lock fails to open after the self clean cycle and sufficient cooling time has elapsed (approximately 1 hour), there are several things you can try.
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Most self cleaning ranges today use one of 3 different types of door locking systems. One design is solenoid driven, another is heat activated and the last, motorized.
  • A solenoid controlled system can be identified by the lever that must be set to lock the door, plus a loud buzzing or clunking noise heard when locking or unlocking the door.
  • The heat sensitive lock mechanism also has a locking lever but makes no noises. It instead utilizes a coiled spring to slowly lock the door as the oven heats.
  • The motorized design has no lever to move, the motor locks the door by itself when the range is set for self clean. The motor may have made an audible whining or ratcheting sound when in use.
A motorized or heat sensitive style lock will usually be located beneath the cook top on free standing ranges. The cook top would usually need to be lifted to access the locking mechanism. On built in ovens, the oven must usually be removed from its enclosure (or at least partially) in order to remove the top panel to gain access to the locking mechanism. On some built in oven models, the lock assembly may be able to be accessed by removing the control console.
sc-lock-geheatsensitive.gifOn the heat sensitive style (illustrated), there are no electrical parts used to operate the lock which could fail, so the whole mechanism will usually need to be replaced if not operational.
With the motorized lock mechanism, a volt/ohm meter is required to try to determine why the locking motor will not operate. The failure could be in the motor itself or the power supply leading to it, including a door activated and/or console mounted switch and switches on the latch mechanism itself.
On solenoid activated designs, the solenoid coil is a common failure point which is often mounted on the back of the range. On many of these models, the lock mechanism can be accessed by removing the rear panel of the appliance. Some models such as built-in ovens or drop-in/slide-in ranges, may have the mechanism mounted towards the front, under the top.
sc-lock-gelocksolenoid.anim.gifFailure of a solenoid style lock is most often caused by a bad solenoid. Once the lock is located, the solenoid coil can be checked for continuity. Some latch assemblies also have micro switches in the power supply that will need to be checked for faults too.
Be certain to unplug or remove power from the range before undertaking any repairs yourself and follow all standard safety precautions.
usually if you are unable to open it after all these tests then you would resort to manually opening the door by getting a piece of wire and slip it where the latch mechanism is and prying to the left this is a last means resort so try these other ways and get back to me with any further questions that you may have and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Dec 18, 2010 | Magic Chef Ovens
My Magic Chef gas oven is giving me a readout of F9
Hello there:
this error code that you have is refering to the door latch/switch and the latch switch wiring assy.
F9 Door lock circuit Check wiring and test operation of door lock switch if the circuit is not working when tested it will have to be repaired or replaced but if it has found to be good than the door switch may be faulty and needs to be replaced and please let me know how this is going so i can help you out if needed ok
Best regards Michael
Feb 24, 2010 | Magic Chef Ovens
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
The oven door must be closed and all controls set correctly for the cycle to work properly.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
If your model has a latch, latch the door.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
On models without a door latch, the door
locks automatically. The display will show
the clean time remaining. It will not be
possible to open the oven door until the
temperature drops below the lock
temperature and the LOCKED DOOR
light goes off.
The oven shuts off automatically when the
clean cycle is complete.
When the LOCKED DOOR light is off,
slide the latch handle to the left as far
as it will go and open the door. If your
range does not have a latch, the door
will unlock automatically.
The words LOCK DOOR will flash and
the oven control will signal if you set
the clean cycle and forget to close the
oven door or forget to latch the door
on models with a latch.
To stop a clean cycle, touch the Clear/Off
pad. When the LOCKED DOOR light goes
off, indicating the oven has cooled below
the locking temperature, unlatch the door
(on models with a latch) and open the door
How to Delay the Start of Cleaning
Make sure the clock shows the correct time
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
start time you can set will appear in the
display.
Using the number pads, enter the time
of day you want the clean cycle
to start.
locks automatically. The display will show the
start time. It will not be possible to open the
oven door until the temperature drops below
the lock temperature and the LOCKED DOOR
light goes off.
The words LOCK DOOR will flash and the
oven control will signal if you set the clean
cycle and forget to close the oven door or
forget to latch the door on models with
a latch.
pad
(on models with a latch) and open the door.
After a Clean Cycle
You may notice some white ash in the oven.
Wipe it up with a damp cloth after the
oven cools.
If white spots remain, remove them with a
soap-filled scouring pad and rinse thoroughly
with a vinegar and water mixture.
These deposits are usually a salt residue
that cannot be removed by the clean cycle.
If the oven is not clean after one clean cycle,
repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to
unlock.
While the oven is self-cleaning, you can
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
small amount of vegetable oil or cooking oil
to a paper towel and wipe the edges of the
oven shelves with the paper towel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Cleaning over but lock light will not goff and i can not open my oven
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
May 20, 2009 | GE JKP15 Electric Single Oven
Door locked after shutting down cleaning cycle earlier than
May 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
LED says "Locked" can't turn on stove. How do you unlock it?
May 16, 2009 | GE Profile JTP18 Electric Single Oven
Self-cleaning oven door won't open
May 15, 2009 | Ovens
I accidently pressed self clean instead of boil on my oven
Hi
*On -some- Frigidaire built ranges, the switch is located behind the right hand side panel and activated by the right hand door hinge. On this model, the side panel may need to be removed to access a malfunctioning door switch.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
117 people viewed this question
Top Magic Chef Ovens Experts
Sal De
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
