Question about Canon Optura 60 Mini DV Digital Camcorder
No power If i conect the camcorder to an outlet power , it work perfecttly, but if i let the camera to run on battery it's sutting down automatically. what might be the problem?
  • 60 Answers
Check your battery. It seems its damaged. Check with a new battery, this bug should br fixed. :)
Posted on May 28, 2008
Do you need a working battery to run camcorder off ac power adapter? I havent used camera in 2 years and just bought replaceable power adapter and wont charge battery or work off outlet at all..camera was...
You do not need a battery to run the camcorder off ac power supply. It is one or the other. The only time that both will be used is when you are charging the battery on the camcorder with the power off.
Hope this helps.
www.austintelstarservices.com
Jul 21, 2011 | Sony DCR-HC52E Mini DV Camcorder
SIR/MAM. WHEN EVER I USE MY CAMCORDER GR-DVX9
There is often a small battery inside the unit or accessed from outside that holds the memory that the device was last set. Yours is defaulting to maximum zoom. And in fact it does.
Built-in Clock's Rechargeable Lithium Battery
To store the date/time in memory, the clock's rechargeable
lithium battery is integrated in the camcorder. While the
camcorder is connected to an AC outlet using the AC
Power Adapter/Charger, or while the battery pack attached
to the camcorder continues to supply power, the clock's
rechargeable lithium battery is always charged. However,
if the camcorder is not used for approx. 3 months, the
clock's lithium battery will become discharged and the
date/time stored in memory will be lost. When this occurs,
first connect the camcorder to an AC outlet using the AC
Power Adapter/Charger for over 24 hours to charge the
clock's rechargeable lithium battery. Then perform the
date/time setting before using the camcorder.
Note that the camcorder can be used without setting the
date/time.
Your manual in English. You can use a smartphone with Google translate and the camera feature to read what is shown on the camera in Japanese and change the operating language to English.
http://www.videocamera-manual.com/manuals/jvc/JVC_GR-DVX9_MiniDV.pdf
Nov 03, 2017 | JVC GR-DVX9 Mini DV Digital Camcorder
Sony DCR- DVD108 switches off automatically while recording
Follow this procedure to troubleshoot if the camcorder turns off by itself.
  1. Remove the battery from the camcorder.
  2. Connect the AC power adapter to the camcorder.
  3. Plug the AC power adapter into a working electrical outlet.
  4. Attempt to turn on the camcorder.
  5. Reset the camcorder back to factory settings.
  6. NOTES:
    • If the camcorder does not operate using the AC adapter, service may be required .
    • If the camcorder does operate using the AC adapter, proceed with the steps below to troubleshoot the battery.
  7. Ensure the battery has been fully charged.
  8. Ensure the battery is properly inserted into the camcorder.
  9. Remove the AC power adapter from the camcorder.
  10. Attempt to turn on the camcorder.
  11. NOTES:
    • If the camcorder does not turn on, then the battery may need to be replaced.
    • If the problem persists using a different battery, service may be required .
Aug 13, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
PUEDO UTILIZAR MI CAMARA DE VIDEO SONY DCR-SR 30 COMO WEB CAM PARA MI ORDENADOR PORTATIL, ASUS?
Si puedo utilizar su camara por eso. pero, la directiones estan en engles.
Primero es para S- Video
La orta mas pavajo estan directiones para USB Streaming
How to use a Sony® camcorder as a Web cam with a composite video or S-video connection.
Solution
sp.gif sp.gif IMPORTANT: The computer must have a composite Video or S-Video input jack [FIG. 1]and compatible webcam software installed. Some computers may require a video capture card and/or sound board.
NOTE: This procedure cannot be performed when using the battery of the camcorder as a power source. If the camcorder is turned on, but not recording or playing a tape, it will automatically turn off after 5 minutes to conserve battery power. In addition, please be advised that this procedure may not work for all Sony camcorder models even when using the AC power adapter. Some models have an automatic demonstration mode that will activate after 5 minutes if the camera is turned on but not recording or playing a tape.
  1. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  2. Connect a composite video cable or S-Video cable to the VIDEO or S-VIDEO jack on the camcorder. NOTES:
    • Sony camcorders usually come packaged with composite Audio/Video cables; S-Video cables are sold separately.
    • To purchase either of these cables, check with your local electronics dealer or visit the Sony® Parts and Accessories Sales Web site or by call (800) 488-7669.
  3. Connect the other end of the composite video cable or S-Video cable to the VIDEO IN or S-VIDEO IN jack on the computer.
  4. Turn on the camera by moving the POWER switch to the CAMERA position.
  5. Remove the cassette tape from the camcorder.
  6. Turn on the computer.
  7. Start the webcam application to be used. NOTE: Contact the software manufacturer for assistance with setting up or using the webcam software.
[[Direct Accessories and Parts Center, DAPC]] How to use a Sony® camcorder as a webcam using USB Streaming. Solution
  • Not all Sony® camcorders are equipped with a USB Streaming port. For compatibility information, or if you require further assistance with any of the steps below, consult the instruction manual of your camcorder. A copy of the camcorder instruction manual is available in the Manuals/Specs/Warranty section of the Sony® eSupport Web site
  • The USB Streaming driver is not compatible with the Apple® Mac OS® operating system.
  • The computer should have a factory installed USB port and compatible webcam software, such as Microsoft® NetMeeting®.
  1. Install the USB Streaming driver on the computer from the CD provided with the camcorder.
  2. Restart the computer.
  3. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  4. Connect the supplied USB cable to the camcorder and computer.
  5. Turn on the camcorder by moving the POWER switch to the CAMERA position.
  6. In the camcorder menu, set the USB STREAMING option to ON .
  7. On the computer, start the webcam software.
Apr 06, 2009 | Sony DCR-SR30E Camcorder
DCR-SR42 Camcorder does not power up
I think AC power charger of your camera got defective first and later on battery lost its charge so no power for camera now to power up.
Try to borrow same charged battery from friend. neighbors etc and test your camera.
If camera power up, it is sure that charger has gone and you need new one.
let me know in that case to guide you further.
Oct 05, 2008 | Sony Handycam DCR-SR42 Camcorder
MY CAMERA WILL NOT TURN ON
Try connecting your camera to your power outlet, then turn on the unit.
If camcorder turns on when connected to the power outlet, you may replace your battery.
However, if unit is still not working, consider sending your camcorder to Samsung Service Center.
Dec 26, 2007 | Samsung SCDC163 Camcorder
Battery charging problem.
hi, its clear that the battery is gone .
replace the battery with a new one its gonna work fine.
when you plug the charging chord into the camera,the camera shuts down because the battery is gone.the battery has lost the ability to charge,so to protect your handycam from any hazard the camera shuts off.
take care bye & have a nice day.
Dec 13, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
Shuts off
It sounds like the battery is flat - I realise that you've probably already thought of this, and charged up the battery, however batteries have a finite life and number of charge cycles they can go through, and may appear to be fully charge (According to the charger, at any rate), but they are unable to hold any decent charge. My suggestion would be to head down to the local camera shop, and ask if you can try a new battery in-store.
Sep 14, 2007 | Quasar VM-L450 Camcorder
WONT READ THE MINI DVD DISK THAT I PUT IN
it is becuse the camcorder will automatically shutoff if there is no use of it in a certain time period, this helps save batterie time and turn on the camcorder and wait for ur videos to loafd then sut it off
Aug 19, 2007 | Canon DC210 DVD Camcorder
Cassette am
To unload the videocassette from the cassette compartment, the camcorder needs to be connected to a power source (either an electrical outlet or a charged battery). Please refer to the following instructions. Connect the camcorder to the power source or insert the fully charged battery pack, and then slide the EJECT switch to open the cassette compartment cover. The cassette compartment cover will open, and then the compartment will open automatically.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Canon Optura 60 Mini DV Digital Camcorder Logo
77 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
