Question about Acer Computers & Internet
I have an acer net book - 2 years old. It will no longer charge / recognise the power cable. Any advice welcome - thanks
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Posted on Oct 06, 2010
Acer aspire 6920 11.1 v battery work but 14.8 v wont charge why is this
Check model numbers, I had this problem with apple, to of the same laptops two differnt batteries
Apr 03, 2017 | Acer Aspire 6920 Notebook PC
2 x 500Gb HDD's no longer recognised. IDE not SATA. They were recognised until 3 days ago. I swapped one for my 85Gb HDD that contained my operating system (XP) and neither has been recognised since. 80Gb...
Good day!
Did you try to use another IDE cables?If not,please find some IDEs there and try it.You can also use another PC and try the said HDD just to recognize it.or try to swap it in the IDE1. See if its work.
mastergani
Jul 06, 2010 | Western Digital My Book Essential Edition...
Should I bother trying to fix this laptop or is it time for new?
it would be cheaper to get a net book and an external hard drive you can get a good one for about 200$ and an external drive enclosure for like 20 and a used hard drive for like 30-40
Dec 17, 2009 | Acer Aspire 3000 Notebook
DVI output problems with Acer Veriton M464
If you are comfortable with opening the case, you can try this: Unplug the power supply, make sure are constantly grounded (touching metal)remove add-in video card. Locate the "Clear CMOS" jumper (usually 3 pins in a row with two shorted via a plastic jumper). Remove the jumper and short the other 2 pins (if originally pins 1-2 with 3 open, short 2-3 with 1 open) for a few seconds. Then replace on original pins. Plug monitor into motherboard video port and power on. If it works, you can leave as is or try to re-install your video card following the same precautions when opening the case and probably changing BIOS settings to utilize the add-on card.
Sep 12, 2009 | Acer Computers & Internet
Net work cable unplug
Hi.
The fact that the router has no lights lit, (not even the power light?) this means the router is burned out or defective. You did the right thing in trying it on a different power outlet. The router is definitely dead and the only solution here is for the library to get a new one.
Jul 31, 2008 | D-Link Air DWL 610 802.11b (DWL-610)...
Laptop turns off when power cable is taken out even though battery is 100% charged
sounds like the system has a problem taking power from the battery, but is able to send power to it for charging purposes, or the battery indicates a ful charge, when in reality it is bad.
If there's a way to borrow a known good battery for testing purposes, you might narrow it down.
I'm sorry, I'd need to see this one to offer any further advice.
Good luck
Nov 25, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 5633WLMi Laptop
unplug everything that isn't necessary to run the laptop ie, external mouse, battery, etc. Then plug the ac adapter in, making sure the switch for 110/220 is appropriate for your region. Now, does the machine turn on? PLease respond with the answer, and we'll go from there. Good luck
Sep 04, 2007 | Acer Aspire 5600 Series 5630-6951 Laptop
Computers & Internet Logo
56 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
