Question about Porter Cable Cable Commercial Pressure Washer PCH3200
I have a porter cable 2500psi 2.5gpm pc2525sp when do you change in the pump and what kind
3 Suggested Answers
  • 88 Answers
SOURCE: What type of oil do I put in the high pressure
regular motor oil
Posted on Aug 22, 2009
  • 760 Answers
SOURCE: what typ of gas do i use
Regular gas 87-89 octane works fine.
Posted on Jul 14, 2010
Porter cable cffn25 won't run. Trips breaker
The little compressors were not built for continuous duty. The pump probably seized, or the motor burned up, or both.
Nov 25, 2013 | Porter Cable Air Tools & Compressors
My porter cable 5101 air compressor will no build up pressure.. no visable leaks found
use liquid soap in water to check for leak if you have no bubble at any connection you probably need a rebuild kit for pump,this model is oilless and wear fast
sometime the o'ring on pump output pipe is worn,you need to open head of the pump to see it
Nov 12, 2012 | Porter Cable - Cable C5101 Oil Free...
How to remove muffler intake from Porter Cable CPF6020-1 air compressor
To remove the air filter intake muffle you will need to remove the 4 screws that hold the head on to the pump.
There is a O-ring under the head you will want to put a little vasoline on before you reassemble the head back to the pump.
The new muffler kit should be the KK-4981
Sep 10, 2012 | Porter Cable Air Tools & Compressors
It will only pump up to 30 psi
If it will only pump to 30psi. then you are having problems with the pressure regulator. You can get a new regulator from Porter Cable.
Sep 20, 2010 | Porter Cable Air Tools & Compressors
Engine manual for the Porter Cable pcv 2250 pressure washer
If you need an engine manual, then look up the manual on the engine manufacturer's web site. eg Briggs & Stratton, Honda, Techumseh. Porter Cable manual would just have cart and pump info.
Jul 23, 2010 | Porter Cable Cable Commercial Pressure...
Air Leak From Pump Head on Porter Cable C2001 Pancake Compressor
The real question is where exactly is the leak coming from. Compressors have a pressure release valve designed to let the pressure off of the compressor motor so it can start when there is pressure in the tank. This valve is often the culprit and fairly easy to replace. You can order it direct from porter-cable online. Just in case double check the drain petcock sometimes these get worn and won't close completely and can easily be over looked when trouble shooting.
Jun 12, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
No pressure
you will have to try the following start up purge up onece with just water then start the powerwasher if that does'nt give u pressure ther is gaskets inside the pumping sometimes 4 to 8 of them these might be to wore down to hold pressure if u can locate the pump and desemable it run it to ur local dealer tell u need new gaskets put into it
Apr 09, 2010 | Porter Cable PCH3200 Commercial Pressure...
Change the blade on my porter cable 347
Here is the owners manual for your saw. It details the procedure for removing and installing a blade.
Please rate this positive if it helps!
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/En900003.pdf
Jul 03, 2009 | Porter Cable Cable 7 1/4" Quik - Change...
Porter Cable Cable Commercial Pressure Washer PCH3200 Logo
115 people viewed this question
Top Porter Cable Garden Experts
Jim Goldsmith
Jim Goldsmith
Jim Parker
Jim Parker
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
