Question about LG Audio Players & Recorders
I have a LG HE 903 PAW 5 disk DVD player and all of a sudden the sound will not work at all all wires are connected and everything is plugged in not sure of the problem?
SOURCE: No sound on my PhilipsDVP642/37 DVD Player
there's a 6.3 amp fuse in the subwoofer that can be replaced.
Posted on Dec 12, 2007
  • 1894 Answers
SOURCE: How to connect all components to work
you will have all them all in user manual itself right?
Posted on Jun 08, 2008
ve3wtj
  • 147 Answers
SOURCE: Have picture, no sound
I've had this trouble too. Not sure how to fix it, but I've found a work-around:
Remove DVD.
Insert Audio CD.
Wait for audio to play.
Remove audio CD.
Reinsert DVD.
Sound should work again.
If you power off the unit, you may have to try this procedure again.
Posted on Oct 07, 2008
SOURCE: DVD player won't work on my 27gt615
alexa,
good day, if youre saying that you program the DVD to work on channel 2 or 4 does it mean you convert the signal of your dvd player from A/V output to RF out?
because the simpliest way to connect your DVD player to TV screen is by using RCA cable ( 3 wired cable being color marked as yellow/red/white) yellow = video red and white = audio
the connection would be: from dvd back part you'll see colored socket yello/red and white. connect the RCA to those socket following the same color .
and from the TV screen there should be A/V input socket. can be locate at the BACK/Side or FRONT of the screen marked as
"INPUT" ( AV1, AV2,AV3 if multiple inputs). Then select which input you want to place your DVD player ex.AV1 (from AV1 there will be 3 scoket in a row, yellow/red/white)
Connect the other end of your RCA cable following the same color code to TV "AV1 INPUT" yellow = yello/red =red/white=white. then from the remote commander of your TV screen locate a button marked as "TV/AV" or "A/V" press this button until the screen display switch to AV1.
cheers,
mark
Posted on Jan 31, 2009
  • 21 Answers
SOURCE: wiring problems
Not certain if HDMI can be used in a setup like this. I'd try it from the home theater (HT) to the TV, and other wiring for the other components.
For video:
All of these should have component connections (Y/Pr/Pb). You'll only need the video cables for each device:
  • Video out from cable, HT, and combo player.
  • Video in to TV. Your choice of inputs.
For audio:
Hopefully, the two output devices (the combo player and the cable box) have digital audio (fiber optic, or RCA coaxial). Otherwise, you'll only get stereo sound. VHS is stereo only anyway.
  • Audio out from cable box and combo player.
  • Audio in to HT.
The TV won't have anything to do with audio in this setup. Alternatively, you could try hooking up all inputs to the TV, and connecting audio out from the TV to the HT. Works best if this connection is digital, for surround.
Posted on Feb 20, 2009
Dvx583kh no sound HDMI
you must read your instrc.manual from TV +DVD about the connection is compatible. or some connection is wrong. download your instruction manual go www.fitness.manualonline.com or www. retrevo.com
see the diagram connection
God bless you
Jul 13, 2012 | LG DVX583KH Player
Jun 08, 2008 | Audio Players & Recorders
Hi, i have LG DVD Player DV6H, can i have region free code for this? Thanks.
Hi Coelhosc
For LG HD DV6H Media Player
1. Start DVD with no disk, wait for no disk in display.
2. Press "0" zero for 5 to 10 sec till screen appear
3. Press pause
4. Press "0" for 5 sec (both setting must be "0" for region free)
5. Press pause again.
All ready to go.
Sep 10, 2011 | LG DVD 6053 DVD Player
Everything works but when dvd is in play it doesnt show picture just sound.every wire is connected right,wat can it be?
everything works but when dvd is in play it dosent show picture just sound. everythingis connected right
Dec 07, 2009 | Pioneer AVH-P5700DVD Car DVD Player
Sudden problem: voices can't be heard, everything else normal.
If this is on a home made dvd then that is probably where you the problem is.
If you try a proper store bought dvd and that works then you know its the other dvd.
But if a proper store bought dvd give the same errors then it could b a setting or part of the sound replay circuits that have or ore dying
Aug 17, 2009 | Sony DVP-NS575P DVD Player
Emerson AV50 says ''NO DISK''
Hi, sounds like you have a dirty laser eye on the DVD player. The eye gets dirty and it won't read movies or function properly. I would recommend a DVD Cleaner CD. I would have you try this before I have you open the DVD Player to clean the Laser Manually. Please try this and Post the Result for me to Review. Thank you
May 19, 2009 | Emerson Audio Players & Recorders
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
Humming noise while watching DVD on Harmon Kardan DVD 5
if the humming sound is in the tv or sound system you will have to check wiring connections and ground wires.
If the humming comes from the dvd player clean optical head with a dvd lens cleaner disk
Oct 04, 2008 | Televison & Video
Pretty colors
Sounds like the other DVD player went bonkers. Try unplugging power on the DVD player you were playing the game on for 5 minutes, then plug it back in.
Apr 02, 2008 | Sony DAV-FC8 System
Portable Accurian DVD player
This may sound overly simple but try disconnecting the power from the unit (i.e. unplug it from the wall), wait a few minutes and plug it back in, kinda like a hard re-boot.
Jan 17, 2008 | Radio Shack Accurian APD-3955
104 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
