Question about Frigidaire FRS26H7C Side by Side Refrigerator
Leaking water periodically under the refrigiater
  • 316 Answers
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
Posted on Oct 06, 2010
  • Timothy Toye Jun 29, 2013
    How do you clean this drain out if it is blocked?
Why is there water leaking under the dash
If it's leaking near the glove box, it's probably the heater.
If it leaks at the foot of the driver it may be a clogged drain near the windshield wipers under the hood. Also could be a clogged drain around the sun roof.
First you can test the drains with a cup of water poured in the drain holes. You should see the water draining out under the car, usually near the tires.
They can be cleaned out with a little bit of air from a compressor.
Hope this helps.
Feb 28, 2015 | Ford Bantam Cars & Trucks
RF261BEAESP
Check the pipe that drains the water from the avaperator (the thing that gets cold inside on the fridge)
periodically your fridge will defrost and the water should drip through a tube and collect at the rear of the fridge
If the pipe is blocked the water collects inside at the bottom ( under the crisper)
Apr 15, 2014 | Samsung RF261BEAESP 25.5 cu. ft. French...
Refrigerator leaking water
You gave no manufacturer name or model number so this is only a guess: If you refrigerator is a self defrosting one, it will periodically, allow ice building up in it to turn to water which naturally drips to the lowest point. Most refrigerators have a drain below the vegetable bins on the bottom. That is probably where the water is coming from. Solutions include putting a shallow baking pan under the bins or under the refrigerator to catch the water, then empty it periodically.
Jan 21, 2013 | Refrigerators
I have an insinkerator hot water dispenser with stainless steel tank, and the tank is now leaking. I'm wondering if it can be fixed or needs to be replaced
Replace water heater if tank wall is leaking.
These things have short warranty period.
Stainless steel will theoretically last longer, but steel tank water heaters have replaceable anode rod to prevent rust-out.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
Be sure to recycle the old metal.
http://waterheatertimer.org/How-to-recycle-water-heater.html
Oct 29, 2012 | Emerson InSinkErator C1300 Chrome...
Water under crisper drawers
I am pretty sure you are having a defrost drain blockage problem. Most refrigerators defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section (depending on the style refrigerator you have).Click Here=> Leaking Refrigerators Just What may Be Happening
Much more on this page=> Leaking Refrigerators!
I willbe here should you have questions, Thank You,
Sea Breeze
Feb 08, 2012 | Maytag Refrigerators
Water is leaking under the refrigerator. This is
If everything else on the refrigerator seems fine (freezing and refrigerating are fine), then you probably have a problem with the drain hose under the evaporator coil. On frost free freezers, there is a heater that comes on periodically to melt off all the frost on the evaporator coil, and that defrosted frost (water) goes out a drain hose and collects in a pan at the back of the unit where it can evaporate.
Either the drain is clogged with ice inside the freezer, (in which case you might notice ice building up on the bottom of the freezer, or perhaps water collecting on the bottom of the refrigerator if your freezer is on top) OR there is something wrong with the pan at the back of the refrigerator, like a crack, or it somehow got tilted so that the water pours out. It is located behind the panel on the back.
Or perhaps, and this would really ****, the water line that supplies your ice maker is leaking, if you have one. If you do have one, I would recommend turning the water line to the fridge off before pulling the fridge out.
Sep 14, 2009 | Kenmore Refrigerators
Water pooling on bottom of freezer and leaking into fridgerator
in the back of the fridge you have a hose going to the bottom , take everything from inside of the fresh food compartment and blow in the hose and after voila problem solved
Jun 17, 2009 | Refrigerators
Refrigerator leaks
Could be nothing is broken. There is a drip pan under the refrigerator. It accepts water from the defroster. The water is supposed to evaporate before it gets full. It ought to be cleaned periodically, as it gets nasty with mold. Could be the pan is displaced or cracked.
Nov 10, 2008 | Samsung Refrigerators
Frigidaire FRS26H7C Side by Side Refrigerator Logo
128 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
