Question about Caterpillar Camshaft Journal For 3608 Generator
Cat generator w/ deisel engine panel board indicates low oil pressure ,when oil pressure indicates engine stop
    Prodigy:
    An expert who has answered 500 questions.
  • Caterpillar Expert
  • 573 Answers
Check the actual oil pressure, don't rely on a sensor
Posted on Nov 27, 2013
How to test caterpillar c18 acert low oil pressure shut down
This is a critical element to protect the engine. Shop manual is needed. You can try manulslib.com but they may not have it.
So ask the dealer or MFG for one.
Mar 15, 2015 | Caterpillar C18 ACERT Marine Generator Set...
Low oil pressure indicator at low rpms (idle) '97 olds V8
Low pressure when at idle, after the engine has warmed up and the oil has thinned, indicates that the oil pump is worn and needs to be replaced.
Jul 07, 2008 | 1997 Oldsmobile Aurora
Generator stopps and the alarm indicates low oil pressure
First check the level of the oil on the dipstick and see if it is in the safe area. If it is the pressure switch or the wires to it need replacing.
Jan 27, 2014 | Garden
Perkins generator stop and indicate low oil pressure?
If the oil level is correct then you might be up for an oil pump. Some engines have an automatic cut-out for low oil pressure or high temperature as a safety mechanism to protect the engine from massive damage.
Oct 08, 2012 | Cars & Trucks
Where can i find the low oil alert module ?
Yes , if there is an errror on the oil pressure switch or a low oil level then the engine will not be allowed to turn in. Check and refill oil, check the oil pressure switch , it can be clogged and so might not work.
Nov 06, 2011 | Coleman Powermate Powermate 5000W...
Why is showing low oil pressure and stop engine on dash board i have low oil pressure and it reads stop engine
Check your oil. If it is low, top it off and see if the light goes out. If your oil is full, have your oil pressure checked.
Jan 08, 2011 | 2002 Chevrolet TrailBlazer
Getting a "Low Oil Pressure" message on the dash board.."Turn off engine" any ideas of what the problem might be?
Hi. This issue has several causes, but the oil light indicator is a strong sign of low pressure in the engine. This will cause the engine lubrication rate to drop, thus, producing a illuminated oil light, and erratic Oil pressure readings. The necessary actions are to have a manual oil pressure test ran on this engine, asap. When running a manual oil pressure test, you will discover if the true oil pressure is low, or normal. If the test proves that the oil pressure is, indeed, low, this will confirm that the Oil pump is suspect.
Now, if the true readings given during the manual oil pressure test are indicating that the pressure is normal, this will be the result of a failed sending unit(oil pressure switch).
Jan 11, 2010 | 2003 Chevrolet TrailBlazer
Oil pressure low
DON'T DRIVE ANOTHER MILE !!!! The 1.8 is known for a sludge buildup in the engine. This is the exact symptem that shows its head. The car HAS to be TOWED to a garage before you cause any further damage. Do a google search, "vw 1.8 sludge", and see what comes up...
Dec 27, 2009 | 2001 Volkswagen Golf
What is the check gauges light
CHECK GAGES light (1) indicates a potential engine failure(low oil pressure, low coolant, coolant overheating) has occurred.
· Check gages and shut down engine. Gages should read as follows: Oil pressure 5 to 10 psi (34 to 69 kPa) at idle; Water Temp gage below 230 degrees (110 C).
· Check engine oil level (Para 2-11) if OIL PRESS gage indicates low reading. Check coolant level (Para 2-11) if Water Temp gage indicates high reading. Notify Unit Maintenance if levels are low.
If CHECK ENGINE light (2) is on, check engine oil pressure gage (3) and water temperature gage (4). If both indicate normal, proceed with mission and then notify Unit Maintenance. If either one does not indicate normal, stop engine immediately and notify Unit Maintenance
Oct 16, 2009 | 1999 GMC Jimmy
Caterpillar Camshaft Journal For 3608 Generator Logo
183 people viewed this question
Top Caterpillar Electrical Supplies Experts
Lawrence Oravetz
Todd Arndt
Todd Arndt
Ted Maxwell
Are you a Caterpillar Electrical Supply Expert? Answer questions, earn points and help others
