Question about Bosch SHE4AM16UC 24 in. Built-in Dishwasher
Bosch dishwasher soap dispenser doesn't open regularly
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
This has become a popular issue with the newer style Bosch dishwasher, and I don`t know if this is the case in your situation, however if using "cubed" or "gel pack" type detergents the dispenser will often get stuck therefore preventing opening.
At a recent service seminar for the Bosch SHX/SHE "Evolution/Ascenta" series dishwasher`s I attended, it was suggested if a client is using the "cubed/gel pack" or even liquid detergent either place the cubes directly into the bottom of the dishwasher or in the case of liquid, switch to powder detergent since both liquid and cubes seem to have an issue of causing this problem.
I understand from experience of presenting this with many clients it may at first appear inconvenient or unacceptable, and many will balk at the idea. Unfortunately it is a reality and no physical repair to the machine will remedy the issue.
Try the suggestion and let me know how you find the unit performs. In my experience the unit actually will perform better actually, as the detergent`s nowadays without "phosphate" require a longer period to dissolve completely and therefore often don`t work nearly as well when being dispensed from the "cup/dispenser".
I`ll watch for your reply on the result or if you need further assistance. Thank you for choosing FixYa. Please take a moment to rate the info provided here today and a testimony if you feel it`s warranted.
Good luck.
Regards,
Macmarkus :)
Posted on Oct 06, 2010
SOURCE: Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Posted on Jan 09, 2009
  • 1073 Answers
SOURCE: i have a kenmore dishwasher.
disasemble the pump housing and remove the debris that are located in the housing, not enough pump pressure to spin the spray arms to desolve the detergent
Posted on Apr 10, 2008
  • 132 Answers
SOURCE: The soap dispenser on my bosch dishwasher doesn't open
it is agood manual solution but if you want to rea ly fix that there is {an electrical order reach at suitable time to open the dispenser it come from electronic circuit to elecronic lock which catch the
dispenser so one of those parts may be fualty
Posted on Jun 09, 2009
  • 311 Answers
SOURCE: Bosch Dishwasher Soap Dispenser Fails to Latch
Need to replace dispenser. I have access to that part; let me know.
Posted on Nov 28, 2008
  • 134 Answers
SOURCE: Smeg Dishwasher SA 620 X-Soap dispenser won't open!
Sounds like the solenoid in the dispenser has failed. Youll need to replace it
Please leave feedback
Thanks
Rob
Posted on Feb 13, 2009
Soap dispenser door will not open. Regular wash cycle time varying a great deal when machine turned on.
The soap dispenser is probably faulty. Wash times can vary. The main controller will determine the wash time and will change according to water temp when filling, time it takes to fill, etc. Check and make sure the filters at the bottom are clean.
Feb 23, 2015 | Bosch 24 in. SHY66C05 Stainless Steel...
Soap tablet not dispensing happens every 2nd or
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Jan 05, 2011 | Bosch 24 in. SGS43E08 Exxcel Built-in...
Soap dispenser will not allways open during washing
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Dec 28, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
The soap dispenser fails to open at times
Hi
Bosch dishwashers (not all) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open. Most often the bi-metal strip has lost its ability to bend properly and needs to be replaced.
Older Bosch dishwashers used a mechanical arm driven by the timer to open the dispenser = no electrical bi-metals. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Oct 12, 2009 | Bosch Dishwashers
Tried to replace bosch soap dispenser model shu3036uc/u12
Wire positioning doesn’t matter to soap dispenser. If water is leaking from the door then the dispenser is not pressed in properly against its seal. As far as the door not opening if wires are connected perhaps the problem is in the control module. Voltage meter on wiring to dispenser should indicate this while machine is running at start of quick wash cycle. (First 5 minutes of cycle on heating)
Dec 28, 2017 | Bosch 24 in. SHY66C02 / SHY66C06 Built-in...
Bosch #SHU9955 Integra dishwasher for the last three uses, the soap dispenser door was open with the powder soap caked in the lowest one half of the pocket dispenser. The dispenser door locked and unlocked...
The problem was evident during short cycle (primary cycle used) and changing to regular cycle used and back to short cycle seems to have corrected problem.
Oct 09, 2008 | Bosch Dishwashers
Soap dispenser flap not opening
Not a solution but exactly the same problem. I should have sent the machine back (I bought mine about 2008 too) but by now, 2010, the machine is a complete waste of time and money. The soap dispenser fails to open every time, wasting money, water and my patience because I then have to hand wash after all. will try the suggested oil trick, but it was obviously a bad design to start with.
Jul 20, 2008 | Bosch 22 in. SKT5102 Free-Standing...
all you have to do is take a flathead screwdriver and look at the dispenser it has a locking metal around thecase where the dispenser goes. it a press in and listen to it click thats when you know that section is in.the plastic around the dispenser is the section where it snaps in. also unplug the dispenser. its only one plug in. very easy but atrick that i use is make sure the rubber gasket is lubricated with something like dish soap.when installing it you have to push hard and listen for the snaps .nyc appliance repair can handle at 1-888-692-1055 based in nyc
Mar 26, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHE4AM16UC 24 in. Built-in Dishwasher Logo
5,935 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
