Question about Samsung DVD-R130 DVD Recorder
Can't find a DVD-RAM disc that works
Panasonic used to have a disc that worked most of the time but they discontinued it. I tried some Maxell 3x but the machine spits them out. Is there anything that works?
  • teclado Jun 19, 2008
    What kind of solution is that? Have you tried TDK? If so, what speed? This site has a lot of potential but the users don't give real information. I want to know what WORKS.
Dear
Every dvd i put into it it tells me to check the dvd. the machine spits them out
samsung dvd-R130
please help me
arif
Posted on Jul 25, 2010
I suggest TDK
Posted on Jun 18, 2008
My Samsung DVDR120 will not accept any new DVD-RW discs. I have tried Maxell, Memorex and SONY. They all either freeze at 85% initialization or formatting, or spit out saying system error. The machine is 4...
This is a common fault and usualy caused by the DVD drive going faulty, The Lazer changes angle as it records across the disc and at about 80% there is a change point.
I suggest putting a cleaner DVD through the unit before you try anything else as a bit of dust can cause that problem. If that doesn't fix it than you may need to change the DVD loader unit as a whole or as you suggested by a new modern unit with even more features.
Jul 16, 2010 | Samsung DVDR120 DVD Recorder
My tunes keep skipping, I have some old tunes burnt to maxell cds and they work perfectly but i went and bought some new maxell discs burnt some tunes from imesh and they skip all the time!!! Is it the...
Try a disk lowering your write speed, for when you burn. If your speed rating on your disks is 40x then try burniong at 1/2 the speed, I generally have a rule to only burn at half the maximum speed.
Hope this helps
Oct 07, 2009 | Nu Mark AXIS 9
I'm unable to find DVD discs that will record in my machine. I was using Maxell DVD+RW 4x but am not able to find them. If it says "up to 4x" it will not work. If I buy Memorex 4x, they won't work. I saved...
I have found that the DVD recorder in this unit will not recognize a DVR+R disc greater than 8X speed. Therfore 16X discs are not an option. Like you already know, it likes DVD+RW 45X speed discs but it is selective. I have been using Maxell DVD+RW 4x and have found that Verbatim DVD+RW 4X and Sony DVD+RW 4X work just as well.
Jul 04, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
CD BURNING
This sounds like a dirty CD Drive, you can purchase a CD Drive Cleaner from most electronic stores that sale blank CD's. Maxell and Memorex are good blank CD brands. In addition make sure you are storing the CD's in a dry, dust free area, also make sure after using the CD Cleaner that there isn't any dust or debri. Keeping the drive free and clear of dirty will help with performance, if this does not help the last resort would be to replace the CD drive.
Mar 19, 2009 | Dell XPS 200 PC Desktop
Failed to burn DV disc.Cyberlink Media Show error code 0x0A180001
I was also suffering this problem with Nero 6. To solve your Problem first make sure that the windows you are using that supports your Software if supports, then your Optical Drive may not Write in high speed 16x or 18x, write your files in DVD in little bit slow speed, after doing all this if it gives same problem then Please reinstall your windows you are using.
Mar 08, 2009 | Computers & Internet
Can not read disc
I mainly use my DVR to record TV shows on DVD-RAM discs (Panasonic brand or Maxell). I've had no problems with the DVD-RAM discs. However, today when I put a DVD-R disc in the recorder, I got an "Incompatible Disc" error message. I tried a second disc from the same set, and got the same message. I tried out some of the DVD-Rs that I recorded last year and I could read them. Tried a DVD-RAM. That was OK. So, I tried another DVD-R disc. That one is OK. I don't know if the problem is that these DVD-Rs are getting a little old (2 years??) or if the recorder is developing its own problems reading discs.
Dec 03, 2008 | Panasonic Diga DMR-EH75V DVD...
Trouble with cdr 570 philips
Newer discs are made with different dyes. We no longer get philips discs in the UK but Maxell 80 min discs work great in my 570. Have you ever been able to use 80 min discs? Usually if a machine only accepts certain types of disc it means the laser's power output is reduced i.e it's worn out so it may be time to find a new machine unless you can get a supply of discs it does use OK.
'Mr Audio' discs from Mr Data should be avoided at all costs.I can only use them in my Sony machines.
Feb 24, 2008 | Philips CDR570 CD Recorder
DVD Recorder will not format blank DVDs
I kept formatting DVD's until I got the unit to work. Mainly, it was some DVD's I had earlier problems formatting. I tried two new DVD's (Maxell DVD-RW) and they worked thus far. I truly think the unit needs to be taken to authorized service center for evaluation or minor maintenance. My suggestion is to verify the DVD's will work with unit. Try to use better quality ones like TDK or Maxell. Thanks for responding to my problem. If I have others, I will contact you.
Feb 09, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic DMR-ES30V
I have three Panasonic DVD recorder/Vhs combos and I get the same problem from time to time...it may be the disks you are using.  Mine absolutely hate Sony disks.  I have the best luck with TDK or Maxell.  You also must clean your unit frequently, if you do alot of recording.  I use my units daily.
Hope this helps
Oct 31, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
Samsung DVD-R130 DVD Recorder Logo
100 people viewed this question
Jerry Greenberg
Jerry Greenberg
