Question about Champion G5NG853S Household Juice Extractor
I need to replace the oil seal on champion G5-NG853S juicer how do i take it apart? where can i find a pdf instruction book on line?
5 Suggested Answers
  • 69 Answers
SOURCE: cleaning inside shaft of champion juicer cutter
Soak it in Hydrogen Peroxide or vinegar.
Posted on Feb 07, 2009
  • 69 Answers
SOURCE: Champion juicer don't work
You have to have the juicer attached, there is a little magnet that allows the machine to turn on.
Posted on Mar 01, 2009
SOURCE: Champion Juicer leaking a lot; from screen holder!
I'm having the same problem, the blank screen just doesn't fit the main body that well (I think the body on mine may have been warped by someone putting it in the dishwasher). Since I'm only going to be using my Champion as a front-end for a hydraulic press, I bought some food-grade silicone sealant (from McMaster-Carr or EMI Supply) and I'm just going to permanently attach the blank screen to the juicer body and slide the screen holder over that. There's a new O-ring for the back where the body attaches to the motor that might be needed as well.
Posted on Apr 18, 2011
chringram
  • 14 Answers
SOURCE: We just got a 2nd hand juicer CHAMPION model
The CHAMPION juicer manual is online at: http://www.discountjuicers.org/manuals/champion.pdf
If your juicer needs parts or maintenance, the phone support is easy to work with - call them directly at:
(209) 369-2154
Posted on Aug 11, 2011
In need of replacement part for older Champion Juicer
Fixya is unable to source parts for appliances.
Jan 22, 2018 | Juicers
I forgot how to use my champion juicer
Here is a direct link to the User's Manual for a Champion Juicer:
http://www.championjuicer.com/manual2.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I hope that was helpful to you, good luck and take care.
Joe.
Sep 13, 2011 | Champion G5NG853S Household Juice...
We just got a 2nd hand juicer CHAMPION model G5-NG-853S. Where can I find a manual for it.
(209) 369-2154
Jul 26, 2011 | Champion G5NG853S Household Juice...
Hello I dropped my juicer and the motor works but shaft won't spin
Hello !
The stainless steel shaft might have misaligned from the motor bushing due to the fall.
But, It would be risky if you tried to open the motor assembly and realign it by yourself, a service man is usually the experts on this.
You can try first to lubricate the shafting with an oil and try to rotate it and see if it moves freely.
You can also inspect if the seal from the shafting is not broken. better replace it if you found one.
The bearing also is most like to be damaged and will need to be replaced.
This link might be helpful if you want to order parts from internet
http://ecommerce.hacres.com/Champion-Juicer-Body-Hub-Oil-and-Seal-White
Nov 23, 2010 | Champion 2000+ Household Juice Extractor
My champion juicer just stopped working. Makes no sound at all when I flip the switch. Any ideas?
Championjuicer.com sells replacement switches. Order the oil seal and o-ring too to save on shipping. Newer models have a safety cut off that does not allow the juicer to turn on unless all parts are properly positioned.
Oct 25, 2010 | Champion G5NG853S Household Juice...
Juicer was working fine yesterday and today it won't start up, period. Checked at different outlets and still nothing
Oct 19, 2010 | Champion G5NG853S Household Juice...
Cleaning inside shaft of champion juicer cutter
Jan 30, 2009 | Champion Juicers
Replace Body/Hub Combo
After reading your initial post and responding...yes, take a 1/4" socket wrench and loosen the four bolts at the other end of the motor. The hub will come off easily. If you have ot replace the oil seal, I have not figured out how to do that yet. I beleive the replacement hub has a new oil seal already installed. hope this helps
May 16, 2008 | Champion 2000+ Household Juice Extractor
Cutter
This is a response I received from Champion Juicer- I am amazed at how fast they responded. His solution is below- Hello Cathy
To remove the cutter from the Champion Juicer motor shaft, take two small
screwdrivers and place them between the back side of the cutter and the
stainless steel portion of the hub. Apply pressure on the screwdrivers and
the cutter should begin to slide forward. When driving the screwdrivers in,
make sure they are spaced far enough apart so they don't damage the motor
shaft which is located in the center of the cutter. If the cutter does not
come off, leave the screwdrivers in place and insert something under the
rear of the Champion Juicer (like a book) to elevate the rear of the
machine, thus allowing the cutter to tilt forward. Apply penetrating oil
between the screwdrivers. Because the cutter is now angles forward the oil
will run inside the cutter. If this is done for several days the cutter will
come off by applying more pressure to the screwdrivers. By merely pulling on
the screwdrivers you will have to use a plastic hammer and slowly tap on
each of the screwdrivers until the cutter breaks free. Tap one screwdriver,
and when it is snug, tap on the other screwdriver until the cutter breaks
free. When this is done there will always be one screwdriver coming loose
and falling out of the slot. Do not rush the removal process; give the oil a
chance to work. It is possible the hub and cutter will be damaged during the
removal process. Contact us for current replacement prices. Once the cutter
has been removed you should polish the motor shaft to remove any film or
burrs which may have developed. If you contact us with your address we will
mail you a piece of fine emory cloth to polish the motor shaft  at no
charge. You should always apply a slight film of olive oil on the motor
shaft to prevent sticking of the cutter. Do not use other oils, as they tend
to break down from the heat during operation of the juicer. If you wish to
speak to a repair person, please call our company weekdays @ 209-369-2154
between 8:30 a.m. and 4:30 p.m. Pacific Standard Time. We would be happy to
offer any assistance you may need.
Thank you
Carl
Aug 05, 2007 | Champion 2000+ Household Juice Extractor
Champion G5NG853S Household Juice Extractor Logo
205 people viewed this question
Top Champion Juicers Experts
David Payne
David Payne
ray gallant
Are you a Champion Juicer Expert? Answer questions, earn points and help others
