Question about Maytag Dryers
I've got a Maytag model LD9206. It makes a lot of noise when it first starts up, but the noise goes away. The noise is a loud squeak which I believe is probably related to the belt or pullys. How do I access the belt to check it?
    New Friend:
I believe it is the noise the machine makes when the felt belts on both sides of the drum wear out. Some models also have low friction pads that were over time.
Posted on Dec 30, 2013
  • 2 more comments
  • Drelrnor
    Drelrnor Dec 30, 2013
    Replace the felt on both sides of the drum. If your model has them, the low friction pad, do not run till fixed.
  • Drelrnor
    wear*
  • Drelrnor
    good luck finfing the dryer part for this model i have been having a HELL OF A TIME
  • Drelrnor
    Drelrnor Oct 20, 2014
    Check the plastic fan that blows the air too. If it is worn out on the shaft it sounds like shoes in the dryer, you can fix but 1 tool was hard to find for a o ring pin
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Oct 06, 2010
MDE9606YW
The motor could be going bad. Check your belt to see if it is loose . There is also a hub that the drum spins around. It could be loose. I believe you can oil it on this model as I have a Maytag as well. At least you have heat . This is just a physical problem and not electrical.
Mar 15, 2013 | Maytag Dryers
When the dryer starts there is a loud skeaking that usually goes away after a few minutes.
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 24, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Dryer is making a lot of noise all of a sudden when it runs, loud loud banging.
heatman101
Nov 08, 2010 | Maytag Dryers
I have a maytag dryer model MDE3757AYW that is making a loud squeaking/sqealing noise. the drum still turns and dries the clothes though.
heatman101
Oct 02, 2010 | Maytag Dryers
New Maytag dryer model mgdc400vw makes loud humming noise
Weird, try making sure it is level, and make sure your vent pipe aint too long. Tip the cabinet back while running if the noise goes away the damn metal vent pipe is too dang long.
Jun 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
MAYTAG Wahing machine model MAV6000AWQ
I believe your machine is equipped with a "snubber plate" under the transmission. A lot of Maytag top-loaders are. This is a white teflon ring that is used as the wash tub and transmission support and assists in dampening vibrations during the spin cycles. It's located on the inside case of the machine under your transmission. When the snubber goes bad they generally start to squeak. They cannot be lubricated and must be replaced. If you try to oil them, they will eventually disintegrate. The snubber costs less than $10 to purchase. I hope this helps.
Apr 04, 2007 | Maytag MAV3855A Top Load Washer
Dryers Logo
195 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
