Question about Refrigerators
Kenmore Refrig #57572791 - Keeps blowing circuit
I have a 1998 Kenmore Side by Side Refrig that keeps blowing the circuit. I have tried several different plugs and they all keep blowing. Can someone explain why the frig keeps blowing the circuit and recommend how this can be corrected? Thanks
  • 828 Answers
If you have an OHM meter, check from the flat conductors of the plug to the ground section of the plug. Any reading at all indicates a short in the circuit. Most likely place of the short could be the compressor. If you are capable, with the unit unplugged disconnect the leads from the compressor, then see if the breaker trips when you plug it in. If not the problem is the compressor . At ten years old it would be more expedient to get a new refrigerator than to replace the compressor. The warranty is up and you would pay the big bill for the compressor and labor.
Posted on May 28, 2008
AC fuse keeps blowing on my 1998 ford crown victoria
The reason a fuse blowing may be because of a short circuit. And you should check any wire connectors that plug into the pc board.
fiat km tool software
Jun 15, 2012 | 1998 Ford Crown Victoria
What is the cubic ft measurement of a Kenmore side by side fridge, model # 57572791, serial # SH2448358
25.0 Cu. Ft.
Aug 07, 2011 | GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW...
I have a 1997 mercury mystique and the power window fuse keeps blowing. What could be the problem?
When a fuse keeps blowing the problem is usually a short or open circuit that allows for the current to keep passing and blows the fuse
Mar 03, 2011 | 1998 Mercury Mystique
I have a Kenmore side by side refrig. and the freezer side keeps getting full of frost, and the refrig. side is barely cold, and keeps spoiling food. I've had a tech come out and check things out and...
Either your defrost element or timer is bad or your fridge is low on freon. Frost is a sign of outside air getting in but it can also be a sign of the defrost heating element not kicking in and the defrost timer turns it on for a few minutes each day and a defrost limit keeps it from getting two warm during the defrost cycle. good luck hope this helps
Aug 17, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
M# 596.72219200 Kenmore with bottom drawer refrig keeps freezing
That is a broken thermostat control part number 67003000 when they stop they can break while on or off. Sea Breeze
Jul 23, 2009 | LG LSC26905TT Side by Side Refrigerator
Water pouring from waterdispenser in side by side refrig
Dispenser leaking----Probably replace the water inlet valve on the back where the water supply comes in. Disconnect the water line to the dispenser there and see if it keeps dripping when you try the dispenser
Jul 01, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Model 57572791 not cooling or freezing on either side
Jan 29, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore side by side refrigerator
there is valve for each right at the water inlet, your valve is stuck or your coil is bad......get a new valve.
Nov 03, 2007 | Refrigerators
Refrigerator repairs
check freezer for frost build up on back wall and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore top freezer unit-refrig not cooling past 50degrees
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 03, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
168 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
