Question about Simplex Kaba Ilco Unican LP1000 Panic/Exit keyless lock
Need to removed from door to change door slab?
  • 963 Answers
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Posted on Nov 10, 2011
Removing a non locking broadway schlage door lever handle. Unscrewed tiny screw to remove handles but can't figure out how to remove the rest of it from the door. I don't see any screws and can't pull it...
There will be two screws under the decorative cover plate. This cover plate is usually removed with simply pry away from the door slab. Just remember the cover plate is thin, so your pry only need to just be under it, not the actual handle body.
Mar 04, 2015 | Cars & Trucks
How can i build a cement speed bump?
Is this for vehicles? If so concrete won't work as it will be too brittle especially when it gets cold.
Jul 14, 2014 | Building Materials
My undercounder KUIS18NNJB5 icemaker freezes successfully but the ice does not exit the freeze plate completely during the harvest cycle. When the next ice cycle starts, the ice refreezes to the plat
In the manual the fix is to clean the ice maker with cleaner. Your ice slab is not releasing during harvest. The plate (evaporator) has minerals on it and needs to be cleaned to remove the build up. On the door of the unit has cleaning instruction, do not short cut the cleaning process, this does take about an hour and follow the instruction to the letter.
This is not a major issue, just cleaning is needed.
Dec 07, 2013 | KitchenAid KUIS18NNT 18" Automatic Ice...
How to repair a water pipe leak under a concreat slab
Things to consider are cut and replace -1. Concrete saw the affected area replace and re-concrete (impact hammer is another option but a concrete saw is neater and you can control the cut better.. 2. You can bypass the pipe. 3. Dig under the slab - you obviously would need to be near an edge.
Jan 18, 2013 | Brett Plummer Android Apps
The bathtub drain pipe [below the tub] is cracked is there any easy fix without removing tub, etc  it maybe could be reached by cutting out part of the adjacent wall otherwise, the water spills onto...
You can do all your fixin underneath where you say it is leaking on the slab if there is room for you to crawl under why remove the tube, more trouble than it is worth.
Jul 18, 2010 | Home
Hi can i hang a door with normal hinges from wall to wall without ang gaps showing
the gaps around a door are there because of the needed clearances while opening and closing the slab. To accomplish no gaps door way a 0 clearance hinger will need to be used other wise use materials to over laps the gaps creating the image of a continuous wall.
Dec 07, 2009 | Hand Tools
A paper jammed during a fax. i removed it. now,
When you removed the paper jam did the paper tear? mit have left piece of the orgnial document. Also open document feeder where you place the orginal check to see fot any problem. As for the cover does it look like something on the the door is broke, The actuator on the door Slab of plastic , that goes into a slot on the machine to accurate the door close sensor, if the sensor is not activated then the copier thinks the door is open even if it closed
Aug 26, 2009 | Office Equipment & Supplies
Does this ice maker need a pump or is it built in zdis15css
It has a circulation pump that continuosly supplys water over a plate that forms a slab of ice on it. As the slab gets thicker the resistance values change in the ice and the machine opens a hot gas solenoid operated valve which floods the plate with heat from the condenser below. This makes the slab slide down the shoot onto a wire grid that is heated. The slab is cut into tiny little cubes and drops off into the ice bin. So yes the machine has a circulator pump. Ever so often you need to put it into the clean mode and add some nickleguard or ice machine cleaner to keep the pump and its components all happy happy.
Jun 13, 2009 | GE Monogram ZDI15C Automatic Icemaker
Water freezes on slab & Builds Up will not fall on Wires
We had this problem. You need to clean the freezing try using a green scouring pad and the solution they recommend in the user manual. You need to scrub the tray with forward backward motions until slippery clean. All surfaces need to be clean and free of plack. it will work like new if you do this. Need to remove the cutting try first.
Feb 06, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ice jams in KUIS18NNJB Kitchenaid under counter ice maker
There are 2 sets of wires on the cutting grid that are perpendicular to each other. Electrical current passing through the wires creates heat that melts the ice. The first set cuts one direction, then the ice strips drop onto the second set that cuts the strips into cubes. Remove the cutter grid and check if the wires are broken. If they are, electrical current can't pass through the wires, so no heat. Restringing kits are available to fix this. If the wires aren't broken, you'll need a voltmeter to see if current is reaching the wires. If it isn't, then the transformer has likely failed.
Dec 13, 2008 | KitchenAid KUIS18NNT 18" Automatic Ice...
Simplex Kaba Ilco Unican  LP1000 Panic/Exit keyless lock Logo
87 people viewed this question
Top Simplex Locks & Locksmithing Experts
Michelle Balcom
Pamela Leach
Pamela Leach
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
