Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
I got a seagate external drive 500 GB all my documents and picture are inside , any computers recognize it ,please help.
    Brigadier General:
  • 10,406 Answers
The unit has two major points:
* the disk-drive
* the USB-to-disk-drive adapter
So, disassemble the unit, and remove the disk-drive,
and connect it as a 'slave' drive in a desktop computer.
If it works, then that adapter has failed.
See: http://www.canadaram.com/3_5_sata_enclosures.htm
to buy a replacement enclosure for your disk-drive.
Posted on Oct 06, 2010
Toshiba Satellite A665 S6067 laptop wont recognize my SeaGate FreeAgent Go 500 Gb. device
I had a similar problem and I had to "Delete Volume" when in DIsk Management. I then had a choice to "Create Simple Volume" which I did, and then a wizard created the correct partitions and assigned a drive letter to my external drive. Everything was them OK.
Mar 21, 2014 | Computers & Internet
I have a 500 GB Seagate portable external hard drive model 9ZA2AH-500. It was working fine untill yesterday. Now when I plug it in all I get is a faint beeping sound Then it stops. I have tried plugging it...
It may be the interface that has failed but I suspect the hdd has failed.
Take the hdd out of the case and fit another drive. If that one is OK the hdd is dead. If it doesn't work, try a new usb to SATA interface.
Sep 25, 2017 | Seagate Free Agent Go Small 12 GB USB...
I have a Assembled Computer with Processor Intel Dual Core (R) @ 270 GHz, 3 GB of RAM equipped with Microsoft Windows XP Professional Edition version 2005 service Pack 3 with Wi-Fi Netgear 108 Mbps Lan...
yah you must buy a Y-USB cable for your external hardisk. this is connection both ends are one is for hardisk and the other two cable is for USB slot of computer. why it two wires connection to usb because one wire is for Data and the other is for Power. If doesn't work..it might be a problem in your Operating system. i recommend to you to reinstall your Windows OS.. theres a 4 reasons why it happen appear the error... deffective USB cable..corrupted driver of USB device for seagate, virus infected of your systems..and maybe your hardive is deffective. Please rate if this is HELPFUL..thanks
Aug 22, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Seagate barracuda external 500 gb hard drive usb not seen any longer,cables and power okay , tried on three computers
Verify what Drives have been detected by your Operating System by using Windows: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk(s) will be displayed with all existing partitions and any assigned drive letters.
Your external (or internal) drive must be recognized as having formatted partitions that have a drive letter assigned to each required partition.
Hope it helps: let me know how you go!
Dec 30, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate FreeAgent, 500 GB p/n 9nk2al-510 stopped working
There's not much troubelshooting you can do with a failed external disk. power off PC and hd and then disconnect all cables, wait 30 secs, power the PC on, let it boot to the OS, power the hard drive on and then connect. If the drive shows up but you still cannot access it or get weird property readings, it generally means the hd controller has failed. If the data's worth more than $1000, you can take it to a data recovery group like Ontrak or Cherry Systems, but otherwise, just get a new hd and restore whatever backups you have.
Oct 07, 2009 | Seagate Free Agent Go Small 12 GB USB...
My computer doesn't detect my FreeAgent Pro 750GB (seagate)!!!
Do not despair - check out the documentation on page 3 (you'll need Adobe Reader to open this PDF file):
http://www.seagate.com/support/freeagent/FA_Pro_15_QSG_US.pdf
Hope this helps
Sep 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My free agent 500gb external not recognized
Try changing the data cable. it should work, I had same problem and after changing cable it worked.
Aug 04, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Can no longer recognize my external hard drive
I cannot get my computer to detect my external hard drive. It worked fine before? Now i get this clicking sound.Please help.
Nov 15, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
104 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
