Question about SIM2 HT300 Multimedia Projector
Replacing the lamp in SIM2 ht-200
How in the world does the case come off just so you can replace the lamp?
OPen top case with four screws, two on back of the unit and two on the bottom. Remove six screws on lamp cooling fan, unpluf lamp (Brown Connector) unscrew lamp.
Posted on Dec 06, 2008
My gz 125 marauder starts sometimes the spark is poor what do you think it is
Start with cleaning and checking the spark gap (reajust to right cap setting) replacing the spark plugs, if that doesn't work then move onto replacing the caps... Thats the cheapest and easiest things to do.
If that doesn't work then look at the coil for loose wiring. If that doesn't come up wth anything then replace the HT leads (unless the HT leads and coil are one unit) and finally it could be a faulty coil and so its a simple, but pricey, thing to replace it...
May 24, 2014 | 2002 Honda XR 200
How to reset lamp hours on Sim 2 Domino 18
I am not familiar with your brand in particular but they are all pretty much the same. In the menu under settings you should be able to scroll to lamp settings. Under that category or something like that will be where you can reset the hours.
May 20, 2014 | SIM2 Office Equipment & Supplies
Replacing Lamps in a Cobra 200GTLDX I need to replace the Nightwatch Lamps and meter lamp in a Cobra 200GTLDX...
check the voltage going to the lamps before you do this so that you don't have to replace them . They might just be shorted enough to have the lights go out.
Jul 01, 2011 | Cobra 200 GTL DX 4-Channels Base CB Radio
How do you reset the lamp timer on a Sim2 Domino 60.
I would need to know the serial number of the unit.
You need to press 2 buttons on the remote then enter a five digit number to enter the service menu to reset the lamp counter.
Mar 16, 2011 | SIM2 DOMINO D80 DLP Projector
My 1997 ultravision projectionn tv is having yellow shadows.
Best case scenario is your lamp is failing and will need replacing ($200 - $300). Worst case scenario is the panel is starting to fail, meaning it would not be worth repairing. The set is 14 years old and has probably reached its end of life. You can probably replace it for less than a thousand and not only have HDTV but a digital receiver as well.
Mar 13, 2011 | Hitachi 51F500 51" Rear Projection...
My HT-P10 displays "protection" and
The amplifier has a bad channel or is bad in general, and will need replacing. In some cases, it's a separate board and can be replaced itself, but in others, everything is on one board(except the power supply unit) and warrants just having he unit replaced.
Dec 04, 2010 | Samsung HT-P10 Theater System
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
I68, not read sim
Change of the SIM Places that you inserted !
Insert your working SIM1 to phone SIM2 SLOT Insert your not working SIM2 to phone SIM1 SLOT
Solution :
  • If your SIM2 that you inserted into SIM1 SLOT remain not working !
  1. Your sim card is defected or Phone does not support this sim card!
  • If your SIM1 that you inserted into SIM2 SLOT is not working
  1. There is a problem with phone's SIM2 SLOT
In case of SIM2 SLOT problem i can help you to get it fixed contact : omniarepair at gmail dot com
Best Regards
Jun 24, 2009 | Dual Cell Phones
Sim2 domino 20
Hi there
I checked the manual of your Sim2 , but they don't even mention the lamp in there.
You already have the front cover off , check if you can see any small screw around the lamp housing. They normally attach the lamp's housing with tiny screws to the rest of the unit.
Apr 24, 2008 | SIM2 Domino 20 Multimedia Projector
Projector not working
I have the same problem with a HT250, red power light on back of projector will not come on. But if you leave the projector plugged in and power switch on it will light after some time and the projector works as normal. Any suggestion please email
Apr 22, 2008 | SIM2 Televison & Video
SIM2 HT300 Multimedia Projector Logo
590 people viewed this question
Top SIM2 Office Equipment & Supplies Experts
Jerry Umali
Are you a SIM2 Office Equipment and Supply Expert? Answer questions, earn points and help others
