Question about Sharp Office Equipment & Supplies
Solution TO sharp photocopier ar-5516 4 H error
Press the following buttons fast: #, interrupt, C, interrupt, C, 14, Start button.
Posted on Apr 22, 2013
  • supun lakshitha
    supun lakshitha Apr 27, 2015
    its really good & work successfully
  • chenemi Aug 17, 2015
    Thank you guys...u are the best...it works preety fine
    President:
  • 2,072 Answers
Normall on an sharp machine, You press # * C * and that will enter diagnostics. Then you enter 14 , then 1, and press start. It is the procedure to reset an H4. Works 99 percent of the time.
Posted on Oct 06, 2010
  • 28 Answers
SOURCE: i have photocopy sharp ar-5516 and when i switch
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
press 14 and start key twice.
copier should restart normaly.
If not, then you have problems with the fuser, contact me to tell you what you have to do next.
Regards,
Adi
Posted on Nov 05, 2010
Testimonial: "thanks a lot it was very helpful"
  • 3 Answers
SOURCE: a new sharp ar 5316e photocopy machine photocopy blank
change the main charger because based on my experienced it has an arching problem
Posted on May 23, 2009
  • 120 Answers
SOURCE: how to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
Posted on Jul 09, 2009
SOURCE: sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Posted on Aug 25, 2010
SOURCE: Sharp AR-5316 photocopier & printer driver
My sharp Photocopier 5316 Hang does not start .All Button show green indicator But does not work .How can solve my problem
Posted on Oct 25, 2010
HOW TO FIX ERROR CODE 444 BLINKING FOR SHARP AR-5516?
http://www.sharpmea.com/cps/rde/xbcr/documents/documents/om/34_ppc/AR5516-D-5520-D_OM_GB.pdf
May 20, 2014 | Sharp AR-5320 Black and White Copier
My Printer is displaying an H4 error
The error code H4 means that you have a problem with the fixing unit. It could one of the item's > The thirmistor or thermal fuse or the fixing heater lamp
Oct 05, 2012 | Sharp Office Equipment & Supplies
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5516 driver free download for xp
Drivers for Sharp AR-5516 are available at Sharp Official Support site Click here and make selections as under: -
Select
1. Photocopiers
2. AR5516
3. Windows XP
Download the required Drivers/ Utility.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Aug 06, 2011 | Office Equipment & Supplies
Sharp ar5516s printer driver
Drivers for Sharp AR-5516 are available at Sharp Official Support site Click here and make selection as under: -
Select
Photocopiers > AR5516 > Windows (XP, Vista, Windows 7 etc) Depending upon the OS you have.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Apr 07, 2011 | Sharp Computers & Internet
Sharp ar 5516 printers error h5. h4
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
2,676 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
