Question about Datacard SP35 Printer
Receive error code DR 00903 when trying to print
Oven Lock stuck open before start of self-cleaning cycle I get a code F9, a flashing lock light, a continous beep and a dr code on the panel when I try to set self-cleaning cycle again.
Thank you for your inquiry, Lucie!
From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Apr 30, 2015 | Frigidaire Stove/Oven/Range Black Glass...
Frigidaire Affinity ATF7000E DR error code
Good Morning Friend,
I understand you are receiving a "DR" error code on your Frigidaire Affinity washer, model ATF7000E. The "DR" error code is stating that there is a possible problem with the door. This could also be a possible false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Affinity ATF7000E Front Load...
My hp deskjet f4180 printer will print but not scan
Dear Lorin,
Please provide me the following details:
1. May I know if the scanner was working fine before?
2. May I know if you have performed any settings changes or software updates?
3. What exactly happen when you try to scan?
4. Are you receiving any error messages?
Please get back to me with the above information.
Thanks and Regards,
Dr. Tony
Feb 11, 2014 | Office Equipment & Supplies
Dr Printer error Unable to connect to the server
Dear
You can use EPM(easy printer Manager) or smart panel. These files can down loaded from the samsung site. install and run in the PC it will show the status of the printer.
The red light blinks and printing is possible means get ready to replace the toner cart. with a new one.
Thanks. Printer Support SAMSUNG India
Apr 25, 2012 | Samsung ML-2510 Laser Printer
I am having trouble with the printer. The DR is working fine. It sounds like it is printing, however it does not. print. There seems not to be a problem with ink The printer is not printing. I...
Definitely you have a problem with the printer.
That will not prevent you from sending faxes out, but did you try to make a copy?
If the machine sat idle for some time, the ink in the jets would have dried, but this will not generate any error messages.
There are cleaning kits available, and they usually work.
May 31, 2011 | HP 1040 Plain Paper Inkjet Fax
I have an Onkyo DR-S2.0 dvd Receiver that will not turn on. That aside I'm trying to find codes for the remote in order for it to learn my Philips tv and my Yamaha stereo receiver. The remote is a RC-437M....
Can't help you with the turning on problem, but the remote doesnt use codes to control other devices it learns the signals from that devices remote. heres a link to the users manual:
http://www.intl.onkyo.com/downloads/manuals/pdf/dr-s2.0_manual_e.pdf
the programing procedure is on page 63
May 21, 2010 | Onkyo RC-549M LCD Remote Control
Error 0xb9000003
* Where exactly you are receiving this error, on the printer display or on in computer?
* When exactly you are receiving this error?
* Does the unit print a self test page? Steps are given below:
1. Load the paper tray with unused plain white paper.
2. Press Setup until Print Report appears on the display, then press OK.
3. Press OK again. The self-test report prints.
:) Dr Tony
Apr 17, 2010 | HP PSC 1610 All-In-One InkJet Printer
Datacard SP35 Printer Logo
1,358 people viewed this question
Top Datacard Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
james laughton
james laughton
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
