Question about Kenmore HE2 Plus Front Load Washer
I get an F-21 error message - Kenmore HE2 Plus Front Load Washer
    Genius:
  • 1,417 Answers
This error code on a WASHER indicates a keypad short on the Electronic washer Control (ERC) board.
or an over flow of water in to the panel of the washer detected by the lens reader.
However,this is the clock/timer on the operator console. The recommended fix is to replace the ERC. You can generally find replacement parts at these websites:
searspartsdirect.com pcappliancerepair.com repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing an ERC is not a difficult repair and can be accomplished by the average do-it-yourselfer. If you decide to order the part and wish to repair this on your own, follow these steps:
1. UNPLUG the range. Dangerous voltage is still present inside even with the range turned off.
2. Pull the range away from the wall and turn the unit around so you can access the rear panel.
3. Remove the screws on the back of the operator console.
4. Carefully disconnect the connector plugs to the ERC. Take note of how they are connected, so that you can reinstall them correctly.
NOTE: The connectors are usually color coded with the colors printed on the circuit board. However, if the colors are not printed on the board, write them down. (A digital camera also comes in real handy for this).
5. With the connectors removed, remove the mounting screws to the ERC and the assembly will come out.
NOTE: Most replacement ERC boards do not come with the overlay. This is the plastic pre-printed number display. The overlay can easily be peeled off and re-used. Just make sure you properly orient the overlay so that you don't inadvertently place it on the new board upside down. If your existing overlay is damaged, you will need to order separately.
6. Install new ERC using the steps provided in reverse order. Minimize handling the new circuit board with your bare hands to avoid damaging the board.
hope this solution help?
Thank you.
Posted on Oct 06, 2010
My dell v313w printer gives the message that I need to replace cartridges even after I have put in new cartridges
Are you using Dell Series 21,22 ink cartridges?
Try Cleaning the Printhead on Dell AIO V313w, V515w, V715w, P513w, and P713W Printers
Troubleshooting Printhead Problems on the Dell AIO V313w, V515w, V715w, P513w, and P713W Printers
If you unplug the printer from the wall and remove the power brick for 60 seconds, this will reset any error messages the printer has. I would then plug everything back in.
Power on the printer.
Open the printer(with the power on) and take out the Dell Series 21, 22 black cartridge and then reseat it. I would then take out the color Dell Series 21, 22 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color side(right side)
photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 21, 22 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 21. 22 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It's possible to get a Dell Series 21, 22 ink cartridge with a bad sensor. I would take these back to the place of purchase for a replacement or a refund.
Rick
Apr 19, 2011 | Dell V313w AllInOne InkJet Printer
When I logon to my computer, 2 little error messages come up with the same message: Runtime error 21 025D49D2. I can exit out of one of them, but if I try to exit out of the second one my screen loses...
Having Problems With Error 21?
Cause: Error 21 takes place when the system is misconfigured or its essential files are missing. Such problems occur when a PC is not maintained properly and has accumulated many critical issues that require immediate repair.
Solution: To repair Error 21 correctly, download and install the repair tool below. This tool was design to successfully diagnose, find and fix the problems on your computer.
http://www.restoreguard.com/p/error-21.html?keyword=Error%2021&gclid=CKXWrq7il6UCFS9e7AodYkPWHw
I found this by google.com searched "run time error 21 025D49D2"
it came up with run time error 21....
click on this link above...
good luck...
Nov 11, 2010 | HP Computers & Internet
Im getting a lens error message on my h3dii ....message reads ... lens error id 21:1
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
May 22, 2010 | Hasselblad H3DII-31 Digital Camera
I have Hp Plotter 500 and i am getting error code 21:10.
your printer error message 21:10 is about service station or carriage problem, the fix steps follow here:
http://www.computercarefiles.com/TWI_Docs/bpp90134/default.html#P16_845
hope help you fix it. take a rating let me know how much helped you thanks!
May 21, 2009 | HP DesignJet 500ps InkJet Printer
I HAVE A PRAKTICA LUXMEDIA 7303 AND AN ERROR MESSAGE KEEPS COMING UP SAYING LENS ERROR 21
HAVE A PRAKTICA LUXMEDIA 7303 AND AN ERROR MESSAGE KEEPS COMING UP SAYING LENS ERROR 12 and 27
Aug 24, 2008 | GE A730 Digital Camera
F-21
replace the contol board
Apr 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Kenmore HE2 Plus Front Load Washer Logo
35 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
