Question about Dayton Vacuums
Need programing instructions for a Dayton time switch model # 1XC73A
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
Gas to oil ratio for dayton chainsaw model 2z971
Hi montorsewill...
You will use a 50:1 Oil to gas ration...1 pint of 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Sep 02, 2011 | Vacuums
I have a Diablo wall switch timer that was manufactured in 1982. It has 926Z on the back. If that is not the model number, I am in trouble. I have lost the operating instructions. Can you help?
Guess we'll just have to give up and throw this away....I've been holding on to one for 30 years, and I remember it being difficult to program anyway....
Jan 16, 2011 | Vacuums
I have a First Alert model 610 timer. It is an older model and I need the instructions for it.
I called First Alert @ (800) 323-9005 and they faxed me the instructions for Model LS510 which is the same and got it working. They will mail it too but not email. Choose Fixed or Random mode. Choose how many hours it will stay on after dusk. Turn your lamp off and unplug the lamp. Plug lamp into timer. Put function in Fixed or Random position. Put hours on switch to number of hours you want it remain on after dusk. Plug timer into the wall outlet. Turn the lamp's switch on and Timer's LED light should be on and the lamp should be off. Turn the lamp's switch off then on again TWICE. The second time you turn the lamp's switch on the bulb in the lamp will flach on then off quickly. This indicates that the Timer is controlling the lamp's operation. Leave the lamp switch in the ON position. The timer is now set for automatic. I hope this helps.
Jan 06, 2011 | Vacuums
I have a Model T25/2ED timer. Product #TN004000 I need to know how to program it?
I have the user instructions for the selecttime T25/2ED in Dutch and French in pdf format.
Contact me at andre.peeters3@telenet.be and I'll send it to you
Dec 28, 2010 | Vacuums
I need a manual for dayton wet/dry vac, 4YE65
Contact "Grainger" by Googling the name...wonderful company that practically invented Dayton
Dec 28, 2009 | Vacuums
I have misplaced my instructions and need to use it today
Thank You, but after I sent the FixYa mail yesterday, I finally found my instruction book.
I am not interested in a repair program at this time.
Diner
Aug 27, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Vacuums Logo
776 people viewed this question
Top Dayton Vacuums Experts
Are you a Dayton Vacuum Expert? Answer questions, earn points and help others
