Question about AT&T ATT Tl92278 Dect 60 Cordless Phones With Bluetooth(r) Cellular Connection
Does this answering system have a code to retrieve messages from a remote location?
The default code is 19. Pressing the setup button on the TL92278 and listening to the prompts will give you the default code 19 and the option to change it.
Posted on Jan 19, 2011
Testimonial: "Thanks. In the meantime I found the manual and you were right on target! Thanks."
Can I check my messages from a phone outside my home, is it possible to make a remote enquiry? And if so, how does it work?Thanks in advance for your answer. Regards, Joy
Remote Message Retrieval
You can operate your answering system from a remote location using any touch-tone
telephone or the handset.
Remote access away from home
You can check, play, or delete messages, even record a new greeting message when
you are away from home. Additionally, you can turn On or Off your answering system
from a remote location.
Remote access:
1) Call your telephone number and wait for the system to answer. If the answering
system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" in your owners manual.
3) The answering system announces the current time and the number of messages stored
in memory. You hear "To play incoming messages, press zero-two. For help, press onezero".
You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
For your convenience
a remote operation
card is provided for
you to use while
away from home, it can be found in the back of your owners manual.
Command Function
0 then 6 Answering System On
0 then 7 Memo Record/Stop **
0 then 8 Greeting Message Record/Stop **
0 then 9 Answer System Off
1 then 0 Help Guidance
Command Function
0 then 1 Repeat a Message*
0 then 2 Playing incoming Messages
0 then 3 Skipping a Message
0 then 4 Deleting a Message
0 then 5 Stop Operation
* For Repeat a Message function, press 0 then 1 within about four seconds to
repeat the previous message, or press 0 then 1 after about four seconds to repeat
the current message.
** For Memo Record and Greeting Message Record function, the first time you enter
the corresponding command, it starts the Recording function. If you want to stop
the recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the
system is in the command waiting mode. You may enter another command at this
time from the chart above.
6) When you are finished, hang up to exit the system. The answering system
automatically returns to standby.
Your machine automatically has a PIN set of 80.
If you are trying to use remote access from a cellular phone and having trouble: Try changing your tone length on your cell phone to long.
May 25, 2011 | Uniden Cordless Phone
How do I retrieve messages when I am away from home? Model # EXA15580
Remote access away from home first you must enter the PIN code: 1) Enter the Answer Setup menu, and then the Security Code submenu 2) Enter a two-digit PIN code (01-99) using the number keypad (0-9). 3)Press OK
You can operate your answering system from a remote location using any touch-tone telephone. 1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about 10 rings and sounds a series of beeps. 2) During the greeting message (or a series of beeps when the answering system is off), press 0 and enter your PIN code within 2 seconds 3)listen to the instructions from there (to play incoming messages, press zero-two)
Mar 19, 2011 | Uniden TRU8885 Digital Answering Machine
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Feb 28, 2010 | Uniden EXAI5680 Cordless Phone
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
Apr 14, 2009 | Lands Phones
Retrieving message
See if this works for you.
Remote Operation
When you are away from home, you can operate your answering system with any
touch-tone telephone.Use this function to check for recorded messages, to play or
2) During the greeting message, press 0 and enter your PIN code.
Command Function
0 then 2 Play Incoming Messages
0 then 3 Skip a Message
0 then 4 Delete a Message
0 then 7 Memo Record/Stop*
0 then 8 Greeting Message Record/Stop*
0 then 9 Answering System Off
1 then 0 Voice Prompts
If you forgot to turn on answering system the directions for that are here:
Turn on the Answering System Remotely
If you have forgotten to turn on your answering system, you can turn it on remotely
3) Press 0 and then enter your PIN code. The answering system announces the
4) Press 0 then 6 to turn the answering system On. You hear the outgoing message
Mar 18, 2009 | Uniden DXA15588-2 Twin Cordless Phone
How do I set a PIN to retrieve messages?
Remote code
A remote code must be entered when operating the answering system remotely. This code prevents unauthorized parties from listening to your messages remotely. Store any 2-digit number (00–99). The default setting is “11”.
1 Press {MENU}.
2 Scroll to “Initial setting” by pressing {V} or {^}, then press {>}.
3 Scroll to “Set answering” by pressing {V} or {^}, then press {>}.
4 Scroll to “Remote code” by pressing {V} or {^}, then press {>}.
5 Select the desired remote code by entering a 2-digit number (00–99).
6 Press {Save}, then press {OFF}.
Note:
To confirm the remote code, repeat steps 1 to 4. Press {OFF} when finished.
Feb 10, 2009 | Panasonic KX-TG2431 Cordless Phone
Remote message retrieval
When you first installed your GE Digital Messaging System, you heard the code that was auto set for it. Once you are out and away from home, phone home and during the answering machine promp press # and then the promps will ask you for your 'pass word [code]. Please be careful as messages deleted by you, you may not beable to retrieve them. This machine doesn't run by cassette tapes.
~ hope the above helps.
Jun 24, 2008 | GE (WMM317440) Answering Machine
Retrieve messages
To connect with your answering system:
1 Dial your telephone number from a touch tone phone. 2 When the system answers, enter your Remote Access Code. The system announces the number of messages and begins message playback. 3 Listen to your messages
Change remote access code Press [*] [#]. Follow prompts to set new code.
Apr 01, 2008 | AT&T 1818 Corded Phone
RETRIEVE MESSAGES
To retrieve a message from another location, dial the telephone number and when the greeting message starts punch in your four digit code. The default code is 0123 if you haven't set one. Follow the prompts to listen to messages.
Feb 14, 2008 | GE 29869GE2 Digital Answering Machine
Accessing the Answering System from another location.
from any touch tone phone by entering your 3 digit security code after you hear the outgoing message.
1. Dial the phone no. to which the answering system is connected to .
2. Enter the security code after you hear the tone.
3. Follow the voice menu to use the answering systems remote functions.
Review messages press 1
plack back messages press2
Stop message playback press 2 again
Erase message press 0 during playback
Skip message press 3
Turn off/on answer press 4
Review voice menu options press 7
Nov 27, 2007 | GE 27851 Cordless Phone
AT&T ATT Tl92278 Dect 60 Cordless Phones With Bluetooth(r) Cellular Connection Logo
110 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
