Question about Frigidaire Washing Machines
I have a FWS933FS0,washer, my problem is that its pushing water out on rinse cycle from the top of washer. i tried different wash cycles and check all hose but its keeps pushing the water out from the top bowl life side.
    Genius:
  • 1,417 Answers
This is a draining problem.
This problem can be cause by different reason here are the solution to solve the problem of your washing machine below.
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car,lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
  • thank you and thanks for using fixya.
    Posted on Oct 06, 2010
    My Kenmore compact washer with dryer on top, will not go from the first wash-rinse-drain-spin cycle to the second rinse-drain-spin-off cycle.
    Check and make sure the door is pushed all the way down until you hear a click. If it starts with the next cycle, then your door switch may be bad. It's a pretty easy fix, but I would watch a video at least before doing it yourself.
    Oct 09, 2016 | Kenmore Washing Machines
    Kenmore 70 series washer
    If you can see a constant water pressure from the hot and cold, chances are the water solenoid valves are ok.
    I would look towards resetting to factory and checking the main control unit.
    May 11, 2014 | Washing Machines
    Washer won t fill water
    pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
    contact your supplier after trying to go thru a few different cycles.
    Dec 04, 2013 | Frigidaire Washing Machines
    Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
    The typical cycle is;
    fills to selected water level
    agitates wash cycle
    drains wash water
    spins wash cycle
    fills to selected water level on rinse cycle
    agitates on rinse cycle
    drains rinse water
    spins final time
    end of cycle
    Aug 08, 2011 | Roper Washing Machines
    Hot water seems to not enter tub during washing cycle. all connections are correct and the hot water hose is hot up to the back of the washer, im baffled ? does the unit start with cold water on the first...
    They start with hot or warm ,what/ever the setting and rinse with cold water. Check the temperature adjustment and the cycle it's on as some do different things on different cycles.
    Dec 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
    Kenmore model# 110.23832100 will not fill up on rinse cycle
    See the Sears site for your washer.
    http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23832100+
    First, I'd try it on a different cycle.
    If it works, the problem points to the timer.
    Following is a description of how to access the console.
    http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
    Following also is a Whirlpool Service manual on top load direct drive washers.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
    Nov 21, 2009 | Kenmore 24032\24036 Top Load Washer
    Wash cycle stops
    This is a relativly simple solution... The washer probably wont spin either... Thanats due to a bad lid switch. Try replacing mthe lid switch and go from there.
    Apr 03, 2009 | Kenmore 24032\24036 Top Load Washer
    Won,t drain on rinse cycle
    Ok mc we need a timer at this point. You see the timer doing several steps different than before.
    Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    I also need the answer...
    where is the lint trap located
    Dec 06, 2007 | Washing Machines
    Maytag Neptune Top Load Washer - Rinse Cycle won't run - Machine says nF
    Sounds like the 'Wash water' is not pumping out fully,You need to drain the water by lowering the empty hose into a bowl & check the pump for a blockage ( if the pump is an 'electric one' check that it is working). TURN POWER OFF FIRST
    Oct 25, 2007 | Washing Machines
    Washing Machines Logo
    44 people viewed this question
    Top Frigidaire Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Charles T Nevin
    Charles T Nevin
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
