Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Convergence issues before diving into tv to fix something i need to know how to work the mute 183 menu
I have pretty much figured out the menu on my own i can probably point you in the right direction.
Posted on Jun 08, 2008
Samsung HCL4715w Hdtv convergence issue
Maybe you can fix it in the service menu.
Turn off TV, press mute then 182, Turn on TV and check out new menu items
Jan 24, 2013 | Samsung HCL4715W 47" Rear Projection...
Got new STK392-040 chips and picture is still distorted. Manual convergence still won't alligne all colors.
the 183 is entry into the tech menu===you need to test all the low value resistors around the convergence chips(only 6 or 8) and they will read low and a resistor with NO reading may be your problem.
Also these sets use a pico fuse going to each chip--either right with it or back at the source----know what a pico fuse looks like"
Mar 12, 2012 | Samsung HCM4216W 42" Rear Projection...
Replaced Convergence Board picture still bowed
did you replace the actual convergence ic's or just a small board ? these ic's usually begin with the letters stk392-????. they are about 2 inches high and 3 inches long..black with about 18 pins sticking out the bottom. replace both of them and do the adjustments with mute 183 and you will be good.
May 26, 2009 | Akai PT5598HD 55" Rear Projection...
Samsung HC-P4752W power and/or convergence problems
Sounds like you soldered two of the convergence pins together by accident. If its shorted the TV will shut down.
Mar 29, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung HDTV 1080I-Model#HCP4363W-Convergence Problem
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 21, 2009 | Samsung HC-P4752W 47" Rear Projection...
Can't access to adjust convergence on my rca R52WM24 tv.
not sure if this will work press mute 183 on remote control
Jan 10, 2009 | RCA R52WM24 52" HDTV Projection Television
Samsung SP-52Q7HE
Convergence ic need to be replaced.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 10, 2007 | Samsung HC-P4752W 47" Rear Projection...
Accessing sevice menu
i tell people all the time if you get into the service menu and hit the wrong buttons i wont know what you did to it again if you post here to ask how to get into the service mode you dont have the desire to find the codes on the internet which are readily available as are service manuals turn on the tv push mute on the remote till mute goes out hold down mute button and push menu on front of tv hit menu again when the s comes up hit 7 on remote and watch out you just figured how to reconverge your tv maybe not
Dec 06, 2006 | Toshiba 55H70 55" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
57 people viewed this question
Henry  Thomas
Henry Thomas
