I have a tempstar central heat and air unit and i need a wire diagram for a model pa5548aka4.
My tempstar central a/c unit will not get above 80 degrees during the day, the charge is fine so we are told, we noticed that the coils and fins are filthy and we have done everything to try to clean it out with a fin tool, fin brush and coil spray and there is still junk in it. we cannot remove it and clean it outside as i would love to do; its too involved to do that so we are trying to clean it in its place we have also sprayed it with a water hose and an air compressor, although it helped some i can still see gunk in it. my coils are on the bottom end of my inside unit. any advice on what else can be done to clean it well? my unit is only 7 years old. also i was told that i need to set my blower to high speed how do i do this and where is it located? thanks for any help or advice. my e-mail is map41269@yahoo.com
Posted on Jul 13, 2011
Tempstar Performance Series Heat Pump
damaged capacitor most likely. open the unit and see if theres any liquid spilling from the capacitor.
Aug 09, 2013 | Heating & Cooling
Heat pump will not turn on
I would call an expert, testing needs to be done, but based on what I have seen it may be the control board of the heat pump is defective.
Mar 24, 2017 | Heating & Cooling
I have a tempstar gas pack,when I cut the heat on the heat fires up, but the blower doesn't come on. I changed out the contactor and the capacitor,and had the blower moter checked and it is fine. I've been...
Does your fan work in auto. If not you may have a wiring problem. Be glad to talk to you and help. Call me at 251-540-2730 and I will give you a hand. Rus
Nov 28, 2009 | Ruud Central System Air Conditioner
Central air unit/ Lux500 thermostat
There is usually an overflow tray which has a shutoff valve when the tray is about to overflow water into your house. It is not located outside on your unit but inside where ever the condenser unit is. IF that tray is full of water, your unit will not turn on until it is emptied. Then you need to find out why the tray isn't draining...do you have a blocked drain pipe?
Jun 21, 2009 | Jackson 25 in. TempStar HH70 Free-standing...
Wiring Diagram for a Emerson Motor in a Tempstar Central A/C
EMERSON 1/4 HP MOTOR 5 WIRES BLACK BLUE BROWN WHITE RED LOST MY DIAGRAM 115V1075 RPM 3 SPD HOW DO I WIRE IT TO THE COMPRESSOR
Sep 26, 2008 | Emerson Heating & Cooling
Ac heat carrier thermastat model no.hh01ad042
GOto the iside unit itself. and remove the door and look for a terminial strip that the thermostat wires from the thermostat connects to and write down the colors wires and the letters they're connected to and connect the same to the thermostat .... they should be... r--red=power w-white=heat y--yellow=cool g-- green=fan! See which wires/ colors they're not using and bend back! Thank-you-very-much!
Aug 31, 2008 | Heating & Cooling
TempStar 10 AC
visit www.gotempstar.com for the schematic on this unit. Coincidentally, your air handler unit should not draw 15.6 amps with an additional 40 for the heater.
Jan 07, 2008 | Dishwashers
Heating & Cooling Logo
191 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
