Question about Whirlpool Refrigerators
Whilrpool chest freezer walls get hotter than normal, power light flickers on occassion, maintains correct cold temperature.
    Genius:
  • 1,122 Answers
NORMAL,CONDENSER COILS ARE IN THE WALLS,MAKE SURE THE COMPRESSER AREA IS CLEAN AND GETTING GOOD AIR FLOW,THANKS-MIKE
Posted on May 29, 2008
MFC09M3FW1
Most (if not all) chest freezers are not self defrosting. Normally, defrosting is not required for long periods because the hotter humid air will not setting INTO the cold freezer.
Dec 07, 2016 | Refrigerators
Green light on chest freezer flickering?
this just means the light is burning out (loosing its filament) it does not effect the operation of the freezer, it just is an indicator that you have power at the unit.
Aug 30, 2014 | Freezers
There are 3 lights on the front of the Zanussi Freezone. The green one on the left doesn't light up. What does that indicate? The red light on the right is on constantly. Does this mean that the freezer is...
Starting the Appliance
Insert the plug into the wall socket. The green pilot light will illuminate to show that the appliance is switched on. The red alarm light will also illuminate until the freezer reaches the correct temperature.
Alarm Light
The red alarm light will illuminate when the temperature in the freezer is higher than the thermostat setting. This alarm light will illuminate if:
- The appliance has just been started.
- Fresh food has been put in the freezer.
- The lid has been left open, opened frequently or open for too long.
The red light will go out when the freezer has returned to the correct temperature
Dado
Oct 14, 2013 | Zanussi 14.62 cu. ft. / 414 liter Chest...
Whirlpool Chest Freezer Not Cooling Properly After Brown Out
work should be performed by a qualified service technician. verify that there is proper voltage at the wall outlet using a voltage meter. if it is ok check for voltage to the compressor relay. if it is ok unplug the freezer and check for continuity at the start relay and overload. if it is open you have a relay or overload. if it is ok check for the ohms rating at the compressor. common to start/common to run, start to run should be the total of both. also start/run to ground if any of these are open you have a system problem.
Apr 30, 2017 | Freezers
Magic Chief Freezer MCCF7W power light is flickering, but no problems with temperature
Most likely loose connections at the light. Try removing and checking. Usually can pry loose with a flatblade screwdriver.
Oct 15, 2011 | Avanti 5.3 cu. ft. / 150 liter Chest...
Orange light in front is flickering almost constantly. What might this mean? The food seems frozen -ice cream is fine as are breads and meats.
It is normal for those lights ot flicker.. as long as the unit is working then do not worry about that...the light really is just showing you that you have power to the unit...
heatman101
Aug 26, 2010 | Kenmore 15 cu. ft. Chest Freezer 16542
Kenmore chest freezer model 12235 - won't get cold
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 13, 2010 | Freezers
Why does it get hot on the front and the sides it never did that before
If the food is at normal temperature, then what you are describing is normal.
On a chest freezer the condenser coils are embedded in the outer walls, as the evaporator coils are embedded in the inner walls to provide cooling.
This is the very basic principle of refrigeration. One set of coils (the condenser) are allowed to get hot, so the other set of coils
(the evaporator) can get cold.
When the unit is not running, which is most of the time, the walls will cool to room temperature.
Nov 03, 2009 | Haier 7 cu. ft. / 198 liter Chest Freezer...
FREEZER NOT FREEZING CONTENTS
I have a similar problem with danby and have been unable to get help - I now HATE Danby Chest Freezers
Mar 10, 2009 | Danby 5.5 cu. ft. / 156 liter Chest...
Freezer not freezing food even at highest setting
If the unit is running continuously and not maintaining the temperature cold enough the system may have a leak. If it is NOT running continuously the problem could be in the temperature control.
May 12, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Refrigerators Logo
64 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
