Question about Philips SA1110 MP3 Player
Player doesnt work cant repair on computer
My player says "Player problem! connect to pc" but when i do the philips device manager doesnt locate it, the phillips website said to reformat it to FAT or FAT 32 but the computer say" Windows was unable to complete format"
  • super_ned9 Mar 22, 2009
    I have a similar problem with my player. My player says "Player problem! Connect to pc", i connect it and the PC shows I have a new removable disk but every time I try to acces it, my windows explorer freezes completely. Therefore I can't format the drive or reinstall the firmware. Does anyone know how to fix this problem?
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Then run the Device Manager.
Posted on May 28, 2008
Hi team,i am facing problem with philips go gear 2GB player, Problem is :when ever i switch it on,"please connect to Pc and use device manager to repair" please help me in this scenario,explain...
I'm not a team member, but
1. Select your GoGear 2GB player from this list:
http://www.search.philips.com/search/search?q=GoGear+2GB&s=all&l=global&h=all&o=
2. When not having the program Philips Device Manager installed on your computer yet: Look under Software and Drivers, select the Device/Firmware Manager for your player.
2.1 Run the execute file Device Manager for installing the Device Manager toolbox.
3. Run Philips Device Manager:
  1. Having launched Philips Device Manager at Start -> Programs -> Philips Digital Audio Player -> SA2XXX -> Philips SA2XXX Device Manager on your PC
  2. Connect your player to the PC
  3. Device Manager should acknowledges your player and automatically goes into recovery mode.
  4. Follow the instruction of the Device Manager.
  5. After the player has been repaired, remove it from your PC and re-start.
If this was helpful I'd appreciate your answer.
When needing more help, just add a comment in this thread.
Feb 21, 2010 | Philips Audio Players & Recorders
Cant format mp4 philips sa312455
i can solve your problem..its an easy way.since you have specified that your computer doesnt recognise it, you have to generate the system file. you can do this by either record a voice and save the file in your device. then connect your device to your computer. it will detect it and you can format and upgrade . the only thing is somehow you have to record the voice in your device.
May 27, 2009 | Philips GoGear SA3245/37 Digital Media...
Connect to PC and use device manager to repair
If you have a Philips HDD Series, it will not work with Windows Vista or Windows Media Player 11 except for briefly, then the player will stop working one day. Your only hope is to use it with Windows XP and Windows Media Player 10 - it is, basically, an obsolete player at this point in time.
The Philips Device Manager has a strange feature - it only properly updates your device if you have the newest version of the Device Manager:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Update" tab
-Tha Mp3 Doctor
Mar 30, 2009 | Philips Audio Players & Recorders
Phillips gogear 6025 is not recognize by computer, code 28
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Feb 17, 2009 | Philips SA6025 Digital Media Player
I am not sure what happened but my daughter was pressing buttons and now my mp3 player is frozen and I cant even charge it. I cant turn it off and my pc doesnt even recognize it when i turn it on. What do...
-Tha Mp3 Doctor
Dec 16, 2008 | Philips GoGear SA3125/37 MP3 Player
NOT'''' RESPONDING
Connect your mp3 player to the computer.
Run the Repair function.
If the Device Manager does not recognize the player, connect the player to the computer (while the player is in the OFF position) while holding in the volume + button. Continue holding the vol + button for 5-15 seconds until a window pops up on the computer screen that says Found New Hardware Wizard. Follow the directions and it will lead you to do a Repair in the Philips Device Manager.
If this strategy doesn't work, your player is screwed. Call Philips and find out how to get an in-warranty replacement (or take it back to the store).
-Tha Mp3 Doctor
Nov 16, 2008 | Philips GoGear SA178 MP3 Player
I pod
Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.  Then click on the “Repair” button to start the repair process.  Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.  If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Aug 28, 2008 | Philips GoGear HDD6330 MP3 Player
Device driver problem
Grab the software directly from the Philips website at www.usasupport.philips.com - enter in your model #, click on software and drivers, then click on Device/Frimware Manager - this is a more recent version than that found on the installation CD.
Also, you can follow the FAQ process on the website which says "Player not recongized by PC"
If that fails, do a repair and a firmware upgrade:
1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
You will now be able to load the firmware upgrade by clicking on the update tab in Philips Device Manager. The firmware upgrade should resolve the issue permanently.
Jan 18, 2008 | Philips SA920017 MP3 Player
If you have the software conect the device to the computer; press volumen + with on/off switch at same time; then press volumen - anh hold it. The software recognice the device and you can update the firmware or repair it.
Aug 20, 2007 | Philips GoGear HDD6330 MP3 Player
Philips SA1110 MP3 Player Logo
136 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
