Question about Sony KDS-60A3000 60" HDTV
My Sony Bravia KDS-60A3000 tvturns its self off then back on within seconds. Some people say it is the lamp some say the ballast driver. What is your opinion?
  • Sony Master
  • 5,138 Answers
Lamp,if it was the Ballast Lamp will not come on because Ballast Board is what Powers Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Posted on Oct 07, 2010
5 blinks sony kds-60a3000
5 Blinks on this unit is not your lamp. Your lamp driver aka ballast is the problem. Very small chance that the G board is defective but I doubt it.
Mar 21, 2013 | Sony KDS-60A3000 60" HDTV
How can you tell if you have a bad lamp or ballast on the Sony DLP KDS60A3000
Remove and examine lamp to see if shattered--lamp has a 2,000 hour lifespan and may look good--if it fails the lamp light on sets front should light.
A ballast is harder to call--can check the approx 300 volts from the power supply to see if it shows at ballast.
Video instructions for lamp replacement are by model number available on You Tube for most sets.
Apr 03, 2012 | Sony KDS-60A3000 60" HDTV
My sony bravia kds-60a3000 loses picture, power button blinks, sound continues to work. The picture comes back on after an interval, then the cycle repeats. What is causing this?
Let your unit cool down for an hour, give proper ventilation and air flow. keep away all the obstruction from the vent, the processor has a built in thermal sensor that might be trigger by peak temp on the main board.
Hope it may help you.
Have a nice day.
Thanks for using Fixya.
Feb 10, 2011 | Sony KDS-60A3000 60" HDTV
I recently replaced my lamp, now my picture is dark. Do I have a faulty lamp? Could it be the ballast? Can I replace that?
Your Problem is the Light Engine/Optical Assy unit Block.
Encompass Parts Distribution 1-800-638-3328
Dec 09, 2010 | Sony KDS-60A3000 60" HDTV
Picture flickers on Sony HDTV
Hi,It seems your ballast(board that powers light bulb) is going weak.The ballast was used to provide a lower voltage because lamp didn't use as much as brand new one. A newer one takes more voltage and when ballast doesn't provide as much power it will flicker or produce a dimmer image.I found the one for your tv here: http://www.discount-merchant.com/1091041-KDS-60A3000-p/1091041.htm?Click=48173 Good luck and God bless you!
Jan 06, 2010 | Sony KDS-60A3000 60" HDTV
I have a Sony Bravia KDS-60A3000. I changed the lamp, plugged in the TV and it was working. Was trying to reset lamp indicator, power went off, red indicator light is blinking and cannot get TV to turn off...
I went to another tech site and saw a suggestion to unplug the TV for a couple hours and then plug back in to see if this helped, but they also indicated this could be a serious power problem. I was really concerned, but tried it and it worked! I think it was running some kind of diagnostics after the new lamp was placed. Back up and running!
Dec 31, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia KDS-60A3000 won't power up. Power light on front of unit turns green when you power on and picture appears for two seconds then powers off with tthe power light turning red and flashing nine...
First if you have had the set for at least two years, then its time for a new lamp. Replace your lamp and this should solve your problem. I don't know how long you have had ur television but lamps usually last about 6500 hours, thats a little less then 3years. But sometimes they go sooner. The lamp door should be located to the right of the unit on the side, if you are facing the television..
More Asistance email me at:
Delhielectronics@live.com
Sep 27, 2009 | Sony KDS-60A3000 60" HDTV
Sony Bravia KDS-60A3000 won't power up 9 flashing red power light
According to other posts I have read (I have same problem) there is no power getting to the fans. They recommend re-seating the fan harness again as it might have come loose or might have dust etc., in it.
I have no idea how to do this yet but that is what the trouble-shooting guide says.
Feb 25, 2009 | Televison & Video
Sony KDS-60A3000 60" HDTV Logo
484 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
