I have a barcrest fruit machine "bigshot" and it is set too free play like i want it too be for home. the bottom door u open on it where the cash boxes n power unit etc is obviously when u shut it it pushes a button in too tell it its closed but when i switch the machine on it alarms out every time, behind that button is a series of white wires linked too a white plug but that plug isnt connected too anything, could this be why its alarming out, and if so where does the plug go?
  • mr_all_dat Dec 03, 2010
    what does the alarm say, i should be able to help you out
    Top Expert:
  • Computers & ... Master
  • 15,371 Answers
Inside unit is a reset switch that your door key should fit or a toggle switch the ringing /alarm is a jackpot won or a jammed coin
Posted on Jun 03, 2017
  • 263 Answers
SOURCE: Whirlpool Frost Free 460 door open alarm
http://www.repairclinic.com check how to repace it with the schematic diagrams you'll see how
Posted on Jan 01, 2008
  • 150 Answers
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Posted on Apr 23, 2008
Witchunter
  • 98 Answers
SOURCE: KM18G pro motherboard power connection, reset sw, power sw, etc.
Hi.
You can download the manual for your motherboard here.
Inside you will find information of where does each connector go. Each connector on the case has a marking on it (HDD, PWR, RST or similar) which stands for hard disk LED, power button, reset button and so on. Connect it to the right place, and problem is solved.
If you need any further assistance, feel free to ask.
Your responses are intended to improve the level of service provided. Please rate your experience.
Posted on Jan 18, 2009
mukund_ce
  • 186 Answers
SOURCE: motherboard installation
Just download manual and check configurations:
http://www.opendrivers.com/driver/265244/emachines-c6415-user-guide-free-download.html
Posted on May 16, 2009
  • 10 Answers
SOURCE: front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Posted on Jul 29, 2009
Fruit is freezing in the bottom drawer of the KitchenAid KSCS25FKSS Side by Side Refrigerator
There is a chance that your refrigerator needs defrosting. Remove everything and unplug your refrigerator, open the doors and let stand for 12 hours. Sometimes the air vents restrict with ice causing this trouble.
http://www.on-timeapplianceplano.com/refrigeratorrepair.html
Jul 23, 2012 | KitchenAid KSCS25FKSS Side by Side...
Iv got a fruitmachine tresure island and its saying 1.6 note mec error and wont work how can i solve this problem it dont have a note meck in he machine
it normally means that there is a not stuck in your note acceptor, is it a barcrest machine?! if so then you need to open both the top door and the bottom door, there should be 4 butterfly wingnuts, by the reels as you open the top door you need to undo them so that the pay tray hangs down, now you should see a black box on your left hand side (the note acceptor) above it (by where the wingnuts used to be) you need to undo 2 posi screwdriver bolts that will release the note accpetor, take it out check to see if there is a note in there and blow and clean, reconnectit and reverse what you have done, hope this helps, anymore questions just ask, cheers Tom
Oct 31, 2010 | Video Game Consoles & Games
How do i empty the pond box on my fruit machine its a king ko bandit
you need to enter the bacta std test routine by pressing the test button and function button on the main circuit board. you will here a cash sounding noise when both pressed together for 2 seconds. look on your display and use start to scroll along to test coin out. press cancel to emit your coins then close the main door when you have finished for main game play.
Feb 28, 2010 | Video Game Consoles & Games
Fruits & Veggies are freezing in both lower frig compartments
Good day,
This problem appears in spades this time of year, every year.
The problem becomes more severe when the temperatures in the house cools down and is made even worse if the usage of the machine becomes lighter.
It occurs when the machine is off, not on.
There is an open vent, near the bottom, between the freezer compartment and the fresh food compartment. This opening or vent is necessary when the machine is running, so that the air pumped into the top of the fresh food section, can return to the freezer compartment. This is by design.
Now,
When the machine is off, the zero degree air from the freezer compartment. can drift into the fresh food compartmnet and drop the temps near the bottom to below freezing.
Off time increases substantialy at this time of year.
Some have even recommended turning the controls colder to offset the problem, but I've no proof it works well, or even a little.
SXS and top freezer models experience it more than bottom freezer models.
Dec 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Alarm says 17-83 opto blocked tamper
Hi did you every solve this problem? i have the same problem currently
Jul 19, 2009 | Kitchen Appliances - Others
Fruit machine manual
Hi i have a barcrest vivid gaming machine, rock around the clock and i need a service manual can anyone help.
Aug 08, 2008 | Video Game Consoles & Games
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
