What dooes task pane do - Computers & Internet
  • 570 Answers
Microsoft Office feature found in Microsoft Office 2002 (XP), Office 2003, and later versions that enables users to have quick access to common features, information, and commands. By default the Microsoft task pane opens on the right hand side of the window. Users who need access to the task pane and are running a compatible version of Microsoft Office can quickly get to the task pane by using the keyboard shortcut CTRL + F1 or by clicking View and then Task Pane.
Thanks.
Posted on Oct 06, 2010
Vista Home....Automatic restore points are not being saved....I can manually enter them and they show up on the drop down table....I have both drives checked off to allow automatically creating restore...
Hi g502,
Here are some helpful tips that you may use on how to Change the Automatic System Restore Point Settings in Vista Task Scheduler.
By default System Restore is scheduled to create a restore point at 12 AM every day (Daily trigger) and at every system startup (At startup trigger) in Task Scheduler if any system changes were made from the last time it checked. This will show you how to change these schedule settings, or disable one or both triggers.
Warning:
System Restore will need to be turned on for this scheduled task to be able to run.
1. Open the Start Menu.
A) In the white line (Start Search) area, type taskschd.msc and press Enter.
B) Go to step 3.
OR
2. Open the Control Panel (Classic view).
A) Click on the Administrative Tools Icon.
B) Click on Task Scheduler.
3. Click on Continue in the UAC Prompt.
4. In the left pane click on the triangle next to Task Scheduler Library, Microsoft, and Windows to expand the folder tree. (See screenshot below step 5)
5. Click on the SystemRestore folder.
A) Choose a option or options below to do.
OPTION ONE
To Disable or Enable this Task Completely
6. To Disable this Task Completely -
NOTE: This will disable both the Daily (OPTION TWO) and At startup (OPTION THREE) triggers regardless of how they are set individually. You will not have anymore automatic restore points created with this task disabled. You can still manually create a restore point though. For how, see: How to Create a System Restore Point in Vista
A) In the middle pane, right click on the SR task and click on Disable. (See screenshot below step 5)
B) Go to step 22.
7. To Enable this Task Completely -
NOTE: Check to make sure that each Daily (step 12 in OPTION TWO) and At startup (step 17 in OPTION THREE) trigger is also set as Enabled.
A) In the middle pane, right click on the SR task and click on Enable. (See screenshot below step 5)
B) Continue to OPTION TWO.
OPTION TWO
To Change Only the Daily Trigger Settings
NOTE: You will need to have the task enabled in step 7 to use this trigger. This is the trigger that creates a restore point at 12 AM every day by default. If you do not want to change these settings, then continue to OPTION THREE.
8. In the middle pane, right click on the SR task and click on Properties. (See screenshot below step 5)
9. Click on the Triggers tab. (See screenshot below step 10)
10. Click on the Daily trigger to highlight it and click on the Edit button.
NOTE: These are the default settings for the Daily trigger in the screenshot below.
11. To Disable the Daily Trigger -
NOTE: This is if you only wanted to have restore points create with the At startup (OPTION THREE) trigger instead.
A) Uncheck the Enabled box and click on OK. (See screenshot below step 12)
B) Continue to OPTION THREE.
12. To Enable the Daily Trigger -
A) Check the Enabled box. (See screenshot below)
B) If the default settings for the Daily trigger schedule are not what you want, then make any changes that you would like.
NOTE: For more details about each of these settings, see STEP FIVE here: How to Create a Task in Vista Task Scheduler
C) Click on OK.
D) Continue to OPTION THREE.
OPTION THREE
To Change Only the At startup Trigger Settings
NOTE: You will need to have the task enabled in step 7 to use this trigger. This is the trigger that creates a restore point at every system startup by default. If you do not want to change these settings, then continue to OPTION FOUR.
13. In the middle pane, right click on the SR task and click on Properties. (See screenshot below step 5)
14. Click on the Triggers tab. (See screenshot below step 15)
15. Click on the At startup trigger to highlight it and click on the Edit button.
NOTE: These are the default settings for the At startup trigger in the screenshot below.
16. To Disable the At startup Trigger -
NOTE: This is if you only wanted to have restore points create with the Daily (OPTION TWO) trigger instead.
A) Uncheck the Enabled box and click on OK. (See screenshot below step 17)
17. To Enable the At startup Trigger -
B) To Speed Up Startup Time - Make sure that under Advanced Settings, the Delay task for box is checked and you have an amount of minutes set that you want for System Restore to run after startup.
C) If the default advanced settings for the At startup trigger schedule are not what you want, then make any changes that you would like.
D) Click on OK.
E) Continue to OPTION FOUR.
OPTION FOUR
To Change the Conditions for the Task
NOTE: You will need to have the task enabled in step 7 first. This will effect how both the Daily (OPTION TWO) and At startup (OPTION THREE) triggers run. If you do not want to change these settings, then continue to OPTION FIVE.
18. In the middle pane, right click on the SR task and click on Properties. (See screenshot below step 5)
A) Click on the Conditions tab. (See screenshot below)
NOTE: These are the default settings for the Conditions tab in the screenshot below.
B) Make any changes you would like.
NOTE: For more details about each of these settings, see STEP SEVEN here: How to Create a Task in Vista Task Scheduler
C) Continue to OPTION FIVE.
OPTION FIVE
To Change the Settings for the Task
NOTE: You will need to have the task enabled in step 7 first. This will effect how both the Daily (OPTION TWO) and At startup (OPTION THREE) triggers run. If you do not want to change these settings, then continue to OPTION SIX.
19. In the middle pane, right click on the SR task and click on Properties. (See screenshot below step 5)
A) Click on the Settings tab. (See screenshot below)
NOTE: These are the default settings for the Settings tab in the screenshot below.
NOTE: For more details about each of these settings, see STEP EIGHT here: How to Create a Task in Vista Task Scheduler
C) Continue to OPTION SIX.
OPTION SIX
To See the Task History
NOTE: This will show you what the run and error history for this task is. This can be handy to help troubleshoot any problems with the task, or you just want to see when it ran. If you do not want to see the history, then go to step 21.
20. In the middle pane, right click on the SR task and click Properties. (See screenshot below step 5)
NOTE: You can also just click on the History tab in the bottom half of the middle pane instead.
A) Click on the History tab. (See screenshot below)
NOTE: In the bottom pane you can get more details about a selected history event listed in the top pane.
B) Go to step 21.
21. Click on OK. (See screenshots from below either steps 10, 15, 18B, or 19B)
22. Close Task Scheduler.
Hope it helps
Thank you for using FixYa.
Aug 31, 2011 | Computers & Internet
Tip
Enable Task Manager
Some Malware and Trojan often disable access to Windows Task Manager. Fortunately, a few quick Registry edits are usually all that are needed to regain control.
Here's how to do it:
  • Click Start
  • Click Run
  • Type REGEDIT
  • Click OK and The Registry Editor will now open
  • Browse to the following key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\system
  • In the right pane, look for the value: DisableTaskMgr
  • Right click DisableTaskMgr and select Delete. (When prompted with "Are you sure you want to delete this value", select Yes.
  • Now browse to the following key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\system
  • Close the Registry by choosing File | Exit
  • Restart your computer
You should now be able to access Task Manager. If not, reboot into Safe Mode and repeat the steps outlined above.
on Jan 26, 2010 | Computers & Internet
Laptop hanging off
If your laptop is hanging while you are working, press this combination keys:
Ctrl Alt Del.
If you are using windows XP, it should automatically take you to task manager.
But if you are using windows vista or windows 7, it would show you options, of which you are to select 'task manager'.
End the tasks the are not responding by right clickin it and selecting 'end task'.
If that task still refuses to end, still in the task master pane, go to 'processes'.
Select the processs running the nonresponsive task. Eg, if internet explorer is the non responsive task, the process would be 'explorer.exe'.
End that process.
If it stil doesnt work, then select 'end all processes', and restart the system.
Hope this was helpful?
Success.
May 14, 2011 | Sony VAIO VGN-FW170J/W 16.4" Laptop
My loptop is honging off
Ctrl Alt Del.
End that process.
Success.
May 14, 2011 | Sony VAIO Notebook
Printer not printing.
Follow these steps to resolve the issue. Windows XP
  1. On the Windows taskbar, click Start, and then click All Programs.
  2. Click Accessories, and then click System Tools.
  3. Click Scheduled Tasks. The Scheduled Tasks window opens.
  4. Under Name, click and delete any task that starts with Webreg (for example, Webreg 20031218075500).
  5. Close the Scheduled Tasks window.
Windows Vista
  1. On the Windows taskbar, click the Windows icon (c01319360.gif).
  2. Right-click Computer, and then click Manage. The Computer Management window opens.
  3. In the left pane, click the arrow next to Task Scheduler, and then click Task Scheduler Library.
  4. Under Name, find and click any task that starts with Webreg (for example, Webreg 20031218075500).
  5. In the Actions pane, click Delete.
  6. In the Confirm delete dialog box, click Yes.
  7. Close the Computer Management window.
Windows 7
  6. In the Task Scheduler dialog box, click Yes.
Jul 19, 2010 | HP PSC 1510 All-In-One InkJet Printer
Shut off my Dell last night. When to sign in in the morning and when I did the Ctrl, Alt, Delete - nothing happened. is it shot or can i fix it ej
possible fixes:
1) run antispyware and antivirus
2) In XP PRO then try turning the Task Manager Disable facility on and then off again. It should be set to off or 'not configured'.
For turning Task manager On/Off
Start, Run, type gpedit.msc,OK
In left hand pane Double click Admin Options.
Double click System,
Click Ctrl, Alt, Delete.
Then in right hand pane double click Ctrl, Alt, Del. This opens up 'Task Manager Disable/Enable' facility..
Setting on radio buttons should be either disabled or 'not configured' If so select enable (this turns Task Manager Off), Apply, OK.
Oct 09, 2009 | Dell 0Y3740 Keyboard
I can not type anything in MS word 07. I have the full version. The windows says "This modification is not allowed because the selection is locked." ANyone can help? Please...with million thanks.
This is an error that happens when you try to modify or use a document that is locked.
1. Open the document
2. Select the Devloper tab
3. Click on "Protect Document"
4. On the Restrict Formatting and Editing Task Pane on the right side of your screen, Click on "Stop Protection" on the bottom of the task pane
5. If there is no password, you can start using the document
Mar 28, 2009 | Microsoft Office Professional 2007 Full...
Windows Vista Many Taskeng.exe processes
1. Go to the start menu.
2. Type task scheduler and press enter.
3. Press continue on the UAC popup.
4. In the left pane of task scheduler, underneath Task Scheduler Local, right-click on Task Scheduler Library.
5. In the View submenu, make sure the Show Hidden Tasks option is checked.
6. Widen the Name column in the center pane. The hidden task that is likely at fault has a name that starts with User_Feed_Synchronization, followed by a dash and a bunch of digits inside a curly brace.
7. Select that task in the middle pane by clicking on its name.
8. To verify that this scheduled task is creating all those taskeng.exe processes, select the History tab in the middle pane near the middle of the screen. If you expand out the Level and Date and Time Columns, you should see a bunch of errors and date and times that are 5 minutes apart. If that's the case, then this task is the problem.
9. On the rightmost pane, select Disable.
10. There may be more than one scheduled task like this, so you'd need to disable any or all that were causing problems.
P.S.: If this information was helpful, please rate this solution.
Mar 13, 2009 | Microsoft Windows Vista Home Basic for PC
Missing shortcuts in MS Word 2003
Open WORD
Go to TOOLS
Select OPTIONS
In VIEW tab check 'Startup Task Pane'
Close WORD to save changes
Open WORD and Task Pane should be back!
Feb 26, 2009 | Microsoft Office Word 2003 for PC
Software Problem!! Design task pane not popping up!!!!
I had this happen to me as well, I'm not sure if I remember what I did to correct it but I think I left the frame in place and closed up the futura program and turned off my machine. waited a minute and reopened everything in the proper sequence. then reopened the design I was working on.
Apr 05, 2008 | Singer CE-200 Quantum Futura Computerized...
Computers & Internet Logo
145 people viewed this question
David Payne
David Payne
