Question about HP vs19 (Silver) 19" LCD Monitor
Hp vs19e lcd sreeen stoped working power light button does not come on, the monitor is around 4 years old is it worth fixing or time for new one?
    Novelist:
  • 112 Answers
For what it would cost to fix that 19 " you can buy a 20 +" on sale. And with H.D.
Posted on Oct 06, 2010
  • 11,361 Answers
If you have it repaired by the shop then it will not be worth it, if you want to DIY repair then you need to buy proper tools.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Monitor will not power on
The monitor has entered permanent sleep mode. After four years of service, it probably is not worth repairing
Oct 21, 2012 | HP W2408H 24-inch Widescreen LCD Monitor
My HP vs19e monitor takes almost 5 minutes to "wake up". Works fine once running. It never took this long before. Any ideas?
most common problem is bad electrolytic capacitors if unit is a few years old. Take it apart and replace any swollen, ie bulging top of the aluminium can... but may be 'off-value' if not swollen. Any electronics from China will fail within 3 years due to bad electrolytic caps..
Sep 07, 2010 | HP w19 19" LCD Monitor
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
HP vs19e monitor is blank. Power button is slowly
that is not a monitor problem that is a cpus problem disconnect the signsl cable and connect power cable you will see the post (power on self test) open the cpu draw the ram clean the dust and reinstall the problem will solved
Feb 26, 2010 | HP vs19 (Silver) 19" LCD Monitor
I have HP vs19e and was happy with it, worked perfectly. But, by no reason, it turned out for good. No, after it happened for the 1st time it rested for about 1 hour or so and started to work again. But no...
i repair one and i'm totally novice in electronic ... look if some condensators are inflated and try to change it ... it is not very complicated with a little soldering iron ... i repair 2 monitor like that without testing anything it is often condensators i think (u can find some in old motherboard card) .... if it doesn't run ... matter is more important and you probably win time to change your monitor ... good luck ;-)
Dec 10, 2009 | HP vs19 (Silver) 19" LCD Monitor
Screen goes black to grey
LCD circa 2004 (old)
what is your question,
1: is it bad, sure it,is, if it fails on 2 PCs, and cable is ok.
2: if it fails its own OSD tests its bad.
of has OSD lock the free manual tells you how to UNLOCK this feature. (the hold button trick)
3: how to fix it.? asking how to fix a LCD here?
the parts for it , inside might be found on ebay, this old.
pigs in a poke sack....
there is no schematic for it, google it ?
black to gray is my only clue here.
if the OSD is dead the black lamp is bad, or its inverter
if the back lamp is ok, then the LCD power is bad or it's logic bad or lack of power. (DC rails)
http://h10032.www1.hp.com/ctg/Manual/c00277016.pdf
Jul 09, 2017 | HP vs19 19" LCD Monitor
No plug in play... don't think their dead... do I need drives first?
no country stated or if not usa what is your line power?(volts AC)
your PSU is inside monitor not outside, so uses a simple line power cord. (just wires)
12 year old monitors, found, (dead)
page one of your user guide is clear, read it yet?
seems not.,
Auto-ranging, 90 to 265 VAC
1280 x 1024 @ 60 Hz, 75 Hz (never higher) resolution settings.
those are very old monitors.. worth like $10 used.
if the power lamp shows wrong, the monitor is dead.
right button is power to the right of it is a power led that must glow.
the old monitors had CCFL backlamps before year 2010.
those are back lamps, that fail fast. 20k hours, fast. (short)
first is the power switch
2nd is a working PC with at least sync signals on 2 pins
Horz/vertical.
then the OSD screens work of not the monitor IS DEAD.
inside this OLD monitor is sleep time, turn if off with OSD menu's its nothing but trouble.
some have an OSD lock, so hold the menu key for 10 seconds
and it unlocks. button 2 from left is MENU.
see page 4-10
the guide is here. not too good , poor diagnosis sections
http://h10032.www1.hp.com/ctg/Manual/c00276671
specs.
https://support.hp.com/us-en/product/hp-l1940-lcd-flat-panel-monitor/427303/document/c00278650#AbT3
testing
power it on, LED power , glows.
with a PC working, say running any BIOS screen only....
or running, windows, in low resolution mode 1280 x 1024
if wise set the pc up to that first. not second.
then plug in the vga cable so the MOnitor only sees that signal above. (if you do above wrong, monitor shows OUT OF RANGE on the screen)
at mon.
PUSH the OSD button, menu, if OSD is dead the montor is dead.
OSD= on screen display., (yes the LDC has brain inside)
then take a flash light . point it at screen
see data now, if yes, in the beam is data the back lamp is dead
as are most 12 years old montors now.
see those 4 cream colored connectors bottom of this PCB
those are the high voltage CCFL lamps.
2 lamps 4 ends. the lamps are bad or the board 500 to 1000vdc
power supply is dead.
Sep 20, 2017 | HP L1940 19" LCD Monitor
I want to replace the power switch board on my hp vs19e monitor.
About your only hope for getting a replacement switch is to buy a "Parts Only" monitor off of EBay and carefully remove the switch. This one is tricky it's attached to the front bezel as you've likely found out. When you disassemble the monitor, lay it face down and remove the bac plastic then remove the 4 screws holding the button board on then take the rest apart. That's the safest way.
Mar 28, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Hp vs19e
try to see maybe it is mute or inspect the connection of your speaker to your audio jack.i think there is loose contact of your speaker.
Feb 15, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
HP vs19 (Silver) 19" LCD Monitor Logo
139 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
