Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
I have a kodak 5500 printer i have cleaned the printhead many times installed new ink cartridges color and black but i have no black when printing also the color seems to be a little lite ?
You can buy a new printhead for 5500 for £25 from Kodak just phone on 0870-2430270. Cliff.
Posted on Oct 14, 2010
My printer only prints color..have installed new black cartridge but still only prints color so installed another new black cartridge and still only prints color
Unlike most printers where the print cartridge and printheads are attached and sold together, the ESP 3 has a separate printhead from the cartridges.
Remoe both cartridges. Then look at the place where the cartridges sit. There is a latch you push down in the back. This will release the printhead to allow it to be removed.
Remove the print head
Take a cotton swap and a little alcohol and clean the printhead of all ink. Repeat this until it is totally clean.
Make sure the printhead is dry and clean of all ink and alcohol.
Replace the printhead.
Place cartridges in and test.
If this does not work, then you need a new printhead for this printer.
here is an example of how to remove and replace printheads for thsi unit.
http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
to gt a new printhead you must contact kodak
http://www.kodak.com/go/contact
probably as expensive or almost as expensive as a new printer.
The seperate printhead from the carts are why kodak can have their ink so cheap. Those other brands cost that extra 15-20$ for the attached new head with each cart.
Jun 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Same proplem kodak 5500 aio black ink not printing. color works fine
Kindly reseat the cartridges 2 times and then close the access door .Click on Menu on the printer and scroll down and choose Clean printhead and select "deep cleaning"
Print a demo sheet after the cleaning process has been completed. If ur issue persists, Call Kodak @ 1800 421 6699 and they will replace printhead of the printer free of cost.
Printhead is the part which takes the ink out from the cartridges. Probably the printhead of the printer has gone bad..
Nov 22, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I haven't used my Kodak 5500 printer in a little over a week and now I'm trying to print out pictures and with a new black cartridge, it's like there is no black ink. However, I just printed out a word...
Since that you already did a good troubleshooting cleaning the printhead and calibrating It and replacing the printhead., I just want to ask this How many times you already replace a printhead if its newly installed it means the problem is in the printer itself and for that you need to call kodak for printer repair toll free 1 800 421 6699
Now if the replacement printhead is more than a month and you already did all the troubleshooting it means the nozzle of the printhead is clogged you need to call kodak for printhead replacement
GudlucK
Nov 04, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
My kodak 5500 AIO easy share printer will not print black ink.
follow the step by step solution from kodak.
Choose All-in-one printer and then Print quality and follow the further steps. I think it's a problem with your printhead.
Oct 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Easyshare 5500 prints very light even after cartridge replaced
Hi!
You'll need to call KODAK to get a new printhead. The # is 1.800.421.6699. This is a very common issue, and they will give you a new printhead and a set of new ink.
Jan 28, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Please call 1.800.421.6699 and select option 01 for prints missing black or color ink. Kodak will send you a replacement printhead kit for free. I hope this helps.
Jan 27, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
I've changed the black ink cartridge but it won't print in black
Sounds like there is a problem with your printhead. You need to clean it using the printer itself (menu -- clean printhead -- deep clean). If this does not work, go to kodak.com/go/itg to get your printhead replaced, free of charge.
Dec 18, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5500 will not print with black ink
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Aug 17, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
Jun 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak Easy Share 5500 will not print anything with black in it
Go here:
http://www.kodak.com/go/aiotroubleshooting
Within the tool, select Print quality, then No black, missing text, or text quality.
After answering all the questions (assuming you haven't abused your printhead) you will be prompted to enter a service number, name, and address to be mailed a replacement printhead.
I just went through this and was told my printhead would arrive in 2 to 5 business days.
Feb 11, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
147 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
