Question about Thomson SpeedTouch 330 ADSL Modem
I need username And Password to Speedtouch modem
    Guru:
  • 124 Answers
Usually the username and password for this are : admin for username and admin also for password. Sometimes the pasword is 1234. If someone change the password then you can hard reset the adsl modem by pressing and holding a small hole ( usually on the side, its in the manual ) using a pen or a pin. Then the username and password will be in its default. Just check the manual. Sometimes the username and password is also written in the box or underneath the adsl modem. If this does not work, you can try calling your ISP.
Posted on Oct 06, 2010
Need username and pwd
To access the configuration: The default user is 'Administrator' and the password is blank.
Make sure you have your DSL username and password to log into you DSL service. If you don't have it your service provider can give it to you.
If that doesn't work find the reset button on the back. Do not use the front reset. Hold the reset buttion in until the power led flashes red. This should reset the unit back to factory. You will need probably need you DSL username and password to re-configure the router.
Mar 06, 2010 | Thomson RCA DCM245R Modem
No internet connection
Check if you can , by pass the wizard and set the connection manually. Let me find more details for you
Thanks
proton
Jul 24, 2008 | NetGear RangeMax WPN824 Router
Do i have un install my speed touch modem to install netgear dg834v5
Hi, please note that speedtouch modem and DG834G router will not work together. Rather DG834G will replace the speedtouch modem. Remove the speedtouch modem and follow the below steps:
1. Connect the cable/phone line coming from Internet Service Provider to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports.
3. Open the browser(Internet Explorer or Mozilla Firefox).
4. Access the router (usually http://192.168.0.1).
5. Login to the router (Username = admin Password = password unless you have changed it).
6. Click 'setup wizard'(at the top of list) from left menu.
7. Select yes and click next.
8. It should give you a "PPPoA Detected" and then click next.
9. Enter the login and Password of ISP click apply.
10. Once the settings are updated click on 'router Status' and click on 'connection status' button(at the bottom of the page).
11. Click on connect button.
12. Connecting to server should show 'connected'.
13. If you receive 'CHAP authentication failed', close the 'connection status' window and click on 'Basic settings'. Check the login and password for ISP and apply the setting again.
14. Open up another browser window and try to access internet.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Nov 05, 2009 | NetGear DG834G Router
I want to know how config speedtouch usb modem in open suse 10.2 *can u told me web site can i download rpm fron it
if you are using speed touch 330 usb modem configuration is like this...
install modem drivers this would installmodem drivers.
then go to start, programs speed touch>> then selest Speed touch USB then it would give you a pop up for dial up connection, click on properties, then click on configure here you can change the speed. else go back chcek username and password and dial. should be able to connect. If you need anyother information other than this please go to speedtouch.com
Mar 24, 2009 | Computers & Internet
DSL Flashing
You dont need both. Do the following:
Unplug your speedtouch from the phone line at the back of the speedtouch unit. Plug that cable into your Zoom. Then plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Nov 23, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
Thomsom speedtouch router
set your router to Protocol = PPPOA, VPI = 0, VCI = 38 Encapsulation = VC-MUX , your username is usually your phone number followed by @talktalk.co.uk or @talktalk.net & your password in the password box (these should be on the letter sent by talktalk when you registered.
Feb 09, 2008 | Computers & Internet
Speedtouch username and password
i need user name and passowrd for modem speed touch
Nov 12, 2007 | Computers & Internet
Ps3 conection
the username and password should both be admin. once in the settings select the ps3 IP and change to a static IP this should just solve your connection problem
Nov 09, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Thomson SpeedTouch 576 wireless modem router
Connect your wireless modem router Sign on to AOL. Download the AOL Easy Installer for Thomson 576 Wireless Modem Router. When prompted to save the file to a location select an appropriate place (desktop is a good example). Once the AOL Easy Installer is downloaded, double click the file: ST_V1.exe This will launch the modem router installer and show the "Welcome" screen. Click the Start Installation button to continue. If you wish to cancel, click the Cancel Installation button. Read the next page carefully. The text advises to close any running programs, ensure to close your AOL software also. Click Next to continue. Please Note: Connect a DSL filter to each telephone socket that is in use for telephones, dial-up modems and fax machines, etc. If you require additional DSL filters, order online at AOL Keyword Broadband Extras. Notes: Ensure to use AOL 8.0 or above. The AOL account to be used for the modem router set up must be a General (18+) account. This installer is not supported with a modem router containing beta firmware.
Apr 24, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Computers & Internet Logo
398 people viewed this question
Top Thomson Computers & Internet Experts
jimmy Leo
Raj Patel
Wbix
Are you a Thomson Computer and Internet Expert? Answer questions, earn points and help others
