my DVD drive wont open either and I cant get a wireless controller to connect. there are no error codes and it boots to the dashboard...my DVD drive wont open either and I cant get a wireless controller to connect. there are no error codes and it boots to the dashboard...
You can't post conmments that contain an email address.
First of all it seems like the motor belt broke. second if you have waranty then send to MS.third if you dont have warraty you can fix the problem youself by going to walmart and buying a bag of rubber band braids to hold your hair in place the bag is around 2.00 get smallest black rubberband braids and replace torn one but in order for u to change it you would actually have to take dvd casing off easy fix
First off, the xbox 360 needs to be repaired. If there is a game disk in there, there is a way to get it out. You will need to remove the faceplate, and look for a small hole just under the disk drive area. If you straiten a paper clip, you then push it into the hole and the disk drive will slowly open.
make sure door is closed and then if that doesnt do it, open door and look for where the door contacts at closing you will see a little metal table that is like a ground sometimes when a dryer door is closed or slammed the tab might get pulled backwards with the opening of the door again adjust the tab again so contact with door when shut makes contact if that doesnt do it, check your breaker and see if the breaker was tripped too
Noise levels can be lower if you have an open component in the high voltage circuit (magnetron, capacitor, rectifier), or have a failure of the relay that powers that circuit. Also, there are some ovens which will seem to run normally, but fail to heat, due to a bad door switch.
Check inside of door where wiring comes thru for broken wires ,ECU doesn't control windows or door locks. You didn't state what model vehicle you own. But opening and closing door on drivers side causes broken wires on numerous vehicles over the years, most makes and models. Split boot and check all wires inside for breakage.
normally your have 3 problem noises: a) power diodes b) high voltage capacitor c) magnetron see the diagram. i recomend you get help from some qualified service tech for fix it. God bless you
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor unit and will be obvious if it is bad. The part number is 41A2817 and is available from any door opener service company. The part will come with instructions.
if you get the cargo door open .look up top theres about 6 or 7 pins they go in and out .just replace those pins at the dealership its not costly. when it dont open is because those pin are not makeing a good negative ground for the doors to open.
Just a possibility, but a discharged battery could be the culprit. Do the headlights come on brightly? Will the horn blow normally? A 'dead' battery will usually have enough power to illuminate LED warning lights, while not having enough current to operate the starter/door solenoids, etc. Have somebody test the battery voltage to be sure.
The replacement part is available from chamberlain for replacement. I suggest the door be serviced by an experienced technician as the door is probably too heavy for the motor to lift, thats how the part became stripped in the first place
