Try these as I found them from Lexmark's website
Solution
What you will see The printer displays a '
Cover open, please close cover' error message, even though the cover is closed.
Possible cause of the error This can happen if the lever on the cover open sensor is knocked off the switch assembly.
What to doTake the following steps to try to determine if there is a hardware fault:
Steps
Actions
Remove and replace the cartridges from the printer.
Disconnect the power cable and the USB cable.
Check that the power cable is plugged directly into a wall socket.
Reconnect the power cable.
5
Close the printer cover.
6
If the error persists, please contact
Lexmark Technical Support for further instructions.
lexmark x3480 showing "cover open".where is the switch exactly?
I contacted lexmark by email and they replied that as they make these printer scanners cheaply the cost of spare parts would be greater than buying a replacement.As my printer is only 18 months old I find this a bit much and if I do replace rest assured it wont be a lexmark
