Question about Kohler K-3386-0 Rialto one-piece round-front toilet with seat and left-hand
How do we replace the seat on a Kohler K-3386-0 Rialto one piece toilet? The screws/nuts holding the seat down are inside the toilet and aren't accessible. Is there a way to replace the seat without having to replace the entire toilet?
    Sergeant:
  • 268 Answers
Kohler will try to sell you $46 anchor bolt kit 84999 & also there special tool. You should expect that for a $400 toilet.
Try this instead:
1. Use 1/8" drill bit and drill and drill around the bolt until the anchor material can be removed.
2. Carefully clean hole with 11/32 drill to remove all remaining acchor material.
3. Go local hardware store & buy a 10 - 32 3/8"X3/4" rubber expansion plug (make certain threaded part is brass & has shoulder on 1 end), a 10 - 32X1.5" Phillips bolt and couple of small fender washers fit the seat.(about $4 for 2)
4. Assemble carefully not to over tighten and crack the porcelain.
Hope it helps
Posted on Oct 07, 2010
  • grilco
    grilco Oct 09, 2012
    Excellent post and it works. You don't need the kit.
  • D Cheng Nov 16, 2012
    In step 1, do you mean to drill the actual top of the anchor itself (the ring around the bolt) and try to break/destroy the anchor?
The Rialto toilet makes it very difficult to replace the seat as you cannot access the wing nuts which in a moment of engineering genius you put inside the bowl I have already purchased a French seat to...
You should be able to remove the tank lid, reach into the cistern and find submerged at the bottom towards the front of the toilet the plastic wing nuts, hold onto these while tightening the plastic bolt from the top.
I have a Kohler toilet with a similar design, not sure if it is this exact model but they look very similar so I hope this works for you.
Apr 18, 2011 | Kohler 3386-6 Rialto Skylight Round Front...
After flushing my Kohler 3386 Rialto Toilet the top of the valve assembly shoots water out while refilling the tank wich hits the tank top and leaks down the front. What do I need to do to fix this? ...
sometimes removing the 3 or 4 screws that hold the top of assemble and separating the assemble will dislodge debri..and adjust the seat so that the water comes out of the small tube into the overflow tube like it should.
Nov 25, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
I cannot replace my toilet seat on Kohler Rialto toilet. Please help.l
there is probly caps on the hinges or if not just directly underneath there should be a nut.
1. pop the caps off with a butterknife or whatever 2. get a flat head screwdriver to hold screw 3. use a socket to turn the nut underneath.
good luck
Nov 15, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
How do I replace the toilet seat on a Kohler
I repaied one of these laast week and it had the Plastic nuts in between the webbing on the seat where the lid connects I believe You remove the plastic cap with a knife and use a flat tip screw driver to remove the screws and replace the seat.
Jun 01, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
I can't unscrew the bolts on my Kohler 3386 rialto toilet to replace the toilet seat.
There is clips where the bolts should be .Flip the clips up grab hold of the seat and pull it strait out towards the front of the toilet.
Dec 03, 2009 | Kohler K-3386-0 Rialto one-piece...
Can not remove toilet seat from Kohler Rialto
to access the nut remove the tank lid, then go down and forward, its there.
Jul 03, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Kohler K-3386-0 Rialto one-piece round-front toilet with seat and left-hand Logo
2,173 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
