Question about Microsoft Xbox 360 Console
Gypopen tray error - Microsoft Xbox 360 Console
    Scholar:
  • 119 Answers
Open tray error when their is a game or dvd in the drive is a common issue, It usually means you need to replace the disc drive which is about 25 dollars with shipping on ebay.com
Try cleaning the game, Usually this is intermittent at first. I may also be way off, It could be the game itself but I have been repairing systems and computers for 10 years, So Im confident in saying it's time to replace the drive before it becomes a more serious issue.
Posted on Oct 06, 2010
ERROR 0X00000709 PRINTER HP CM6040F MFP
hi,
Error related tray lifting....just check which tray is not lifting and find "is there any kind of abstraction to lift the tray".
Then just refix the tray lifter assy. connector otherwise replace lifter assy.
hope it will help.
Feb 04, 2014 | HP LaserJet Office Equipment & Supplies
Tip
CANON iR2016/2020 ERROR CODES
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540
0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542
0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744
0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
on Aug 03, 2010 | Office Equipment & Supplies
Tray error on a denon dn 4000
The cd transport is up the swanny (broken , kaput).
take it to your nearest registered denon repair/service centre
Sep 05, 2012 | Audio Players & Recorders
A paper jam was not cleared in a timely manner, now the machine will only display "Error Code C0202, Call Technician" It is Saturday and I can not get a hold of anyone at our support center. How can I...
C0202= tray 1 elevator failure.
Open tray 1, check and make sure paper is loaded correctly.
With tray open, open and close front door. This will reset error code. With tray 1 open look to see if paper is stuck behind tray in back of machine, if so remove it ( this will block the lift motor for the tray).
Close tray 1, if you hear a popping noise the lift motor is damaged and will have to be replaced. Until it is replaced operate machine with tray 1 out to prevent error code.
Sep 18, 2010 | Konica Minolta Bizhub 362 Copier
Hp laserjet 8150. i have a problem, tray 3 empty, always but have paper in tray 3
CAUSE: This error message indicates the paper present sensor flag in one of the trays does not detect paper in the tray. This could be caused by one of the following:
  • A broken sensor flag
  • The tray paper guides being set too close and restricting the paper from being pulled
  • The tray is not lifting
SOLUTION: Follow the steps below to determine the cause of a false TRAY X EMPTY message. Tray 2 empty
  1. Verify there is paper in the tray.
  2. Open the duplex unit access door just above Tray 2 on the front of the printer.
  3. Check the black-paper present flag by looking in through the duplex access door.
  4. Open and close Tray 2 and observe the tray lifting looking through the duplex unit access door.
The tray lifts but the error is still present
  1. Inspect the paper present flag on the PIU located just behind the pickup rollers. Ensure the flags are present and not damaged.
  2. Remove the tray guides from the tray and reseat them. Ensure the guides are seated correctly and are in the correct slot for the size paper in the tray. Add paper to the tray and try printing again.
  3. Try another known good tray, if available.
The tray does not lift and the error is still present
  1. Remove the tray, remove the paper in the tray, and inspect the lifting plate in the tray for damage. Ensure it will lift freely by hand.
  2. Try another known good tray if available.
Tray 3 empty
  2. Remove Tray 2.
  3. Open and close Tray 3 and verify it lifts by observing through the Tray 2 cavity.
  3. Try another known good tray if available.
Tray 4 empty
  2. Open Tray 4 and check for an extra **** of paper stored on the left side of the tray. This can cause the tray to stall while lifting and result in a tray empty message.
  3. Defeat the interlock in the vertical transfer unit (VTU). Open and close Tray 4 and watch the tray lift through the VTU door on the lower-right side of the printer.
    NOTE: Follow troubleshooting steps for Trays 2 and 3 when working with the 2 X 500 sheet-input tray.
  1. Check the tray guides to ensure the guides are seated corrected and are in the correct slots for the paper size in the tray.
  2. Inspect the paper present sensor for damage.
  3. Check for any broken plastic pieces in the tray that may be a broken sensor flag.
The tray does not lift and the error is still present Defeat the VTU interlock on the right side of Tray 4. Open and close Tray 4 and observe the tray lifting.
Nov 25, 2009 | HP LaserJet 8150n Printer
Describe your Minolta Di3010 Grayscale CopHi I
The error code you are getting is a paper tray lift problem. Open all the paper trays and make sure that you have the correct size paper in each paper tray. Also, make sure the paper guides are tight againest the paper in the trays. Turn the copier OFF then back ON... Wait for the copier to come to ready and one tray at a time reinstall each tray at a time.... The one that cause's the error code to show up is the paper tray with the problem. Once you know what tray is the problem, remove the tray and look inside the copier for a wade of paper jammed behind the tray... If not you may have a bigger problem, then we can help with... Good Luck....
Jun 26, 2009 | Minolta Di3010 Copier
Ricoh copier/printer error SC505
SC505 LCC Tray Malfunction (Optional LCC)
Remove the trays - reseat see if that clears it
Jun 19, 2009 | Office Equipment & Supplies
HP COLOR LASREJET 3500 41.3 ERROR
hi ray, it's chris. i called your cell phone, but figured you might see this. replace the registration clutch. after some research, this seems to be the solution given that should solve the issue in that printer, and it's an independant part from the paper pickup assembly...
RK2-0247-000CN
chris
May 27, 2009 | HP Color LaserJet 3500 Printer
913 service motor error
If this is the first time you have seen this error, do the following:
  1. Power off the printer.
  2. Remove all installed paper trays.
  3. Make sure the paper is loaded correctly in each tray. If it is not, reload the paper into that tray.
  4. Look up into the printer where the paper tray slides in and out. Check the feed (autocompensator) assembly for any damage.
  5. If everything is fine, reinstall the tray and power on the printer.
  6. Try printing a few print jobs.
  7. If the error does not return, continue using the printer as before. Keep an eye on it for the next few days. If the error does not return, it may have been an isolated incident.
  8. If the error returns just as soon as you power on the printer or when you try to print again, you will need to find out which paper tray/paper source is causing the problem.
  • If the printer has only the one integrated paper tray, the problem will be with either the tray 1 pick arm/autocompensator assembly or the printer's engine/system board.
  • If the printer has more than one paper tray installed, try printing from each paper tray one at a time. The best way to do this is to have all of the paper trays empty and then proceed as follows:
    1. Put paper in tray 1 only.
    2. Print from tray 1.
    3. If tray 1 works fine, empty tray 1 and put paper in tray 2 and so on until you encounter the error message.
    4. If you receive the error when printing from one particular tray, power off the printer to clear the error.
    5. Power the printer back on.
    6. Skip the faulty paper feed slot and move on to the next one (if another one is present). If you can print from all but one of the paper trays, this is the source of the problem.
      If you have extra paper trays/drawer units installed and the error occurs from only one particular source, there are some things you can do as a temporary fix.
      • If the error is occurring from an OPTIONAL paper drawer/source, power off the printer and remove the defective drawer from the printer. You will then need to set up the printer to print from a different tray. For information on removing an optional drawer, click here.
      • If the error is occurring from the integrated paper tray (tray 1) AND you have optional paper trays installed, take all of the paper out of tray 1 but leave tray 1 installed. Set up the printer to print from one of the other paper tray sources (tray 2, tray 3, multi-purpose feeder, etc.).
    7. And if your getting the same error then you need to get it serviced...
Sep 09, 2008 | Lexmark Optra SC 1275 Laser Printer
Tray 1 problems
Most machines refer to the bypass tray as tray 1. You might want to make sure there is not a jam in there.
Jul 05, 2007 | Ricoh Aficio CL2000N Laser Printer
Microsoft Xbox 360 Console Logo
35 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
