Question about HP LaserJet 1020 Printer
Hi i have installed hp1020 printer in one pc(XP)and shared it which is working fine. but when connect it to another pc (win 7) it get the error message "operation failed with error 0x000006be". pls help me to solve the problem.
When i giving print one system its coming print but another system not coming becuse both system r domain is there any patch
Posted on Feb 17, 2011
    Problem Solver:
  • 3 Answers
Try to download driver for windows 7....
Posted on Oct 12, 2010
Why cant my windows xp share printer w windows 7?
Hi Chris,
Make sure that both Computers are turned ON if you are printing from Win7 through Win xp
Also make sure that the printer is installed on both machines and that the printer sharing is set up, and that both computers are on the same Workgroup.
Also make sure that the Turn On network discovery is activated in windows7 for XP to be able to detect it on the network, and that the File Printer Sharing is also activated, make sure everything in the sharing settings is activated in the network.
I hope that this will help,
mvincentc
Apr 16, 2012 | Toshiba Computers & Internet
Printer HP Photosmart C5180 Series cannot be contacted over the network
Check with HP for a Windows 7 driver for the printer. HP Ink Jets require proper drivers to work correctly. Once you have downloaded and installed the drivers try connecting again.
If you have installed the drivers and Windows 7 still refuses to "talk" to the printer, you may have to adjust your advanced network settings as well. Open up the Network and Sharing center, click on advanced sharing settings and make sure file and printer sharing is turned on. Also check "File Sharing Connections" and enable file sharing for devices that use 40 or 56 bit encryption.
If that fails to work you may need to speak with HP support for further assistance.
Feb 23, 2012 | HP Photosmart C5180 All-In-One InkJet...
My hp1020 works perfectly using xp but when I try to use the hp1020 on windows 7 (32 bit) it may work briefly then it stops working.
Your best bet to solve this will be to do the following. Go to HP.COM and download the VISTA 32bit driver to your computer. Go to the printer folder and right click on the icon for the 1020 driver that works intermittently, select printer properties. Click the advanced tab and you will see an option next to the currrently installed driver that says "new driver". Click on this and when the install starts say have driver and point it to the file you downloaded. The Vista drivers seem to work for most printers better than the downloaded ones that Win 7 installs automatically.
Mar 17, 2011 | HP LaserJet 1020 Printer
Hi, my Xerox phaser 6110 is installed on a Windows XP computer and i'm trying to share it with another Windows 7 computer on the same network. Unfortunately, the drivers i downloaded for windows 7 will...
follow this simple steps:
  1. Share you printer
  2. Go to your Win 7 PC
  3. Find your Win XP PC on network
  4. Click to see shared devices
  5. Right click on Xerox 6110 icon and then click "Conect"
Enjoy!
Mar 13, 2011 | Xerox Phaser 6110 Laser Printer
Hi i have installed hp1020 printer in one pc(XP)and shared it which is working fine. but when connect it to another pc (win 7) it get the error message "operation failed with error...
You need to change your home network. Change Windows 7 machine from homegroup to workgroup and restart your systems. This should work for you.
Windows is defaulted to homegroup
Hope this helps
Oct 30, 2010 | HP LaserJet 1020 Printer
The network printer will print a test page but nothing else
whenever a printer is connected to a network it loads a driver for all the lower versions of operating systems so that if any computer from the network having a lower version gives a print command it can be spooled using that driver. On the other hand you have connected the printer to an OS of low version and printing through a higher version. Its just like connecting a printer to DOS comp and trying to print through Win 98. So now you know what you have to do. Just find your driver compatible for Win7 and connect it to win7 and you can give print through xp.
Apr 14, 2010 | HP Photosmart C5180 All-In-One InkJet...
I want to share an HP 7760 on an XP with Win 7
To get ahead of myself and answer your question first, your Win 7 machine may automatically load a driver for your shared printer.
Please have a look at the procedure below: (these instructions assume that your XP machine is sharing the HP printer and that your Win 7 laptop can "see" your network and the shared printer connected to your XP desktop computer)
On the Win7 machine, follow these steps:
1) In "Control Panel" click "Add local printer"
2) Create New Port > Local port
3) Port Name is "\\xpcomputername\printername" - without the quotes
(insert the XP's real network name and your printer's real name in the above location)
4) Click <OK>
5) Windows 7 should automatically load a driver allowing you to print on the HP connected to the XP from the Win7 laptop.
I hope this helps!
Mar 07, 2010 | HP PhotoSmart 7760 InkJet Printer
I need a 64 bit Canon D780 printer driver...where can I download? I went to canon, but their drive is only a 32 bit
Okay so this may not help you now, but I just got a hand me down D780. After much frustration and research here's the solution that I was able to work with. It isn't perfect; but it's something....
So here are the steps for network shared installation; assuming your D780 is installed on an old xp desktop and you're using a Win-7 laptop. If you're using the printer directly on your Win-7 machine, just use the local printer installation after the XP mode has been installed.
1) You'll have to install WinXP mode on Win-7 using the steps listed on this link. If you have a genuine Win-7 copy installed, this download and installation is free, courtesy Microsoft.
http://windows.microsoft.com/en-us/windows7/products/features/windows-xp-mode
2) After installation, you'll have to change network settings for your virtual pc. This step is necessary if you want to be on the same home network and want to see the printer! Never mind if you don't understand this logic. Just follow the steps and you'll do just fine. To change the network settings in vPC: click Tools; click Settings; select Network from left; then for Adapter 1 choose the actual network adapter connected to your router (simply put: select the wireless adapter or wired adapter you're using to connect to your actual router or home network. You can find that from Change Adapter Settings in Network and Sharing.) Click Ok.
3) Now add the printer as local or networked following your usual XP steps. You should be able to see the printer. If not, open a command prompt window, check your ip to make sure you're on same network. If not, or if you don't know how to do that, just type in ipconfig /release enter and then ipconfig /renew enter. Try to connect to the shared printer by pinging the ip of the host computer. If the ping works, you should be able to see the printer then.
Connect printer and use in XP mode. Not the best solution, I know. But it's free and at least lets you print from your laptop, given the circumstances.
Feb 21, 2010 | Canon imageCLASS D780 All-In-One Laser...
Printing using Parrallels and winxp
How do you have this unit connected via parallel - there is no parallel port
Apr 22, 2007 | Epson Stylus CX6600 All-In-One InkJet...
HP LaserJet 1020 Printer Logo
563 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
