I need to know where to connect the sata cables for the cd rom to the mother board
    Guru:
  • 124 Answers
Sata cables on both ends have female connectors. Just find a "L" shaped connector on the back of your cd rom and to the motherboard( usually about the size of a usb connector but narrower a little bit, sometimes color blue or black depending on the brand of your motherboard with a lable on it like "sata 1" or "sata2" ) and connect the cables on each end. Ther's only one connector at the back of the cd rom but on the motherboard, you can choose any sata connector available.
Posted on Oct 06, 2010
Picture of hp m8100y mother board sata and cd rom cable
see this webpage
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c01077641&lc=en&jumpid=reg_r1002_usen_c-001_title_r0001
I have also attached an image of both ends of a SATA data cable (right angled at one end, straight and all types available) . SATA cables are standard, there isn't a special one for any particular device or motherboard.
12.April.20013 c032f163-3941-4529-9272-f7e3110a5dfc.jpg bbe12c09-6d51-471a-bb0c-effac1df97cc.jpg
Dec 03, 2012 | HP Pavilion Media Center m8100y PC, Intel...
I am unable to connect a cd rom from an old pc to my new emachines because there is no "ribbon" to connect the cd to? How else can I connect it to the motherboard? The CD doesn't have a SATA...
Look on the mother board for a ribbon connector.. double row of pins.. Some boards will have a legacy connector. If not.. you can buy an adaptor to connect IDE CD to board,
BUT.. for about the same cost, you can buy a cheap new CD-DVD RW - burner.. probably with far better peformance than an old one. About $25 should do it.
Dec 13, 2010 | E-Machines emachines (emachinees) CD-ROM...
I need to know where to plug in on motherboard
If its having sata connection you can see sata ports on *********** board using sata cable
1.Pic of sata cable
2.Pic of Sata ports on mother board
You can connect any one of the ports. and you need to go to bios and enable the sata ports if its not done already..
If you have a normal CD Drive you can connect with IDE cable.
See the pics below
Apr 24, 2010 | Lite On LH-20A1H DVD RW Dual Layer Burner
Sata power supply with ide only mother board?
Unlike IDE drive cables, which allow you to connect at least 2 drives to the same cable, SATA cables only allow one connection from motherboard to drive per cable. You can connect as many SATA drives to your motherboard as you have SATA connections.
Mar 25, 2010 | Computers & Internet
I have asrock prescott 800 ddr400 fsb800 motherboard. i bought a new dvdrw that is sata. is this dvdrw compatible with the mother board? where to connect?
Sorry but the motherboard Asrock 845GV (P4I45GV) doesn't have a SATA controller and there for does not have the ability to connect a SATA CD/DVD-ROM drive to the MB. However you can buy a serial ATA IDE to SATA converter which will allow you to connect you're SATA CD/DVD-ROM drive into an opened IDE port. Provided is a link to you're motherboard;
http://www.asrock.com/mb/overview.asp?Model=P4i45GV%20R5.0 Next, is a link for the SATA convertor;
http://www.startech.com/item/IDE2SAT25-40-Pin-Female-IDE-to-SATA-Adapter-Converter.aspx
Cheers'
Mike
Jan 30, 2010 | Asrock 845GV (P4I45GV) Motherboard
I need to hook up a CD drive to my computer. I have a P5GC MX/133 mother board, two 256 gig hard drives and 3 1/2 disk drive. I would preferr not to diconnect any of the ubove
Well you could get an external CD/DVD drive. You didn't say how the existing drives are connected - but it seems like, according to specs, that you can take
4 - SATA - Serial ATA devices
2 - ATA (aka IDE) devices (one connector jack. Drives would be Master and Slave, or more likely CSEL or Cable Select. So if you jumper the drives CSEL they should just work.)
SATA is the better drive interface technology these days, so I'd go for an internal SATA CD Drive ... assuming you have a CD bay. Not knowing how / who built your computer I have no way of knowing how many spare Power Cables and SATA cables, etc. that you have available. But usually with a new drive purchase they give you cables.
If they don't give them, and you need them, you can get power cable adaptors as well that will change a white standard power plug/cable inside the computer to an SATA type power plug. Often there will be spare SATA power cables in there anyway since the motherboard come with 4 SATA connections on the motherboard.
Nov 22, 2009 | ASUS P5GC-MX/1333 Motherboard
My motherboard doesnt have that long prong connector for the cd rom drive so how do i connect the cd rom drive?
What you will going to do is find a nearest computer store in your place and buy the connector for your cd rom drive.
Oct 25, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
CD ROM DETECTION PROBLEM
LEAVE YOU hard drive on primary master port on your main board set as master or single drive ( IF YOU HAVE A STATA HARD DRIVE THEN DONT WORRY ABOUT THAT PART)
SET YOUR FIRST DRIVE AS MASTER
SET THE SECOND AS SECONDARY
use the jumber in the back of the drive to set them the propper setting is labeled on the drive it self
Connect them to the secondary port on your motherboard
so you should have
HARD DRIVE - MASTER OR SINGLE *jumper settiing* connected to the primary port on your main board
DRIVE 1 = MASTER *jumper settiing*
DRIVE 2 = SLAVE *jumpersetting*
connected to the secondary port on your mother board
IF YOU HAVE A SATA HARD DRIVE FORGET THE PARTS ABOUT HARD DRIVES ABOVE
i assumed you had a IDE hard drive
JUST USE THE SETTINGS FOR THE DRIVES and it should work :)
Dec 25, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Computers & Internet Logo
David Payne
David Payne
