Question about Moen & One Handle Tub & Shower Faucet
We have a new shower. Water comes out of shower head and tub faucet together. What do I need to do?
    Sergeant:
  • 268 Answers
Its because that model usually when u pull for the shower is not properly connected. You will have to remove handle and coverplate, then shine flashlight down to see what is happening when pulling rod on tub spout for shower. Usually its broken or bent and just needs new one installed. It cost me 2 buck for new shower rod. Directions u can get free from Moen with free lifetime parts.
Posted on Oct 06, 2010
Why is water coming from shower head and faucet at same time?
sounds like you need a new tub spout with diverter...thats your problem...unscrew spout and go to lowes and match up with new one...use pipe dope on threads and reinstall new one...good luck
May 30, 2012 | Danze & Single Handle Tub And Shower...
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
Leaking shower head
Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
Water steams out of shower head when tub faucet is on
check the tub faucet the pull lever maybe slightly faulty causing back pressure in line and pushing water up to shower head --u may have debris in tub line causing partial blockage -or u have alot of water pressure coming in and it is to much for the lines to handle and it is pushing up to shower head
Feb 26, 2010 | Delta & Leland Lavatory Faucet
Moen shower valves are failing
the diverter is stuck. you have to move it up and down to free it up. the diverter is the mechanism attached to the tub spout that switches the water from shower to tub. you may also need a new diverter if fiddling with it doesn't work.
Jan 02, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Water comes out of both the faucet and the shower head at the same time when I turn the water on past halfway.
You will have to get a new tub spout, is sounds like the old diverter is not working right. The new one should fix the problem.
Sep 26, 2009 | Moen & One Handle Tub & Shower Faucet
Water coming from faucet and showere head when the
the washer on back of the dirverter knob needs replacing or the seat behind the vavle stem
Aug 18, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Delta T13090 faucet shower head working at the same time.
The only possible explaination is that the water is finding it easier to go up than down. Water is lazy, just like me. ;)
Use an allen key to remove the tub spout. It's underneath and awkward. Once the allen key is loose, the spout just slides off. Try running the water. This may solve your problem and all you'll need is a new tub spout. If not.....
Turn the water off to the house.
Use an allen key to remove the handle.
Use a phillips to remove the trim plate (2 screws). Cut the silicone around the trim if it's there (which, in a proper installation it shouldn't be, but...)
Unscrew the nut (usually chrome) holding the cartridge into the brass body of the valve. The cartridge pulls straight out. Check for restriction in the ports of the cartridge itself. Check for restriction in the line going down to the tub spout. If you can't find anything, replace the cartridge.
Reassemble & Enjoy!
Aug 05, 2009 | Delta & Single Handle Shower Faucet
Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
Jun 15, 2009 | Delta & Single Handle Shower Faucet
Moen & One Handle Tub & Shower Faucet  Logo
179 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
