Question about Saeco Vienna Digital Coffee Maker, Espresso Machine
The screen says to Ventilate. I fill the water tank then turn the steam knob counter clockwise and water streams out Ventilate drops off the screen and it just says Hot Water?? When I try to make a coffee it comes back to Ventilate. Can't find in the menu Ventilate only.
  • 1,089 Answers
Hi
You might have a restriction or blockage in the brew head. This is from fine coffee residue and oils that will build up in the passages of the brew unit. To fix.
Remove the brew unit. Holding the handle, on the top left side is the brew head, there is an outlet pipe that exits the front side towards the door (looks like a long "L" pipe). 2 screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (be careful, there is an O-ring, spring and at the end a black rubber disk or crystal ball). Do this over a towel to prevent loosing small pieces, mainly the crystal ball.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember, thumbscrew), DON'T use the key to install the screen, use your fingers.
Once the screen is out, look at where the screen was. There are 2 holes. A big one in the center and a small one to the side.
With the brew unit upside down over the towel, insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first. Then the spring small end first on the crystal ball.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head. That should do it.
Posted on Oct 06, 2010
Testimonial: "Works perfectly now. Thank you"
  • Cynthia OConnell Oct 06, 2010
    I followed your instructions and it is working perfectly!!!. I was a little reluctant to take the machine apart especially with all the small parts. But it worked. Thank you
  • roberttho324 Oct 18, 2010
    Legend bansheracer. Extremely good instructions and it was done in 5 minutes. Love your work.
Tip
Saeco, Gaggia, Spidem VENTILATE, Prime what is mean, how to perfrom
Ventilate or priming or else loading all means the filling the machine system full with water, like pump, piping and boiler. This must perform first time of starting up the machine.
It will also appear if the water system in not full of water especially after the steam preparation some steam can be blocked in the system and the machine recognized it by luck in the pressure.
Another reason that ventilate it appears on screen is because air have been insert and blocked in the water system usually from water filter or water softener located in water tank.
So here how you Ventilate or Priming or loading:
Place a container beneath the steam tube.
Turn the knob counter clockwise to start loading the circuit.
Wait until a steady stream of water flows out from the nozzle.
Turn the knob clockwise
to terminate the circuit loading process.
Remove the container. The machine is warming
up; lights are flashing.
Note: You must load the circuit before starting up
the machine for the first time, if it has been inoperative
for a lengthy period or if the water tank has
been completely emptied. The circuit must also be
loaded each time the light flashes
on Aug 28, 2010 | Coffee Makers & Espresso Machines
How do you descale my Delonghi Magnifica?
10.3 DESCALING Due to the continuous heating of the water used to make the coffee, over time it is normal for the tubing inside the machine to fill with lime scale. When the light starts flashing (section 12 - point 5), it is time to descale the machine. NOTE: when the light switches on, the coffee maker can still be used to prepare coffee. Proceed as follows: • Empty the tank and pour in the contents of one bottle (125 ml) of DURGOL descaler plus one liter of water. For subsequent descaling operations, descaling solution can be purchased from authorized technical service centers. Note: Make sure splashes of descaler do not fall onto surfaces sensitive to acid such as marble, limestone and granite. • place a container with a minimum capacity of 34 oz. under the cappuccino frother (Fig. 3); • turn the machine on by pressing the button (Fig. 4). • wait for the green and indicator lights to come on steady. • press and hold the button for at least 5 seconds (Fig.14). The decalcification warning light will illuminate (section 11 - point 8) to indicated the start of the descaling program (the and lights remain off to indicate that it is not possible to make coffee). • turn the steam knob half a turn counter-clockwise (Fig.5). The descaling solution will come out of the cappuccino frother and start to fill the container underneath. • the descaling program automatically performs a series of deliveries and pauses, so as to remove the lime scale deposits from inside the coffee maker. Fig.32 The two red buttons have snapped out CORRECTLY The two red buttons have not snapped out CORRECT INCORRECT 17 OPERATING INSTRUCTIONS • after around 30 minutes, when the light comes on (section 12 - point 1), turn the steam knob half a turn clockwise (Fig.6) until it stops. The machine must be rinsed so as to eliminate the residues of descaling solution from inside the machine. Proceed as follows: • remove the water tank, rinse it and fill it with clean water. • reposition the tank. • empty the collection container (located under the milk frother) that is full of liquid, and then replace it under the milk frother. • turn the steam knob half a turn counter-clockwise (Fig. 5). Hot water will come out of the milk frother and fill the container underneath. • when the tank is empty, the l ight goes off and the light comes on (section 12 - point 1). • turn the steam knob all the way clockwise (Fig. 6) and fill the water tank with clean water again. • the program of descaling is now terminated and the machine is ready to make coffee again. NOTE: if the descaling procedure is interrupted before completion, the alarm (section 12 - point 5) is not deactivated and the procedure must be started again form the beginning.
Jul 14, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Cant remember how to de scale
Instructions per De'Longhi:
10.3 DESCALING
Due to the continuous heating of the water used to make the coffee, over time it is normal for the tubing inside the machine to fill with lime scale. When the light starts flashing, it is time to descale the machine.
Proceed as follows:
cappuccino frother;
• turn the machine on by pressing the button.
• press and hold the button for at least 5 seconds. The decalcification warning light will illuminate to indicated the start of the descaling program (the and lights remain off to indicate that it is not possible to make coffee).
• turn the steam knob half a turn counter-clockwise. The
• after around 30 minutes, when the light comes on, turn the steam knob half a turn clockwise until it stops.
• turn the steam knob half a turn counter-clockwise. Hot water will come out of the milk frother and fill the container underneath.
• when the tank is empty, the indicator light goes off and another light (looks like a pitcher pouring water) comes on.
• turn the steam knob all the way clockwise and fill the water
NOTE: if the descaling procedure is interrupted before completion, the alarm is not deactivated and the procedure
IMPORTANT: FAILURE TO DESCALE THE APPLIANCE REGULARLY INVALIDATES THE WARRANTY.
You can download the entire pdf manual from the De'Longhi website: http://www.delonghiusa.com/index.php?texts&pid=10&catid=1
Helpful tips:
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water or use abrasive cleaning products/scouring materials on any part of your espresso machine.
Jun 24, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Keep getting ventilate message - won't ventilate and cannot operate steam or grinder w/ ventilate message
Try this run the hot water cycle for a few seconds, it that works, try steaming if you get the message again clear it by running the hot water cycle and then go to steaming, this time push in on the knob after you open it, it that works, then the tap rod or the valve assembly needs to be replaced.
May 01, 2010 | Gaggia Titanium Espresso Machine
How to decalcify?
1. place water and descaler solution into tank
2. remove milk frother from arm
3. place a jug under steam arm
4.hold down the button 2nd from the right next to the menu button for a few seconds.
5.descaling machine open steam knob will appear on the display
6. after descale has finished "fill water tank" will appear.
7. refill tank with clean water no descaler
8.press the button 2nd from the right as in step 4
9. rinsing machine will appear.
10. when finished"close knob"will be displayed
11. refill water tank
12. ventilate will appear on the display
13.press the hot water button and allow to run
14.ventilate will disappear,warming should be displayed.
15. job done !!!
Jan 27, 2010 | Gaggia Titanium Espresso Machine
Solis Palazzo Descaling (?) Problem? Please Help!
Hi
He has the first part correct, but when you rinse the machine with fresh water the machine needs to quit on its own and you will know this when the descale light is off, but you will have a flashing green light and a steady red light over the water drop. Refill the water tank, the close the steam knob and then open it again. This will clear the red light and then the machine will start heating. IMPORTANT on any automatic machine is when the water tank is off the machine don't do anything with the beans. A chip of bean in the water receptacle can be a big problem for the machine.
Jan 28, 2009 | Solis Palazzo Espresso Machine
Descaling
(Button 26 is the right-most one (2 intersecting
ovals.)
From the Manual:
Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
• Direct the steam nozzle (14) toward the drip
tray.
• Position a vessel of adequate capacity under
the steam nozzle and turn the hot water knob
anticlockwise (16). The appliance starts an
automatic descaling cycle with pauses preset
by the manufacturer and managed
automatically by the appliance.
• At the end of the cycle, the flow of the
descaling solution is shut off and the 5 buttons
start flashing simultaneously.
• Turn the knob of the hot water nozzle (16)
clockwise to OFF. In this case, also the warning
light (27) flashes.
• Rinse the water tank and fill it with fresh
drinking water.
the steam nozzle and empty 2/3 of the
contents of the water tank by turning the steam
knob (16) anticlockwise; to shut off the flow,
turn the knob (16) clockwise.
• Let the appliance heat up and empty the
remaining contents of the water tank by turning
the steam knob (16) anticlockwise; to stop the
flow, turn it clockwise.
HTH
dave
Aug 14, 2008 | Gaggia Syncrony Compact Coffee...
Saeco royal cappuchino ventilate
Alternatively, try draining the machine. Page 37 of the user manual, Drainage. Place cup under the steam/hot water tube, turn knob clockwise around to 9. If the pump is ok, it will start automatically and start filling the cup. Drain about 1/2 cup of hot water and return knob counterclockwise to start position. If the flow meter is not damaged, the Ventilate message should be gone.
Jun 30, 2008 | Saeco Royal Professional Espresso Machine
Ventilate
I fixed my ventilate problem! After 2 days of utter frustration and pushing many buttons, I read another guest comment about resetting to factory settings. Push the up button under the small coffee icon. It should say factory setting with the asterick next to it. Push OK. Then push "yes" for factory settings. Then my machine started working again! Hallelujah! It erased my personal coffee cup setting, but who cares.
Big thanks to the person who posted their solution on Dec. 2007.
Jun 11, 2007 | Gaggia Titanium Espresso Machine
Saeco Vienna Digital Coffee Maker, Espresso Machine Logo
421 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
