Question about Frigidaire Refrigerators
Getting water on floor water line is not leaking
  • 262 Answers
First check the inside of the freezer at the bottom and see if you have a block of ice on the freezer floor.... if you do then your defrost drain is cloged.... use warm water to dethaw
if you do not see the drain hole then it is behing the back wall where you see the vent .... in side the freezer. use some warm water.... This will take a while and will be wet ... get a couple of BIG towls and keep the warm water comming untill the water drains....
Not : once it drains stop pouring water in it .... It only hold 1 or 2 cups in the pan under the machine.
if this is not your problem then you most likely have a water line leaking or a water valve leaking under the machine.
Posted on Oct 06, 2010
I have a water leak in bathroom not from toilet. How can I check the pluming in that area?
Your idea may correct. But majority of cases it is floor/ground seepage....leaks through your tiles or waterproofing layers and so on..To chk...keep on pouring water to the ground of the bathroom, near wetting areas, and close the freshwater line leading to the bathroom taps
May 18, 2016 | 2006 Tahoe Transport
Model 1068630583. Why is it leaking water on the floor?
Remove the floor grille and check drip pan if full carefully remove and drain water if pan is dry [pan is drip tray from auto defrost water goes to pan than usually dissipates ] if dry look to back at water line for damaged or leaking line or valve
Aug 11, 2015 | Kenmore Refrigerators
Leaking water on floor
remove the floor grille and check drip pan if full carefully remove and drain water if pan is dry [pan is drip tray from auto defrost water goes to pan than usually dissipates ] if dry look to back at water line for damaged or leaking line or valve
Aug 11, 2015 | Refrigerators
Water leak on floor under refrigerator
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
Jun 15, 2012 | GE Refrigerators
Jenn-air JFC2089HEP French door Fridge with bottom drawer freezer. Water is leaking on to my floor. I checked all the external connections at the solenoids / water into filter water / water out of...
one of the plastic wtaer lines could be cracked,when the ice maker fills the water line could be cracked and leak out when it's filling.also it looks like you have a water dispenser in your machine,go in the back with the bottom panel removed and have someone fill a cup of water and check the lines while it's filling.where does it look like the water is leaking from?is there ice in the bottom of the freezer floor?the drain could be blocked.when the machine goes into defrost if the drain is blocked the water will leak out onto the floor of the freezer and then out onto the floor,if that's ok i'd have to say it will be one of the plastic lines,it gets hot in there,have you been cleaning the condenser coil?that should be vaced out at least once a year,this is how the heat escapes from the machineif the coil is clogged with lint and dust it will run hotter than normal and this also makes the plastic lines brittle.hope this helps and change the water filter every 6 months.
Sep 22, 2011 | Refrigerators
Water frozen in the bottom of freezer on double door Maytag frig.
Shut the water off for one before it ruins all your floor. It probably has frozen and broken a line or the valve. You can go to this site and get a drawing on your fridge and parts if you need them.
http://www.appliancepartspros.com/partsearch/
Jul 28, 2009 | Maytag MSD2756G Side by Side Refrigerator
My refrige leaks water on the floor from the freezer side on the left. I turned the water off and disconnected the water line. Still once or twice a week the refrige leaks water on the floor.
Sounds like ice build up on the freezer coils. Disconecting the water line doesn't stop regrigerant from flowing through the coils since they are still working. Easiest way would be a hair dryer to melt the built up frozen consensation. After you should see no water on the floor and you can turn the water back on (i assume the water is for your ice water and ice cube tray).
Apr 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Water leaking
Hi
There are several things to check for: The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. Some fridge's have a humidity switch inside the fridge that should be turned on to prevent sweating on the center bar between the fridge and freezer section. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. A kit to repair a separated heat exchanger line, comes with instructions as well. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Please revert for any clarification.
A Fixya rating would be appreciated if you found this to be helpful.
Thanks
Rylee
Feb 16, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Water heater problem (no leak on floor)
It sounds like you might have scale buildup on the elements. If its a dual element unit it will ground it self out and it sounds like its boiling. constance usage of electricity, but no water usage. Drain it, and pull the element and replace the element.
Jan 17, 2009 | Water Heaters
Refrigerators Logo
89 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
