Question about Frigidaire FAC125P1A Window Air Conditioner
I have a Frigidaire combo-ac/heat window unit that is not blowing hot air when heater mode is selected.
3 Suggested Answers
SOURCE: My Frigidaire AC/Heater unit model
The problem was in the power cord. I didn't have to disconnect the heat after all.
Posted on Apr 27, 2008
  • 8404 Answers
SOURCE: Purchased used Frig FAH12EN2T HEAT/AC,
Look for failed start capacitor.
Posted on Oct 19, 2009
In AC mode the cooler fan doesn't turn on and after a little while the warm air starts to blow instead of cold air. Any ideas
Sounds like a bad or stuck reversing valve. Typically r.vs. are energized in cooling, verify 24 volts to valve, if yes , bad valve
Sep 30, 2016 | Whynter ARC-14SH ECO-FRIENDLY 14000 BTU...
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
Jun 02, 2016 | Heating & Cooling
Kennmore combo window unit will not blow hot air what could be the problem
That all depends on the model number of the unit you own. Some window units have electric resistance heat (like a toaster), where others are a heat pump. Even other models have heat pump ability, with added backup resistance heat.
Then again it could be a settings problem. Ifd the unit is not set in the right mode, and the thermostat is not set correctly, the unit may operate and not produce heat.
Jan 08, 2015 | Heating & Cooling
Frigidaire heat/AC window unit will not blow warm air
if you still have the old heater element its done but if yours is the new heat pump system you need to find the reverse solanoid and just tap it a few times with the handle of a plastic screwdiver till you hear it click these solanoids do stick if you havnt used the heater for a while
Dec 09, 2013 | Frigidaire Heating & Cooling
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
Have Goldstar Model R1804h ac/heater window unit when turned to heat blows only cold air what is easiest thing to check and purchase first.
If your thermostat is working on the Heat cycle (listen for "click" when turned up and down on Heat), then your heating coil assembly is probably bad. The heating coil is in series with a Fusible Link and a Bi-metal thermostat, if any of these three fails, there will be no heat from the coils.The Link and Bi-metal Thermostat are made up as part of the heater coil assembly.
Jan 18, 2013 | Goldstar Heating & Cooling
The heater is blowing cold air
Check heater hoses running from the engine to the cabin. and check if heater switch works
Nov 28, 2012 | Cars & Trucks
Heater doesnt work
To troubleshoot this types of problem,click the link below :---
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
This will help.Thanks.
Mar 27, 2012 | 1994 Volvo 960
How does the heater part of the CPN12XH9-E work? Does the hoses need to be in window still?
Yes, hose needs to connect to outdoors, since it operates as a heat pump. You'll notice cold air blowing out the exhaust when in heating mode, and hot air blowing out the exhaust in cooling mode - unit exhausts opposite of temperature you want.
Jun 13, 2011 | Haier HEATER CPN12XH9 Air Conditioner
Heating & Cooling Logo
169 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
