Question about Kenmore Dryers
My mother in law has a kenmore dryer that is 15 - 20 years old. It will start but the dru will not turn she says it does not have a broken belt
  • 262 Answers
Verification of the belt in place would first need to be done, then check to see if the motor is running.
The belt could have jumped off
if the belt was replaced recently, It might not have been the right belt.
Posted on Oct 06, 2010
I own a Kenmore 796.8044 steam dryer. It is less than one year old and the drum will no longer turn. I suspect either the belt has slipped off or has broken. Is this a common problem?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 29, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
The drum in my Kenmore gas dryer (over 20 years old) will not spin around. There is still heat, but clothes will not spin around. Does the belt need to be replaced or should I get a new dryer altogether?...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Apr 18, 2011 | Kenmore Dryers
Dryer wont turn
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 24, 2010 | Kenmore 63942 Dryer
Kenmore 500 series dryer won't start. Only 2.5 years old.
turn the drum with your hand,if it feels hard to move you could have something stuck in the blower wheel that is below the lint filter and behind the duct that the filter slides into or the belt could be jammed,if it moves try starting it it might start you could have a flat spot on the motor and most likely you'll need to replace it,if it'shumming it's the motor making the sound
Feb 14, 2010 | Kenmore Dryers
Kenmore electric dryer, power on, drum doesn't turn. Help? can I fix this myself or do I have to call out for repairs. About how much will this cost, or should I replace, it's about 12 years old. Thankx
check the belt that goes around the drum and the idler and motor pulley. if it is broken replace it. when installing the ribs on the belt go down against the drum. a new belt is somewhere between $10-$20. you can do this easily yourself.
Oct 11, 2009 | Kenmore Dryers
My dryer won't turn on. it's plugged in. power is fine in the room. one of the link trap screws came out but I put it back in. still won't turn on. i can't find a model name or number printed on the...
I know you said you have power in the room, but make sure the breaker to the power outlet for the dryer has power, because most dryers are 220 volt and room power is 120 volt.
If the belt is broken on the dryer, it would also not allow the drum to turn, but the motor may be running.
Check to see if the motor is running. When motors are running with a broken belt they can almost be silent while running.
If your breaker is ok and power is ok at the power outlet, then your problem could be a faulty motor, broken belt, faulty start switch or faulty timer switch.
I hope this helps
Oct 03, 2009 | Kenmore Dryers
Kenmore dryer not running
Ticking sound is the timer running--so it is not the problem unless a contact has failed or a wire has come loose.  Broken door switch, thermostat failed in open position, or clogged lint filter/exhaust vent/outlet would keep unit from running.  If you can hear the motor running but the drum is not turning then the drum belt is broken.
Jun 04, 2009 | Dryers
Kenmore HE2 Dryer
That model has a belt switch. If the belt is broken then it will not com on.
Oct 30, 2008 | Kenmore 62602 Electric Dryer
Broken belt
remove top first, then front just a few screws,then put belt around the drum and pulley and reassemble,bye.eire
Dec 03, 2007 | Kenmore 63942 Dryer
Dryers Logo
101 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
